Installation Tools and Parts
The following tools and parts are required to install the Acme Packet 6400 into your equipment rack:
  • #2 Phillips-head screwdriver
  • Rack and associated mounting hardware
  • Shielded Ethernet CAT5e or CAT6 RJ45 cables
  • 11/32" nut driver
  • T15 Torx tip screwdriver
  • T25 Torx tip screwdriver
  • 8mm nut driver
Keep the two Torx tip screwdrivers for later maintanence. The T15 Torx is used for openning the cover and replacing the FIM. The T25 Torx is used for removing the main board.
