Converged Charging Notification
post
{apiRoot}/nchf-convergedcharging/v3/{$request.body#/notifyUri}
Notifies the NF that one of the following is required:
- Reauthorization
- Ending the authorization
Request
Path Parameters
$request.body#/notifyUri(required): string
The notification URI (notifyUri field) provided in the Create a Converged Charging Session request body.
Supported Media Types
- application/json
Root Schema : schema
Type:
objectA notification request.
Show Source
notificationType(required): string
Allowed Values:
[ "REAUTHORIZATION", "ABORT_CHARGING" ]The reason for the notification:- REAUTHORIZATION: Reauthorization is required
- ABORT_CHARGING: Ending authorization is required
reauthorizationDetails: array
Minimum Number of Items:
0Reauthorization data that specifies the quota or usage reporting to update.
Response
- application/problem+json
204 Response
The charging notification was created successfully.
400 Response
The request isn't valid.
Root Schema : ProblemDetails
Type:
objectProvides additional information in an error response.
Show Source
accessTokenError: object
AccessTokenErr
Error returned in the access token response message.
accessTokenRequest: object
AccessTokenReq
Contains information related to an access token request.
cause: string
A machine-readable application error cause specific to this occurrence of the problem. This IE should be present and provide application-related error information if available.
detail: string
A human-readable explanation specific to this occurrence of the problem.
instance: string
String providing a URI formatted according to RFC 3986.
invalidParams: array
invalidParams
1 -
nrfId: string
Minimum Length:
4Maximum Length:253Pattern:^([0-9A-Za-z]([-0-9A-Za-z]{0,61}[0-9A-Za-z])?\.)+[A-Za-z]{2,63}\.?$Fully Qualified Domain Name. -
status: integer
supportedFeatures: string
Pattern:
^[A-Fa-f0-9]*$A string indicating the features supported by an API, as defined in clause 6.6 in 3GPP TS 29.500. The string should contain a bitmask indicating supported features in hexadecimal representation. Each character in the string takes a value between "0" to "9", "a" to "f" or "A" to "F" and represents the support of 4 features, as described in table 5.2.2-3. The most significant character, representing the highest-numbered features, appears first in the string, and the character representing features 1 to 4 appear last in the string. The list of features and their numbering (starting from 1) is defined separately for each API. If the string contains fewer number of characters than the total number of defined features for an API, all features that are represented by characters missing in the string are not supported. -
title: string
type: string
Nested Schema : AccessTokenErr
Type:
objectError returned in the access token response message.
Show Source
error(required): string
Allowed Values:
[ "invalid_request", "invalid_client", "invalid_grant", "unauthorized_client", "unsupported_grant_type", "invalid_scope" ] -
error_description: string
error_uri: string
Nested Schema : AccessTokenReq
Type:
objectContains information related to an access token request.
Show Source
grant_type(required): string
Allowed Values:
[ "client_credentials" ] -
hnrfAccessTokenUri: string
nfInstanceId(required): string
(uuid)
String uniquely identifying an NF instance. The format of the NF Instance ID should be a Universally Unique Identifier (UUID) version 4, as described in IETF RFC 4122.
nfType: string
Allowed Values:
[ "NRF", "UDM", "AMF", "SMF", "AUSF", "NEF", "PCF", "SMSF", "NSSF", "UDR", "LMF", "GMLC", "5G_EIR", "SEPP", "UPF", "N3IWF", "AF", "UDSF", "BSF", "CHF", "NWDAF", "PCSCF", "CBCF", "HSS", "UCMF", "SOR_AF", "SPAF", "MME", "SCSAS", "SCEF", "SCP", "NSSAAF", "ICSCF", "SCSCF", "DRA", "IMS_AS", "AANF", "5G_DDNMF", "NSACF", "MFAF", "EASDF", "DCCF", "MB_SMF", "TSCTSF", "ADRF", "GBA_BSF", "CEF", "MB_UPF", "NSWOF", "PKMF", "MNPF", "SMS_GMSC", "SMS_IWMSC", "MBSF", "MBSTF", "PANF", "IP_SM_GW", "SMS_ROUTER" ]NF types known to NRF. -
requesterFqdn: string
Minimum Length:
requesterPlmn: object
PlmnId
When PlmnId needs to be converted to string (e.g. when used in maps as key), the string should be composed of three digit "mcc" followed by "-" and two or three digit "mnc".
requesterPlmnList: array
requesterPlmnList
2 -
requesterSnpnList: array
requesterSnpnList
1 -
requesterSnssaiList: array
requesterSnssaiList
1 -
scope(required): string
Pattern:
^([a-zA-Z0-9_:-]+)( [a-zA-Z0-9_:-]+)*$ -
sourceNfInstanceId: string
(uuid)
targetNfInstanceId: string
(uuid)
targetNfServiceSetId: string
NF Service Set Identifier (see clause 28.12 of 3GPP TS 23.003) formatted as the following string "set
.sn .nfi .5gc.mnc .mcc ", or encoded as defined in clause 5.4.2 ("Mcc" data type definition) encoding the Mobile Network Code part of the PLMN, comprising 3 digits. If there are only 2 significant digits in the MNC, one "0" digit should be inserted at the left side to fill the 3 digit coding of MNC. Pattern: '^[0-9]{3}$' encoded as defined in clause 5.4.2 ("Nid" data type definition). encoded as defined in clause 5.3.2. encoded as defined in 3GPP TS 29.510. encoded as a string of characters consisting of alphabetic characters (A-Z and a-z), digits (0-9), and/or the hyphen (-) and that should end with either an alphabetic character or a digit. -
targetNfSetId: string
NF Set Identifier (see clause 28.12 of 3GPP TS 23.003), formatted as the following string "set
. set.5gc.mnc .mcc ", or "set . set.5gc.nid .mnc .mcc " with encoded as defined in clause 5.4.2 ("Mcc" data type definition) encoding the Mobile Network Code part of the PLMN, comprising 3 digits. If there are only 2 significant digits in the MNC, one "0" digit should be inserted at the left side to fill the 3 digit coding of MNC. Pattern: '^[0-9]{3}$' encoded as a value defined in Table 6.1.6.3.3-1 of 3GPP TS 29.510 but with lower case characters encoded as a string of characters consisting of alphabetic characters (A-Z and a-z), digits (0-9), and/or the hyphen (-) and that should end with either an alphabetic character or a digit. -
targetNfType: string
Allowed Values:
targetNsiList: array
targetNsiList
1 -
targetPlmn: object
PlmnId
targetSnpn: object
PlmnIdNid
Contains the serving core network operator PLMN ID. For an SNPN, the NID together with the PLMN ID identifies the SNPN.
targetSnssaiList: array
targetSnssaiList
1
Nested Schema : invalidParams
Type:
arrayMinimum Number of Items:
Show Source
1-
Array of:
object InvalidParam
It contains an invalid parameter and a related description.
Nested Schema : PlmnId
Type:
objectWhen PlmnId needs to be converted to string (e.g. when used in maps as key), the string should be composed of three digit "mcc" followed by "-" and two or three digit "mnc".
Show Source
mcc(required): string
Pattern:
^\d{3}$Mobile Country Code is a part of the PLMN, comprising 3 digits, as defined in clause 9.3.3.5 of 3GPP TS 38.413. -
mnc(required): string
Pattern:
^\d{2,3}$Mobile Network Code is a part of the PLMN, comprising 2 or 3 digits, as defined in clause 9.3.3.5 of 3GPP TS 38.413.
Nested Schema : requesterPlmnList
Type:
Show Source
2-
Array of:
object PlmnId
Nested Schema : requesterSnpnList
Type:
Show Source
1-
Array of:
object PlmnIdNid
Nested Schema : requesterSnssaiList
Type:
Show Source
1-
Array of:
object Snssai
When Snssai needs to be converted to string (e.g. when used in maps as key), the string should be composed of one to three digit "sst" optionally followed by "-" and 6 hexadecimal digit "sd".
Nested Schema : PlmnIdNid
Type:
objectContains the serving core network operator PLMN ID. For an SNPN, the NID together with the PLMN ID identifies the SNPN.
Show Source
Pattern:
Pattern:
^\d{2,3}$Mobile Network Code is a part of the PLMN, comprising 2 or 3 digits, as defined in clause 9.3.3.5 of 3GPP TS 38.413. -
nid: string
Pattern:
^[A-Fa-f0-9]{11}$This represents the Network Identifier, which together with a PLMN ID is used to identify an SNPN (see 3GPP TS 23.003 and 3GPP TS 23.501 clause 5.30.2.1).
Nested Schema : targetSnssaiList
Type:
Show Source
1-
Array of:
object Snssai
Nested Schema : Snssai
Type:
objectWhen Snssai needs to be converted to string (e.g. when used in maps as key), the string should be composed of one to three digit "sst" optionally followed by "-" and 6 hexadecimal digit "sd".
Show Source
sd: string
Pattern:
^[A-Fa-f0-9]{6}$3-octet string representing the Slice Differentiator in hexadecimal format. Each character in the string should take a value from "0" to "9", from "a" to "f", or from "A" to "F" and should represent 4 bits. The most significant character representing the 4 most significant bits of the SD should appear first in the string, and the character representing the 4 least significant bit of the SD shall appear last in the string. This is an optional parameter that complements the Slice/Service type(s) to allow to differentiate amongst multiple Network Slices of the same Slice/Service type. This IE should be absent if no SD value is associated with the SST. -
sst(required): integer
Minimum Value:
0Maximum Value:255Unsigned integer, within the range 0 to 255, representing the Slice/Service Type. It indicates the expected Network Slice behaviour in terms of features and services. Values from 0 to 127 correspond to the standardized SST range and values from 128 to 255 correspond to the Operator-specific range. See clause 28.4.2 of 3GPP TS 23.003. Standardized values are defined in clause 5.15.2.2 of 3GPP TS 23.501.
Nested Schema : InvalidParam
Type:
objectIt contains an invalid parameter and a related description.
Show Source
param(required): string
If the invalid parameter is an attribute in a JSON body, this IE should contain the attribute's name and be encoded as a JSON Pointer. If the invalid parameter is an HTTP header, this IE should be formatted as the concatenation of the string "header" plus the header name. If the invalid parameter is a query parameter, this IE should be formatted as the concatenation of the string "query " plus the query parameter name. If the invalid parameter is a variable part of a resource URI path, this IE should contain the variable name, including the "{" and "}" symbols used in the OpenAPI specification to represent variable path segments.
reason: string
A human-readable reason, for example, "must be a positive integer". In cases involving failed operations in a PATCH request, the reason string should identify the failed operation that using the operation's array index to help correlate the invalid parameter with the failed operation, for example, " Replacement value invalid for attribute (failed operation index= 4)."
Default Response
Generic Error
