C.1.4 Using V$ASM_DISK_SPARSE and V$ASM_DISKGROUP_SPARSE to Monitor Sparse Disks
The V$ASM_DISK_SPARSE and V$ASM_DISKGROUP_SPARSE views contain information about sparse disks.
Table C-3 V$ASM_DISK_SPARSE Columns and Descriptions
| Column | Description |
GROUP_NUMBER |
The number of the disk group containing the disk. |
The number assigned to the disk within this disk group. |
The incarnation number for the disk. |
The total used physical and materialized capacity on the disk. |
The total physical capacity on the disk. |
The total number of I/O read requests on non-materialized regions of the disk. |
The total number of bytes read from non-materialized regions of the disk. |
The time taken by sparse read I/O operations. |
Table C-4 V$ASM_DISKGROUP_SPARSE Columns and Descriptions
The cluster-wide number assigned to the disk group. |
The total used physical and materialized capacity of the disk group. |
The total physical capacity of the disk group. |
Parent topic: Oracle Database Dictionary Views
