4.6 Locating Serial Numbers for System Components
You may need to provide the serial numbers for the system components when contacting Oracle Support Services.
Serial numbers for system components can be determined by using the following procedure:
Each time the system is booted, the serial numbers are written to the /var/log/cellos/validations/SerialNumbers file. This file can be used as a historic record of the serial numbers. The file also contains configuration information for some components.
Parent topic: Maintaining Oracle Exadata System Software
