H/S LED
The blue H/S LED indicates whether the Option Card is seated properly.
H/S LED
Possible states of the H/S LED include:
on/blinking — indicates that the Option Card is not seated properly. When this occurs, ensure that you remove power to the platform and attempt to properly lock the Option Card to the chassis. Then apply power to the chassis. If the H/S LED is no longer lit, proceed with normal operations.
off — when the PWR LED is on, this indicates that the Option Card is seated properly in the chassis.
