AC Power
The auto-sensing AC power supply is rated at 110-240 VAC, 50-60 Hz, and is supplied with an IEC connector. The handle on the front panel of the power supply is used to remove the power supply from the chassis. The black locking tab, when moved from left to right, unlocks the power supply from the chassis when removing the power supply.
AC Power Cords
Oracle ships one region-specific power cord with each AC-power supply.
