Cooling Unit Components
The system has six 60-mm fan modules with two fans in each module. The following table lists the system cooling unit components.
Table E-3 Cooling Unit Components
| Component Name (Oracle ILOM CLI Targets) | IPMI Type | Description | Values (if applicable) |
/SYS/MB/FM[0-5] |
FRU |
Fan module FRU |
/SYS/MB/FM[0-5]/F[0- x ] |
FRU |
Individual fan |
/SYS/MB/FM[0-5] /PRSNT |
Discrete sensor |
Fan module is present. |
01h-ENTITY_ABSENT 02h-ENTITY_PRESENT |
/SYS/MB/FM[0-5] /F[0-x]/TACH |
Threshold sensor |
Fan module fan speed |
RPM |
/SYS/MB/FM[0-5] /SERVICE |
Indicator |
Fan Fault-Service Required LED |
Color: Amber Location: Motherboard Off: Normal On: Fan module was diagnosed as faulty. |
