Enabling Network Connectivity Using the Diagnostics ISO
You might need to use the diagnostics ISO to access a storage server that fails to restart normally. After starting the server, you can copy files from the ISO to the server, replacing the corrupt files.
The ISO is located on all Recovery Appliance servers at /opt/oracle.SupportTools/diagnostics.iso
Caution:
Use the diagnostics ISO only after other restart methods, such as using the USB drive, have failed. Contact Oracle Support for advise and guidance before starting this procedure.
To use the diagnostics ISO:
