Converged Charging Notification
post
{apiRoot}/nchf-convergedcharging/v3/{$request.body#/notifyUri}
Notifies the NF that one of the following is required:
- Reauthorization
- Ending the authorization
Request
Path Parameters
$request.body#/notifyUri(required): string
The notification URI (notifyUri field) provided in the Create a Converged Charging Session request body.
Supported Media Types
- application/json
Root Schema : schema
Type:
objectA notification request.
Show Source
notificationType(required): string
Allowed Values:
[ "REAUTHORIZATION", "ABORT_CHARGING" ]The reason for the notification:- REAUTHORIZATION: Reauthorization is required
- ABORT_CHARGING: Ending authorization is required
reauthorizationDetails: array
Minimum Number of Items:
0Reauthorization data that specifies the quota or usage reporting to update.
Response
- application/problem+json
204 Response
The charging notification was created successfully.
400 Response
The request isn't valid.
Root Schema : ProblemDetails
Type:
objectProvides additional information in an error response.
Show Source
accessTokenError: object
AccessTokenErr
Indicates error returned in the access token response message.
accessTokenRequest: object
AccessTokenReq
Contains information related to the access token request.
cause: string
A machine-readable application error cause specific to this occurrence of the problem. This IE should be present and provide application-related error information, if available.
detail: string
A human-readable explanation specific to this occurrence of the problem.
instance: string
Refers to a string providing an URI formatted according to RFC 3986.
invalidParams: array
invalidParams
1 -
nrfId: string
Minimum Length:
4Maximum Length:253Pattern:^([0-9A-Za-z]([-0-9A-Za-z]{0,61}[0-9A-Za-z])?\.)+[A-Za-z]{2,63}\.?$A Fully Qualified Domain Name. -
status: integer
supportedFeatures: string
Pattern:
^[A-Fa-f0-9]*$This string indicates the features supported by an API, as defined in clause 6.6 of 3GPP TS 29.500. It is a hexadecimal representation of a bitmask, where each character represents the support of 4 features as described in table 5.2.2-3. The string is ordered with the most significant character, representing the highest-numbered features, appearing first. The character representing features 1 to 4 appears last. The list of features and their numbering (starting with 1) are defined separately for each API. If the string's length is less than the total number of features defined for an API, all features corresponding to missing characters are considered unsupported. -
title: string
type: string
Nested Schema : AccessTokenErr
Type:
objectIndicates error returned in the access token response message.
Show Source
error(required): string
Allowed Values:
[ "invalid_request", "invalid_client", "invalid_grant", "unauthorized_client", "unsupported_grant_type", "invalid_scope" ] -
error_description: string
error_uri: string
Nested Schema : AccessTokenReq
Type:
objectContains information related to the access token request.
Show Source
grant_type(required): string
Allowed Values:
[ "client_credentials" ] -
hnrfAccessTokenUri: string
nfInstanceId(required): string
(uuid)
Indicates a string uniquely identifying a NF instance. The format of the NF Instance ID must be a Universally Unique Identifier (UUID) version 4, as described in IETF RFC 4122.
nfType: string
Allowed Values:
[ "NRF", "UDM", "AMF", "SMF", "AUSF", "NEF", "PCF", "SMSF", "NSSF", "UDR", "LMF", "GMLC", "5G_EIR", "SEPP", "UPF", "N3IWF", "AF", "UDSF", "BSF", "CHF", "NWDAF", "PCSCF", "CBCF", "HSS", "UCMF", "SOR_AF", "SPAF", "MME", "SCSAS", "SCEF", "SCP", "NSSAAF", "ICSCF", "SCSCF", "DRA", "IMS_AS", "AANF", "5G_DDNMF", "NSACF", "MFAF", "EASDF", "DCCF", "MB_SMF", "TSCTSF", "ADRF", "GBA_BSF", "CEF", "MB_UPF", "NSWOF", "PKMF", "MNPF", "SMS_GMSC", "SMS_IWMSC", "MBSF", "MBSTF", "PANF", "IP_SM_GW", "SMS_ROUTER" ]Indicates NF types known to NRF. -
requesterFqdn: string
Minimum Length:
requesterPlmn: object
PlmnId
When converted to a string, for example, when used in maps as key, PlmnId is represented as three digits "mcc" followed by "-" and two or three digits "mnc".
requesterPlmnList: array
requesterPlmnList
2 -
requesterSnpnList: array
requesterSnpnList
1 -
requesterSnssaiList: array
requesterSnssaiList
1 -
scope(required): string
Pattern:
^([a-zA-Z0-9_:-]+)( [a-zA-Z0-9_:-]+)*$ -
sourceNfInstanceId: string
(uuid)
targetNfInstanceId: string
(uuid)
targetNfServiceSetId: string
Indicates the NF Service Set Identifier (see clause 28.12 of 3GPP TS 23.003) formatted as the following string "set
.sn .nfi .5gc.mnc .mcc ", or encoded as defined in clause 5.4.2 ("Mcc" data type definition) encoding the Mobile Network Code part of the PLMN, comprising 3 digits. If there are only 2 significant digits in the MNC, one "0" digit must be inserted at the left side to fill the 3 digits coding of MNC. Pattern: '^[0-9]{3}$' encoded as defined in clause 5.4.2 ("Nid" data type definition) encoded as defined in clause 5.3.2 encoded as defined in 3GPP TS 29.510 encoded as a string of characters consisting of alphabetic characters (A-Z and a-z), digits (0-9) and/or the hyphen (-) and that must end with either an alphabetic character or a digit. -
targetNfSetId: string
Indicates the NF Set Identifier (see clause 28.12 of 3GPP TS 23.003), formatted as the following string "set
. set.5gc.mnc .mcc ", or "set . set.5gc.nid .mnc .mcc " with encoded as defined in clause 5.4.2 ("Mcc" data type definition) encoding the Mobile Network Code part of the PLMN, comprising 3 digits. If there are only 2 significant digits in the MNC, one "0" digit must be inserted at the left side to fill the 3 digits coding of MNC. Pattern: '^[0-9]{3}$' encoded as a value defined in Table 6.1.6.3.3-1 of 3GPP TS 29.510 but with lower case characters encoded as a string of characters consisting of alphabetic characters (A-Z and a-z), digits (0-9) and/or the hyphen (-) and that must end with either an alphabetic character or a digit. -
targetNfType: string
Allowed Values:
targetNsiList: array
targetNsiList
1 -
targetPlmn: object
PlmnId
targetSnpn: object
PlmnIdNid
Contains the serving core network operator PLMN ID and, for an SNPN, the NID that together with the PLMN ID identifies the SNPN.
targetSnssaiList: array
targetSnssaiList
1
Nested Schema : invalidParams
Type:
arrayMinimum Number of Items:
Show Source
1-
Array of:
object InvalidParam
Contains an invalid parameter and a related description.
Nested Schema : PlmnId
Type:
objectWhen converted to a string, for example, when used in maps as key, PlmnId is represented as three digits "mcc" followed by "-" and two or three digits "mnc".
Show Source
mcc(required): string
Pattern:
^\d{3}$Indicates the Mobile Country Code part of the PLMN, comprising 3 digits, as defined in clause 9.3.3.5 of 3GPP TS 38.413. -
mnc(required): string
Pattern:
^\d{2,3}$Indicates the Mobile Network Code part of the PLMN, comprising 2 or 3 digits, as defined in clause 9.3.3.5 of 3GPP TS 38.413.
Nested Schema : requesterPlmnList
Type:
Show Source
2-
Array of:
object PlmnId
Nested Schema : requesterSnpnList
Type:
Show Source
1-
Array of:
object PlmnIdNid
Nested Schema : requesterSnssaiList
Type:
Show Source
1-
Array of:
object Snssai
When converted to a string, for example, when used in maps as key, Snssai is represented as one to three digits "sst" optionally followed by a hyphen "-" and 6 hexadecimal digits "sd".
Nested Schema : PlmnIdNid
Type:
objectContains the serving core network operator PLMN ID and, for an SNPN, the NID that together with the PLMN ID identifies the SNPN.
Show Source
Pattern:
Pattern:
^\d{2,3}$Indicates the Mobile Network Code part of the PLMN, comprising 2 or 3 digits, as defined in clause 9.3.3.5 of 3GPP TS 38.413. -
nid: string
Pattern:
^[A-Fa-f0-9]{11}$This represents the Network Identifier, which together with a PLMN ID is used to identify an SNPN (see 3GPP TS 23.003 and 3GPP TS 23.501 clause 5.30.2.1).
Nested Schema : targetSnssaiList
Type:
Show Source
1-
Array of:
object Snssai
Nested Schema : Snssai
Type:
objectWhen converted to a string, for example, when used in maps as key, Snssai is represented as one to three digits "sst" optionally followed by a hyphen "-" and 6 hexadecimal digits "sd".
Show Source
sd: string
Pattern:
^[A-Fa-f0-9]{6}$A 3-octet string representing the Slice Differentiator (SD) in hexadecimal format. Each character takes a value from "0" to "9", "a" to "f" or "A" to "F", representing 4 bits. The most significant bits are represented by the first character, and the least significant bits by the last. This is an optional parameter used to differentiate between multiple Network Slices of the same Slice/Service type. This IE must be absent if no SD value is associated with the SST. -
sst(required): integer
Minimum Value:
0Maximum Value:255Indicates an Unsigned integer, within the range 0 to 255, representing the Slice/Service Type. It indicates the expected Network Slice behaviour in terms of features and services. Values 0 to 127 correspond to the standardized SST range. Values 128 to 255 correspond to the Operator-specific range. See clause 28.4.2 of 3GPP TS 23.003. Standardized values are defined in clause 5.15.2.2 of 3GPP TS 23.501.
Nested Schema : InvalidParam
Type:
objectContains an invalid parameter and a related description.
Show Source
param(required): string
If the invalid parameter is an attribute within a JSON body, the "invalidParameter" IE must be encoded as a JSON Pointer. For invalid HTTP headers, the IE must be formatted as "header " concatenated with the header name. For invalid query parameters, it must be formatted as "query " concatenated with the query parameter name. For invalid variable path segments, the IE must contain the variable name within curly braces ("{}"), as defined in the OpenAPI specification.
reason: string
A human-readable reason for the error must be provided, such as "must be a positive integer." In cases involving failed operations in a PATCH request, the reason string should identify the operation that failed using the operation's array index, for example: "Replacement value invalid for attribute (failed operation index= 4)." This helps correlate the invalid parameter with the specific failed operation.
Default Response
Refers to a Generic Error.
