Power Guidelines
When preparing to install your Acme Packet 6400:
  • Ensure that the installation location has access to adequate power and grounding. Separate circuits should be available for each of the two Acme Packet 6400 power supplies.
  • Never use extension cords when powering an Acme Packet 6400.
  • Use grounded, 3-conductor circuits.
  • A local earth ground must be available.
  • A service disconnect must be provided for each power supply that is clearly marked and is nearby the equipment.
