4 Configuring Provisioning Gateway using CNC Console
This section describes how to configure parameters on Oracle Communications Cloud Native Core, Provisioning Gateway Guide using CNC Console.
4.1 Logging into CNC Console
After logging successfully into the CNC Console application, you can use Provisioning Gateway integrated with CNC Console. To log in successfully into the CNC Console, edit the hosts file available at the C:\Windows\System32\drivers\etc location.
  1. In the Windows system, open the hosts file in the notepad as an Administrator and append the following set of lines at the end:
    <CNCC Node IP> cncc-iam-ingress-gateway.cncc.svc.cluster.local
    <CNCC Node IP> cncc-core-ingress-gateway.cncc.svc.cluster.local
    Example:
    10.75.212.88 cncc-iam-ingress-gateway.cncc.svc.cluster.local
    10.75.212.88 cncc-core-ingress-gateway.cncc.svc.cluster.local
    The IP Address in the above lines may change when deployment cluster changes.
  2. Save and close the notepad.
    Before logging to CNC Console, it is important to create a CNC user. Using this user details, you can log in to the CNC Console application. For information on creating a CNC Console user, see Oracle Communications Cloud Native Configuration Console (CNC Console) User Guide.
CNC Console Log in
Following is the procedure to log in to CNC Console:
  1. Open any browser.
  2. Enter the URL http://<host name>:<port number>. where, host name is cncc-iam-ingress-ip and port number is cncc-iam-ingressport and press Enter. The following screen appears:
    Figure 4-1 CNC Console Login Page
  3. Enter the Username and Password and click Log In. The CNC Console Home page appears from where a user can select different instances in the drop down, for example, Provisioning Gateway SLF, or the Provisioning Gateway UDR instance.
    Figure 4-2 CNC Console Home Page
    Provisioning Gateway in UDR mode, the users can configure following services:
    • Configuration Export & Import
    • Global Configurations
    • Subscriber Entity Configuration (SEC)
    • Logging Level
    • Service Configurations
    Provisioning Gateway in SLF mode, the users can configure following services:
    • Logging Level
    • Auditor Service Status
  4. Select the service to be used from the left navigation pane:
    Figure 4-3 CNC Console Home Page with Services
    The same NF services appear in the left navigation pane for SLF instance excluding Subscriber Entity Configuration (SEC).
4.2 Configuration Export & Import
This section describes how to perform bulk export and bulk import of the Provisioning Gateway configuration data using CNC Console.
In the CNC Console application, click PROVGW and then Configuration Export & Import. The Configuration Export & Import page appears.
Figure 4-4 Configuration Export and Import
The Configuration Export & Import page has two tabs: Export (default) and Import. This page allows you to:
  • Export the configuration data.
  • Download the exported data.
  • Import the data (zip file) that you have exported earlier.
  • Generate report to view details of successful and failed configurations.
Exporting Configuration Data
To export the configuration data:
  1. Click the Bulk Export button in the Export tab. The Objects to be Exported dialog box appears.
    Figure 4-5 Objects to be Exported Dialog Box
  2. Select the objects that you want to export. Click the Selection button to either 'Select All' or 'Deselect All' the objects.
  3. Click Export to export the selected objects data. The data in the Configuration Export & Import page is updated.
  4. Click Cancel to exit the dialog box.
Downloading Exported Configuration Data
To download the exported configuration data:
  1. Click the Export Configuration Download icon available under the Actions column of the Export tab.
  2. The "Export Data downloaded Successfully" message appears and the zip file of the exported data is saved to your system. For example: exportedFiles_1.12.41_20210807133529.zip
Downloading Exported Configuration Data Report
To download the exported configuration data report:
  1. Click the Export Report Download icon available under the Actions column of the Export tab.
  2. The "Export status report downloaded successfully" message appears and the export report in the .txt file format is saved to your system. For example: exportReport_1.12.41_20210807134056.txt
Importing Configuration Data
To import the configuration data:
  1. Navigate to the Import tab. The Configuration Export & Import page appears as follows:
    Figure 4-6 Importing Configuration Data
  2. Click the Import button. The Import Data dialog box appears.
    Figure 4-7 Import Data Dialog Box
  3. Select the file that has configuration data and click Import.
    You can only import the configuration data that you had exported earlier.
  4. The data in the Configuration Export & Import page is updated.
  5. Click Cancel to exit the dialog box.
Downloading Imported Configuration Data Report
To download the imported configuration data report:
  1. Click the Import Report Download icon available under Actions column of the Import tab.
  2. The "Import status report downloaded successfully" message appears and the import report in the .txt file format is saved to your system. For example: importReport_1.12.41_20210807134056.txt
4.3 Global Configurations
To access the Global Configurations page, click PROVGW and then, Global Configurations in the left navigation pane of the CNC Console application. The following page appears:
Figure 4-8 Global Configurations
The Global Configurations page displays the value of some global parameters as follows:
Table 4-1 Global Configurations Parameters
Field Name Default Value Attribute Description
Usage Mode UDR Read-only Displays the name of the usage mode of provisioning gateway. The two usage mode are UDR and SLF.
Outgoing HTTPS false Editable Enables HTTPS while sending requests to UDR.
SLF Segment Details NA Editable It defines the connection details with UDR in SLF mode. Each segment can have multiple FQDNs. But only one FQDN is marked as preferred.
Error Code Profiles NA Editable Its defines the switchover logic from preferred FQDN to non-preferred FQDN in any segment.
These values are extracted from the database and on every Helm upgrade, users need to click the Refresh icon to see the latest values.
4.4 Subscriber Entity Configuration (SEC)
To access the Subscriber Entity Configuration page, click PROVGW and then, Subscriber Entity Configuration in the left navigation pane of the CNC Console application. The following page appears:
Figure 4-9 Subscriber Entity Configuration
The Subscriber Entity Configuration display the below parameter as follow:
Table 4-2 The Subscriber Entity Configuration Parameter
Convert to SEC true Editable
Indicates the flag to enable or disable the SEC validation. The flag can be set to true or false.
When set to true, the SEC validation is case insensitive and the request is converted to the SEC case format.
When set to false, the SEC validation is case sensitive and the request is dropped immediately, if the case does not match.
SEC validation will always be successful.
Editing the Subscriber Entity Configuration (SEC) Details
To edit the custom field in existing subscriber entity such as QuotaEntity. Click Edit. This enables the add, edit and delete options of each subscriber entity.
To edit the subscriber entity:
  1. Click Edit option corresponding to the entity you want to edit. The Edit SEC Entities page appears.
  2. Updated or remove the details as required and click Save.
  3. Click Cancel to access the Subscriber Entity Configuration page.
Figure 4-10 Edit Subscriber Entity
Figure 4-11 Edit SEC Entities
Edit SEC Entities
To add the subscriber entity such as QuotaEntity:
  1. Click Add. The Add SEC Entities page appears.
  2. Fill in the required details and click Save to add the subscriber entity.
  3. Click Cancel to exit the Add SEC Entities dialog box.
Add Sec Entities
To delete the subscriber entity such as QuotaEntity:
  1. Click Delete corresponding to the subscriber entity you want to delete.
  2. A confirmation message appears. Click OK to confirm the deletion of record.
  3. Click Cancel to exit the delete dialog box and access the Subscriber Entity Configuration page.
4.5 Logging Level Configuration
The Logging Level Configuration page allows its operators to view and edit the log level details at the application log level and package log level for each service. To access the Logging Level Configuration page, click PROVGW and then Logging Level in the left navigation pane of the CNC Console application.
The Logging Level Configuration page appears with following log level details:
  • Service: Provisioning Gateway microservice name
  • Application Log Level: This field shows the log level of the microservice. Its possible values are:
    • DEBUG
    • ERROR
    • INFO
    • TRACE
    • WARN
  • View: Click View corresponding to each microservice to View Log Level List detail.
    Figure 4-12 Sample: View Log Level List - auditor-service
Editing Log Level Details
To edit log level details:
  1. Click Edit on the Logging Level Configuration page. The Edit Log Level page appears.
    Figure 4-13 Sample: Edit Log Level
  2. Update the log level details as required. To add the Package Log Level details:
    1. Click the Add button available in the Package Log Level section. The Add Package Log Level dialog box appears:
      Figure 4-14 Add Package Log Level
    2. Enter the Package name and select the Log Level from the list. The Log Level options are:
      • DEBUG
      • ERROR
      • INFO
      • TRACE
      • WARN
    3. Click Save to add the package log level details. [OR] Click Cancel to exit the Add Package Log Level dialog box.
  3. Click Save. A confirmation message, "Save successfully." appears.
  4. If you do not want to modify any log level detail, click Cancel. The Logging Level Configuration page appears.
  5. Click Refresh to reload the Logging Level Configuration page.
4.6 Auditor Service Status
To access the Auditor Service Status page, click PROVGW and then Auditor Service Status in the left navigation pane of the CNC Console application. The following page appears:
Figure 4-15 Auditor Service Status
The Auditor Service Status page shows following service status details:
  • Audit Report ID: It is audit file name given at the start of the audit.
  • Match Count: Total subscriber matched between two segment exported files.
  • Mismatch Count: Total subscriber mismatched between two segment exported files.
  • Total Audited Subscribers Segment1: Total audited records from the segment one exported files including processing failed records.
  • Total Audited Subscribers Segment: Total audited records from the segment2 exported files including processing failed records.
  • Progress: Show the percentage of audits completed.
  • Start Time: Time at which audit started.
  • End Time: Time at which audit ended.
  • Status: Show the status of the audit. Possible values are as follows:
    • AUDIT_IN_PROGRESS
    • AUDIT_COMPLETED
    • AUDIT_FAILED
    • AUDIT_PAUSED
4.7 Service Configurations
To configure Provisioning Gateway services using CNC Console, you can use Service Configurations. In the left navigation pane of the CNC Console application, click PROVGW and then Service Configurations.
Using Service Configurations, Provisioning Gateway in UDR mode users can configure ProvGw Service service
Using Service Configurations, Provisioning Gateway in SLF mode users can configure following services:
  • Auditor Service
  • ProvGw Service
4.7.1 ProvGw Service
Click PROVGWand then Service Configurations. From the Service Configurations menu, select ProvGw Service. The ProvGw Service Configurations page appears:
Figure 4-16 ProvGw Service Configurations
The following table explains the ProvGw Service Configurations page in detail:
Table 4-3 ProvGw Service Configurations
Tracing Enabled False Read-only
Tracing is not enabled by default. Tracing addresses logging information in microservice based applications.
Retry Error Codes 500, 503 Editable This field displays comma separated error codes. These error codes are eligible for retry notifications in case of failures.
Retry Count 2 Editable Number of notification attempts to be done in case of notification failures.
Retry Interval 2 Editable The retry interval for notifications in case of failure. It is measured in seconds.
Editing ProvGw Service Configurations
To update or modify any configuration information related to ProvGw service:
  1. Click Edit. The ProvGw Service Configurations page appears.
  2. Update the configuration details as required and click Save. A confirmation message, "Save successfully." appears.
  3. If you do not want to modify any configuration, click Cancel. The ProvGw Service Configurations page appears.
  4. Click Refresh to reload the ProvGw Service Configurations page.
4.7.2 Auditor Service Configurations
Click PROVGWand then Service Configurations. From the Service Configurations menu, select Auditor Service. The Auditor Service Configurations page appears:
Auditor Service Service Configurations
The following table explains the Auditor Service Configurations page in detail:
Table 4-4 Auditor Service Configurations
Pause Audit false Editable Enables to pause the in progress audit when the parameter is set to true. Set the parameter to false to resume the audit.
Days To Keep Exported Files 1 Editable This parameter indicates that number of days the exported files is kept on the segment folders that are audit completed. If the number of days are older than the configured value, the files which are in AUDIT_COMPLETED status is deleted periodically.
Audit Start Time - editable This parameters specifies the time when audit should start in combination with frequencyOfPeriodicDump parameter value.
Frequency Of Periodic Dump DAILY editable
This parameter indicates the frequency of audit schedules. The allowed values are as follows:
  • ONE_TIME: Audit will be scheduled at one time.
  • DAILY: Audit will be scheduled daily at the time mentioned in the startTime.
  • WEEKLY: Audit will be scheduled weekly at the time mentioned in the startTime.
Segment1 SLF InstanceId Segment1SLFInstanceId editable This parameter defines the SLF instance ID from the first segment.
Segment2 SLF InstanceId Segment2SLFInstanceId editable This parameter defines the SLF instance ID from the second segment.
Maximum Discrepancies Count 1000000 editable This parameter defines maximum allowed configured discrepancies between the both segment exported files. If the discrepancies found are more than the configured value during audit, then the audit will be failed and alert is raised.
Delete Exported Files After Audit true editable If the parameter flag is set to true, the exported files is deleted immediately after the successful audit.
Maximum Number Audit Reports 3 editable This parameter defines the maximum number of audit files to be retained in audit report folder. When the files count exceeds the configured limit, the older files are deleted from the PVC.
Editing Auditor Service Configurations
To update or modify any configuration information related to auditor service:
  1. Click Edit. The Auditor Service Configurations page appears.
  3. If you do not want to modify any configuration, click Cancel. The Auditor Service Configurations page appears.
  4. Click Refresh to reload the Auditor Service Configurations page.
4.8 Logout of CNC Console
To logout of the CNC Console application, click the Sign Out link available at the top right corner. The following confirmation message appears:
Figure 4-17 CNC Console Logout
CNC Console Logout
