@@@@Platform-“OnPrem”
@@@@Product-“Database”
@@@@ReleaseVersion-“26.11”
@@@@info-map-label-“Oracle Trace File Analyzer Daemon is Not Starting or Not Running?”
Description:
TFA-00001: Failed to start Oracle Trace File Analyzer (TFA) daemon
TFA-00002: Oracle Trace File Analyzer (TFA) is not running
The errors indicate that Java does not start.
Action:
Verify that Oracle Trace File Analyzer is not running.
ps -ef|grep -i tfaNote:
On some operating systems, the
pscommand truncates the output at 80 characters. Thepscommand does not display the process even if it is running. -
To confirm that the Oracle Trace File Analyzer daemon is not running, run the following command run as
root.# tfactl print statusTFA-00002 Oracle Trace File Analyzer (TFA) is not running -
Try starting the Oracle Trace File Analyzer daemon as
root.# tfactl start Starting TFA.. Waiting up to 100 seconds for TFA to be started.. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Successfully started TFA Process.. . . . . . TFA Started and listening for commandsIf Oracle Trace File Analyzer still fails to start, then run
tfactl diagnosetfa -local. Upload the resultant file to Oracle Support.
