Rescuing a Server Using the CELLBOOT USB Flash Drive
Caution:
Follow the rescue procedure with care to avoid data loss.
To rescue a server using the CELLBOOT USB flash drive:
Additional options might be available that allow you to enter a rescue mode Linux login shell with limited functionality. Then you can log in to the shell as the root
user with the password supplied by Oracle Support Services, and manually run additional diagnostics and repairs on the server. For complete details, contact your Oracle Support Services representative.
