6.3.4.2 Monitoring Exadata Smart Flash Log Using Database Statistics and Wait Events
The following table describes various database statistics that are useful for
monitoring redo write and Exadata Smart Flash Log
performance. The statistics are available in various dynamic performance views,
including V$SYSSTAT, and may be displayed in the Global Activity
Statistics or Instance Activity Statistics section of an AWR report.
| Statistic | Description |
Number of redo writes where the redo write size is smaller than the
size indicated in parenthesis. For example, |
Total number of writes to the redo log files by the Oracle Database log writer (LGWR) process(es). |
The following table describes database wait events that are useful for
performance. The wait events are visible in various dynamic performance views, including
V$SESSION, V$SYSTEM_EVENT and
V$SESSION_EVENT, and may be displayed in the Wait Event sections of
the AWR report.
| Wait Event | Description |
log file parallel write |
The Oracle Database log writer (LGWR) process waits on this event when it is waiting for the completion of writes to the redo log file. Efficient use of Exadata Smart Flash Log is indicated by comparatively lower time waiting on this event. |
The availability of a specific statistic or wait event is subject to the version of Oracle Database being used.
Parent topic: Monitoring Exadata Smart Flash Log
