@@@@Platform-“OnPrem”
@@@@Product-“Database”
@@@@ReleaseVersion-“26.11”
@@@@info-map-label-“Problems Related to Remote Login”
Action:
If you see messages similar to No such file or directory or /usr/bin/scp -q: No such file or directory, then refer to Remote Login Problems to fix the issues.
