Running AHFCTL Commands to Manage Cell, Switches, Databases and exacli Passwords
You need root access to ahfctl, or sudo access to run checkpassword, setpassword, and unsetpassword commands.
ahfctl checkpassword
Use the ahfctl checkpassword command to check cell, switches, databases and exacli passwords.
Syntax
[-nodes nodes]
[-dbs databases]
[-user user]
[-exacli]
Parameters
ahfctl checkpassword Command Parameters
| Parameter | Description |
-nodes nodes | Specify a comma-delimited list of nodes. |
-dbs databases | Specify a comma-delimited list of Oracle Databases. |
-user user | Specify a user name for whom you want check the password. |
-exacli | Specify to check exacli user of a cell. |
ahfctl setpassword
Use the ahfctl setpassword command to set cell, switches, databases and exacli passwords.
Syntax
ahfctl setpassword
[-nodes nodes]
[-dbs databases]
[-user user]
[-exacli]
Parameters
ahfctl setpassword Command Parameters
-user user | Specify a user name for whom you want to set password. |
-exacli | Specify to set exacli user of a cell. |
ahfctl unsetpassword
Use the ahfctl unsetpassword command to unset cell, switches, databases and exacli passwords.
Syntax
[-nodes nodes]
[-dbs databases]
[-user user]
[-exacli]
Parameters
-user user | Specify a user name for whom you want to unset the password. |
-exacli | Specify to unset exacli user of a cell. |
