Running the Recovery Appliance Backup Module Installer
Install the Recovery Appliance backup module in the host file system of the protected database. Since the Recovery Appliance backup module is a shared library, it must be installed into a location within the shared library search path that is visible to every protected database instance. For example, $ORACLE_HOME/lib is the default location for shared libraries for the Oracle database.
The Recovery Appliance backup module location is used with the SBT_LIBRARY parameter in the ALLOCATE CHANNEL or CONFIGURE CHANNEL commands.
To run the Recovery Appliance backup module installer:
See Also:
"Creating an Oracle Wallet on the Protected Database" for steps to manually create an Oracle wallet
"Using RMAN Channels for Recovery Appliance Backup and Recovery Operations"
