Cleaning the Cooling Components
To clean the Fan module:
- Clean the fan module.
- Remove the fan from the chassis.
- Spray compressed air into the fan to dislodge and blow away contaminants.
- Replace the fan.
- Clean the air inlets.
- Clean the air filters.
- Remove the air filter.
- Either spray compressed air through the air filter, or use a vacuum, or rinse it under water and let it dry.
- Re-install the air filter.
