Prerequisites for Running the rastat Utility
Before you run the rastat utility, ensure that the following requirements are met:
The platform on which you will be running rastat is either Linux or Unix.
If you will be running the utility from a protected database, copy the
rastat.pl
file from the/opt/oracle.RecoveryAppliance/client/
directory of a Recovery Appliance compute server to the protected database. -
Complete the steps to enroll the protected database with the Recovery Appliance as described in "Enrolling Protected Databases".
Ensure that the
$ORACLE_HOME
and$ORACLE_SID
environment variables are configured if you do not plan to set them by using the applicable options when you run the utility.
