1 Introduction to the Order Control Application
The Oracle Communications ASAP Order Control Application (OCA) is a Java-based GUI that communicates with the OCA Service Request Processor (SRP) server. OCA is commonly used to perform fallout management; however, you can also use it to perform ASAP work order queries and submit new ASAP work orders.
The OCA is available as a stand-alone application or an applet that can be run in a browser and embedded in an HTML web page.
For information on installation and configuration, contact your system administrator or refer to ASAP Installation Guide.
You can extend the functionality contained in the ASAP OCA client to support your business requirements.
To start OCA as an applet:
Open a web browser and enter the following:
http://hostname:port/Environment_ID/OCA
where:
hostname is the name of the server where Oracle WebLogic Server is running for ASAP.
port is the port number where Oracle WebLogic Server is running for ASAP.
Environment_ID is the ASAP environment. An ASAP system can have multiple ASAP instances with multiple environments.
The OCA Web Client Configuration screen appears.
Ordinarily, there will only be one registered server session. In the event that multiple server sessions are available, select the appropriate servers that you want to use, and optionally configure the session parameters. Any given OCA client can have sessions to multiple OCA SRP servers, distributed over one or more ASAP instances.
In the Server Session Configuration section, you can modify the following fields:
Table 1-1 Server Session Configuration Fields
Field Description Idle Timeout
Maximum idle time, in minutes, after which the OCA SRP server terminates the OCA client connection. Set to 0 to disable this feature.
Events Supported
The flag should be set to false when connecting to servers on the HP10.20 platform. Events are not supported on this platform.
Max Open Windows
The number of detail windows a user can have open at one time.
Language Code
Language code for the language in which translatable information is returned to and displayed by the client.
If applied, all translatable fields are shown in the OCA client native language, as specified by the LANGUAGE variable.
Default Template
The template (user or global) that will be selected by default in the Order Entry Wizard after OCA client is launched.
Date Format
The date format that will be displayed in the OCA client including in work order headers, the Work Order Query window and its results, the Work Order Release dialog box, audit logs, report generation dialog boxes, and in standard ASAP reports.
Click Launch Selected Server Sessions.
The following security warning appears. This is a MetaSolv-specific digital certificate.
Click Grant this session (this certificate will appear on subsequent accesses) or Grant always if you want to grant this session until the certificate expires and is no longer valid.
The Login dialog box appears.
In the Name field, enter your name.
In the Password field, enter your password.
Click OK, which starts the OCA applet.
OCA Components
The OCA Console window provides access to the following functions:
Provisioning Management
Order Management: Order Management window enables you to:
Predefine order management search criteria.
Set order management search criteria.
Manage order management fallout.
Before starting a search, all search criteria is checked for valid values. If the values are not valid, the search is not initiated.
New Work Order: You create and submit new work orders to the ASAP system using the New Work Order window. In addition to work order header information (work order ID, date, priority and operation), this dialog box includes the following tabs:
CSDL Information: You can add, update, and delete Common Service Description Layers (CSDLs). When you update a CSDL, you must add the required CSDL parameters.
Work Order Details: You can specify more information for the work order, including rollback if the work order fails, Atomic Service Description Layer (ASDL) retries, external system ID, among others.
Global Parameters: You can add and delete global work order parameters.
User Work Order Properties: You can define work order properties specific to the work order.
Order Entry Wizard: The Order Entry Wizard guides you through the entry of required CSDL and global work order parameters based on predefined templates.
Audit Log: You can view a log of work order events using the Audit Log. The Audit Log window displays all user-generated changes to work orders, as well as system-generated events.
Events
Work orders can fail due to a number of factors. Failed work orders must be analyzed to determine the cause of the failure.
The Events function of the OCA contains:
Events Management: Through the Event Management dialog box, you can subscribe or unsubscribe to work order notifications based on event type. You can subscribe to multiple event types.
Events Message Board: Through the Event Message Board window, you can track the progress of a work order through the ASAP system without having to poll ASAP for results. The Events Message Board displays work order events occurring on the ASAP system according to the criteria defined in the Event Management dialog box. After the work order is submitted, the events appear on the Events Message Board as it is provisioned in ASAP.
Changing Your Password
Your system administrator uses the WebLogic Server Administration Console to manage user and group security.
ASAP Administrators can set password policies and can change user passwords at any time using the Change Password Utility Java Server Page (JSP), provided that the system uses the WebLogic Server as the user security repository. For more information, refer to the "Configuring the WebLogic Server Change Password Utility Page" section in ASAP System Administrator's Guide.
To change your password:
In the OCA Console, select Security, then select Change Password.
The Change Password dialog box appears.
In the Old Password field, enter your current password.
In the New Password field, enter your new password.
In the Confirm Password field, enter your new password again.
Click OK.
A confirmation message appears.
Changing the Date or Time Format
You can select either the MM/dd/yyyy or dd/MM/yyyy date format.
The date format affects the way date values are entered and displayed in the OCA client including in work order headers, the Work Order Query window and its results, the Work Order Release dialog box, audit logs, report generation dialog boxes, and in standard ASAP reports.
Changes to the time format apply to the Calendar tool use (for time range selection in the Work Order Query, Audit Log, and New Work Order windows).
To change the date or time formats:
In the OCA Console, from the File menu, select Date Format and the appropriate date format option.
In the OCA Console, from the File menu, select Time Format and the appropriate time format option.
Select AM_PM TIMEZONE if you want times specified using a 12-hour clock with an AM or PM designation. Select TIMEZONE if you want time specified using a 24-hour clock.
Setting the Default Date Format
You can set the date format for the OCA web client application in the OCA Web Client Configuration screen.
To set the date format:
Open a web browser and type:
http://Weblogic_host:Weblogic_port/ASAP_envID/OCA
For example: http://10.15.15.15:7001/AS47/OCA
Weblogic_host is the WebLogic host on which ASAP is deployed and Weblogic_port is the WebLogic port.
ASAP_envID is the ASAP environment ID. An ASAP system can have multiple ASAP instances with multiple environments.
Select the required date format from the Date Format drop-down list.
The new date format is applied.
The default selected date format in the OCA Web Client Configuration screen is dd/MM/yyyy. If you want to change the default value to MM/dd/yyyy, modify the oca.jsp file in asap<ENV_ID>.ear.
To modify the oca.jsp file:
Shut down the WebLogic Server.
Take a backup of asap<ENV_ID>.ear in the Weblogic domain directory.
Extract ocac.war from the EAR file by running the following command:
jar xvf asap<ENV_ID>.ear ocac.war
Extract oca.jsp from the ocac.war file by running the following command:
jar xvf ocac.war oca.jsp
Modify the oca.jsp file as follows:
<SELECT NAME="DATE_FORMAT" LENGTH="10"> <OPTION VALUE="dd/MM/yyyy">dd/MM/yyyy</OPTION> <OPTION VALUE="MM/dd/yyyy" SELECTED>MM/dd/yyyy</OPTION> </SELECT>
Update the ocac.war file with the modified oca.jsp.
jar uvf ocac.war oca.jsp
Update the EAR file with the modified ocac.war file.
jar uvf asap<ENV_ID>.ear ocac.war
Run the following command to remove the old files:
rm oca.jsp ocac.war
- Restart the WebLogic Server.
