@@@@Platform-“OnPrem”
@@@@Product-“Database”
@@@@ReleaseVersion-“26.11”
@@@@info-map-label-“Running Generic Compliance Framework (Oracle Orachk and Oracle Exachk) Commands”
Review the list of generic Oracle Orachk and Oracle Exachk command options.
Syntax
[-a]
[-v]
[-debug]
[-nodaemon]
[-f]
[-upgrade]
[-noupgrade]
[-testemail all | "NOTIFICATION_EMAIL=comma-delimited list of email addresses"]
[-sendemail "NOTIFICATION_EMAIL=comma-delimited list of email addresses"]
[-dbserial]
[-dbparallel [n]]
[-dbparallelmax]
[-readenvconfig]
Parameters
Generic Commands
-a
Runs all checks, including best practice checks and the recommended patch check. If you do not specify any options, the tools run all checks by default.-v
Shows the version of Oracle Autonomous Health Framework compliance tools.-debug
Runs in debug mode. The generated.zipfile contains a debug log and other files useful for Oracle Support.-nodaemon
Does not send commands to the daemon. Usage is interactive.-f
Runs offline. The tools perform health checks on data already collected from the system.-upgrade
Forces an upgrade of the version of the tools being run.-noupgrade
Use this option when you have the latest version inRAT_UPGRADE_LOCbut do not yet want to upgrade. Specifying-noupgradewithout having the latest version inRAT_UPGRADE_LOCstill prompts you to download the latest version.-testemail all | "NOTIFICATION_EMAIL=comma-delimited list of email addresses"
Sends a test email to validate the email configuration.-sendemail "NOTIFICATION_EMAIL=comma-delimited list of email addresses"
Specify a comma-delimited list of email addresses. Emails the generated HTML report to the specified email addresses when the run completes.-dbserial
Runs theSQL,SQL_COLLECT, andOShealth checks serially.-dbparallel [n]
Runs theSQL,SQL_COLLECT, andOShealth checks in parallel usingnchild processes. The default is 25% of the available CPUs.-dbparallelmax
Runs theSQL,SQL_COLLECT, andOShealth checks in parallel using the maximum number of child processes.-
-readenvconfig
Reads theconf_fileconfiguration file underDATA_DIR/SERVER_NAME/common/config/user_username.You cannot set the
RAT_SSH,RAT_SSHELL, andRAT_SCOPYenvironment variables using the export option. Create the configuration file and add these variables manually.To read the configuration file, run:
./exachk -readenvconfigor:
./orachk -readenvconfig
