6.3.2.2 Monitoring XRMEM Cache Using Database Statistics and Wait Events
The availability of a specific statistic or wait event is subject to the version of Oracle Database being used.
The following table describes database statistics that are useful for
monitoring XRMEM cache. The statistics are available in
various dynamic performance views, including V$SYSSTAT, and may be
displayed in the Global Activity Statistics or Instance Activity Statistics section of
an AWR report.
| Statistic | Description |
cell RDMA reads |
The number of successful XRMEM cache read requests using RDMA |
cell RDMA reads eligible |
The number of database reads that meet basic eligibility criteria for RDMA |
cell RDMA read hash table
probes |
The total number of RDMA hash table probes issued to determine the presence of data in XRMEM cache. Each eligible read is usually associated with a hash table probe. |
cell RDMA reads issued |
The total number of RDMA reads issued to retrieve data from XRMEM cache. An RDMA read is usually issued after each successful hash table probe. |
The total number of RDMA hash table probes that failed. Each statistic covers a specific failure reason. The sum of these failures accounts for most of the difference between
Some RDMA hash table probe failures are normal while XRMEM cache is being initialized. However, frequent failures or a large number of failures may indicate a problem requiring further investigation. |
The total number of RDMA reads that failed. Each statistic covers a specific failure reason. The sum of these failures accounts for most of the difference between
Normally, some RDMA read failures may occur. However, frequent failures or a large number of failures may indicate a problem requiring further investigation. |
cell RDMA reads rejected -
ineligible |
The number of database reads that failed basic eligibility criteria for RDMA |
cell xrmem cache read hits |
The number of non-RDMA read requests processed by
cellsrv resulting in a XRMEM cache hit
The following table describes database wait events that are useful for
monitoring XRMEM cache. The wait events are visible in
various dynamic performance views, including V$SESSION,
V$SYSTEM_EVENT and V$SESSION_EVENT, and may be
displayed in the Wait Event sections of the AWR report.
| Wait Event | Description |
cell list of blocks physical
read |
This wait event occurs during recovery or during buffer pre-fetching (rather than performing multiple single-block reads). It is used to monitor database blocks that must be changed as part of recovery and are read in parallel for the database. In
This wait event is equivalent to |
cell list of blocks read request |
This is a placeholder wait event associated with
cell multiblock physical read |
This wait event represents the time taken to perform all the I/Os for a multi-block database read. In
cell multiblock read request |
cell single block physical read |
single block database I/O, equivalent to This wait event does not include I/O from Exadata Smart Flash Cache, I/O from XRMEM cache, or database I/O using a Remote Direct Memory Access (RDMA) read. In
cell single block physical read:
RDMA |
This wait event represents the time taken to perform a single block database I/O using a Remote Direct Memory Access (RDMA) read. In
This wait event was introduced in the May 2022 Oracle
Database release updates and is present in Oracle Database versions
19.15.0.0.220419, 21.6.0.0.220419, and later. Previously,
cell single block physical read: xrmem
cache |
This wait event represents the time taken to perform a single block database I/O from XRMEM cache. Effective use of XRMEM cache coincides with extremely low latency for this wait event, which is typical for operations using RDMA. In
cell single block read request |
This is a placeholder wait event associated with a single
block database I/O that is visible only during the wait period.
After the wait event ends, the placeholder is converted to the
appropriate wait event, which is typically one of the |
cell interconnect retransmit during physical
read |
This wait event appears during retransmission for an I/O
of a single-block or multiblock read. The cell hash number in the
Parent topic: Monitoring XRMEM Cache
