Low-Voltage 15 kVA Three Phase PDU for North America, South America, Japan and Taiwan
Note: The following specifications are for a single PDU. Every ZDLRA Rack configuration contains two PDUs.
Table 2-7 Specifications for each Low-Voltage 15 kVA Three Phase PDU for North America, South America, Japan and Taiwan
| Specification | Value |
| Number of Inputs | 1 |
| Source Voltage | 200-220V |
| Frequency | 50/60 Hz |
| Max Line Current | 40A |
| Phase Current | 23A |
| Nominal Power Rating | 15kVA |
| Recommended Circuit Breaker | 50A |
| Outlets | 42 x C13, 6 x C19 |
| Outlet Groups | 6 |
| Max Group Current | 20A |
| Output Voltage | 200-240V |
| Data Center Receptacle | 3ph 3W + ground 60A IEC60309 |
