System Chassis Components
The following table lists the system chassis components.
Table E-1 System Chassis Components
| Component Name (Oracle ILOM CLI Targets) | IPMI Type | Description | Values (if applicable) |
/SYS |
FRU |
Product information only |
/SYS/UUID |
FRU |
Unique system ID |
Derived from host MAC address. Used for PXE boot and licensing. |
/SYS/ACPI |
State sensor |
Advanced Configuration and Power Interface |
01h-ACPI_ON_WORKING 20h-ACPI_SOFT_OFF |
/SYS/VPS |
Threshold sensor |
Virtual power consumption sensor |
Watts |
/SYS/VPS_CPUS |
Threshold sensor |
Virtual power sensor - CPU power consumption |
Watts |
/SYS/VPS_MEMORY |
Threshold sensor |
Virtual power sensor - memory power consumption |
Watts |
/SYS/VPS_FANS |
Threshold sensor |
Virtual power sensor - fan power consumption |
Watts |
/SYS/T_AMB |
Threshold sensor |
Ambient temperature on system motherboard |
Degrees Celsius |
/SYS/TEMP_FAULT |
Indicator |
Temperature Fault LED |
Color: Amber Location: Front panel Off: Normal On: Chassis overtemp fault |
/SYS/OK |
Indicator |
System OK LED |
Color: Green Location: Front and back panels Off: Power is off. Standby blink: Host is off, awaiting Power On. Slow blink: Startup sequence initiated on host. On: Host is booting OS or running the OS. |
/SYS/SERVICE |
Indicator |
Fault-Service Required LED |
Color: Amber Location: Front and back panels Off: Normal On: Server requires service. |
/SYS/LOCATE |
Indicator |
Locate Button/LED |
Color: White Location: Front and back panels Off: Normal Fast blink: Locate function is activated; self-extinguishes after 30 minutes. |
/SYS/PS_FAULT |
Indicator |
Rear Power Supply Fault LED |
Color: Amber Location: Front panel Off: Normal On: General power supply fault |
/SYS/FAN_FAULT |
Indicator |
Top Fan Fault LED |
Color: Amber Location: Front panel Off: Normal On: General fan fault |
/SYS/DO_NOT_SERVICE |
Indicator |
Do Not Service LED Color: White Location: Front panel Off: Normal On: Do not service this cell |
