D SCP Traffic IP Flow
This section describes the Internet Protocol (IP) flow between the IP services.
Table D-1 SCP Traffic IP Flow of SCP-Worker (SCP Data Plane)
Source Node Destination Node Destination Port Type of Port Nature of Port IP Protocol Version Service Mesh Included(No means excluded from SM)
Peer 5G Network Function F5 Service Proxy 8000/9443 Load Balancer External IPv4 Yes
F5 Service Proxy SCP-W Pods 8080 Container Target Port Internal IPv4 Yes
SCPC-Subscription SCP-W Pods (Service fqdn) 8000/8080 Service Port or Container Target Port Internal IPv4 Yes
SCPC-Audit SCP-W Pods (Service fqdn) 8000/8080 Service Port or Container Target Port Internal IPv4 Yes
Prometheus SCP-W Pods 8091 Container Target Port Internal IPv4 Yes
SCP-Worker Peer 5G NF Peer NF port Load balancer port External IPv4 Yes
Kubelet (readiness) SCP-W Pods 8091 Container Target Port Internal IPv4 Yes
Kubelet (liveness) SCP-W Pods 8091 Container Target Port Internal IPv4 Yes
SCPC-Configuration SCP-W Pods (Service fqdn) 8080 Container Target Port Internal IPv4 Yes
SCP-Worker Coherence SCP-Worker/SCP-Cache Coherence 8095/8096 Container Target Port Internal IPv4 No
Operator/User SCP Worker Coherence Mgmt 9000/30000 Service Port or Container Target Port Internal IPv4 Yes
SCP-Worker SCP-Nrfproxy 8086 Container Target Port Internal IPv4 Yes
SCP-Nrfproxy SCP-Worker 8000 Container Target Port Internal IPv4 Yes
SCP-Worker scp-mediation 9090/30081 Service Port or Container Target Port Internal IPv4 No
SCP-Worker scp-nrfproxy-oauth 8040 Container target port Internal IPv4 Yes
SCP-Worker SCPC-Configuration 8092 Container target port Internal IPv4 No
SCP-Worker SCPC-Notification 8092 Container target port Internal IPv4 No
SCP-Worker SCPC-Audit 8092 Container target port Internal IPv4 No
Table D-2 SCP Traffic IP Flow SCP Control plane SCPC- Configuration
Operator/User F5 Service Proxy 443 Load Balance Port External IPv4 Yes
F5 Service Proxy CNCC Ingress API GW Pods 8081 Container Target Port Internal IPv4 Yes
CNCC SCP Configuration Pod 8081/8081 Internal Service Port / Container Target Port Internal IPv4 Yes
Prometheus SCPC-Config Pods 8091 Container Target Port Internal IPv4 Yes
Kubelet (readiness) SCPC-Config Pods 8091 Container Target Port Internal IPv4 Yes
SCPC-Configuration Kubenetes API server API Server Port Kube API Server Ports Infrastructure IPv4 Yes
SCPC-Configuration DB service 3306 Container Target Port External IPv4 Yes
SCPC-Configuration SCPC-Configuration 8092 Container Target Port Internal IPv4 No
SCPC-Configuration SCPC-Alternate-Resolution 8092 Container Target Port Internal IPv4 No
Table D-3 SCP Traffic IP Flow SCP Control plane SCPC- Subscription
SCPC-Subscription SCP-W Pods (Service fqdn) 8000/8080 Service Port / Container Target Port Internal IPv4 Yes
SCPC-Subscription Kubenetes API server API Server Port Kube API Server Ports Infrastructure IPv4 Yes
SCPC-Subscription DB service 3306 Container Target Port External IPv4 Yes
Prometheus SCPC-Subscription Pod 8091 Container Target Port Internal IPv4 Yes
Kubelet (readiness) SCPC-Subscription Pod 8091 Container Target Port Internal IPv4 Yes
SCPC-Configuration SCPC-Subscription Pod 8080 Container Target Port Internal IPv4 Yes
SCPC-Subscription SCPC-Configuration 8092 Container Target Port Internal IPv4 No
Table D-4 SCP Control plane SCPC- Notification
NRF F5 Service Proxy (SCP -Worker svc) 8000 Load Balancer External IPv4 Yes
F5 Service Proxy (SCP-Worker svc) SCP-W Pods 8080 Container Target Port Internal IPv4 Yes
SCP-W Pods SCP-Notificaton Service/Pods 8082/8082 Internal Service Port / Container Target Port Internal IPv4 Yes
SCPC-Configuration SCP-Notificaton Service/Pods 8082/8082 Internal Service Port / Container Target Port Internal IPv4 Yes
SCPC-Audit SCP-Notificaton Service/Pods 8082/8082 Internal Service Port / Container Target Port Internal IPv4 Yes
Prometheus SCP-Notificaton Pods 8091 Container Target Port Internal IPv4 Yes
Kubelet (readiness) SCP-Notificaton Pods 8091 Container Target Port Internal IPv4 Yes
SCPC-Notification Kubenetes API server API Server Port Kube API Server Ports Infrastructure IPv4 Yes
SCPC-Notification DB service 3306 Container Target Port External IPv4 Yes
SCPC-Configuration SCP-Notificaton 8082 Container Target Port Internal IPv4 Yes
SCPC-Notification Coherence SCPC-Notification/SCP-Cache Coherence 8095/8096 Container Target Port Internal IPv4 No
SCPC-Notification SCPC-Configuration 8092 Container Target Port Internal IPv4 No
Table D-5 SCP Control plane SCPC-Audit
SCPC-Configuration SCP Audit Service/Pods 8083/8083 Internal Service Port / Container Target Port Internal IPv4 Yes
SCPC-Audit SCP-W Pods (Service fqdn) 8000/8080 service Port/Container Target Port Internal IPv4 Yes
Prometheus SCPC-Audit Pods 8091 Container Target Port Internal IPv4 Yes
Kubelet (readiness) SCPC-Audit Pods 8091 Container Target Port Internal IPv4 Yes
SCPC-Audit Kubenetes API server API Server Port Kube API Server Ports Infrastructure IPv4 Yes
SCPC-Audit DB service 3306 Container Target Port External IPv4 Yes
SCPC-Alternate-Resolution SCP Audit Service/Pods 8083/8083 Internal Service Port / Container Target Port Internal IPv4 Yes
SCPC-Audit SCPC-Configuration 8092 Container Target Port Internal IPv4 No
SCPC-Audit SCPC-Notification 8092 Container Target Port Internal IPv4 No
Table D-6 SCP Control plane SCPC-Alternate- Resolution
SCPC-Configuration SCPC-Alternate-Resolution Service/Pods 8084/8084 Internal Service Port / Container target port Internal IPv4 Yes
SCPC-Notification SCPC-Alternate-Resolution Service/Pods 8084/8084 Internal Service Port / Container Target Port Internal IPv4 Yes
SCPC-Audit SCPC-Alternate-Resolution Service/Pods 8084/8084 Internal Service Port / Container Target Port Internal IPv4 Yes
Prometheus SCPC-Alternate-Resolution Pods 8091 Container Target Port Internal IPv4 Yes
Kubelet (readiness) SCPC-Alternate-Resolution Pods 8091 Container Target Port Internal IPv4 Yes
SCPC-Alternate-Resolution DB service 3306 Container Target Port Infrastructure IPv4 Yes
SCPC-Alternate-Resolution SCPC-Configuration 8092 Container Target Port Internal IPv4 No
Table D-7 SCP-Cache (SCP Data Plane)
SCPC-Configuration SCP-Cache Service/Pods 8010/8010 Service Port / Container Target Port Internal IPv4 Yes
Prometheus SCP-Cache Pods 8091 Container Target Port Internal IPv4 Yes
Kubelet (readiness) SCP-Cache Pods 8091 Container Target Port Internal IPv4 Yes
SCP-Cache Coherence SCP-Worker/SCP-Cache Coherence 8095/8096 Container Target Port Internal IPv4 Yes
Operator/User SCP Cache Coherence Mgmt 9000/30000 Service Port / Container Target Port Internal IPv4 Yes
SCP-Cache Coherence Federation SCP Cache Coherence Federation 30001/30001 Service Port / Container Target Port External IPv4 Yes
SCP-Cache SCPC-Configuration 8092 Container Target Port Internal IPv4 No
Table D-8 SCP-Nrfproxy (SCP Data Plane)
SCP-Nrfproxy SCPC-Configuration 8081 Container Target Port Internal IPv4 Yes
Prometheus SCP-Nrfpfoxy Pods 8091 Container Target Port Internal IPv4 Yes
Kubelet (readiness) SCP-Nrfproxy Pods 8091 Container Target Port Internal IPv4 Yes
SCP-Nrfporxy DB service 3306 Container Target Port Infrastructure IPv4 Yes
SCP-Nrfproxy SCP-Worker-int 8092 Container Target Port Internal IPv4 Yes
SCP-Nrfproxy SCPC-Configuration 8092 Container Target Port Internal IPv4 No
Table D-9 SCP-Mediation and SCP-Data Director (SCP Data Plane)
Flow Description Source Node Destination Node Destination Port Type of Port Nature of Port IP Protocol Version Service Mesh Included(No means excluded from SM)
SCP-Mediation(SCP Data plane) SCP-Worker SCP-Mediation 9090/30081 Service Port / Container Target Port Internal IPv4 No
SCP-Data Director(SCP Data plane) SCP-Worker OCNADD OCNADD Port Service Port / Container Target Port External IPv4 No
Table D-10 SCP-load-manager
scp-worker coherence SCP-Worker/scp-load-manager coherence 8095/8096 Container Target Port Internal IPv4 No
scp-load-manager SCPC-Notification 8082 Container Target Port Internal IPv4 Yes
scp-load-manager SCPC-Configuration 8081 Container Target Port Internal IPv4 Yes
scp-load-manager SCPC-Configuration 8092 Container Target Port Internal IPv4 No
scp-load-manager SCPC-Notification 8092 Container Target Port Internal IPv4 No
Table D-11 SCP-Nrfproxy-Oauth (SCP Data Plane)
SCP-Nrfproxy-Oauth SCPC-Configuration 8081 Container Target Port Internal IPv4 Yes
Prometheus SCP-Nrfproxy-Oauth Pods 8091 Container Target Port Internal IPv4 Yes
kubelet (readiness) SCP-Nrfproxy-Oauth Pods 8091 Container Target Port Internal IPv4 Yes
SCP-Worker SCP-Nrfproxy-Oauth 8040 Container Target Port Internal IPv4 Yes
SCP-Nrfproxy-Oauth SCP-Worker-int 8092 Container Target Port Internal IPv4 Yes
SCP-Nrfproxy-Oauth coherence 8095/8096 Container Target Port Internal IPv4 No
SCP-Nrfproxy-Oauth SCPC-Configuration 8092 Container Target Port Internal IPv4 No
SCP Microservices Port Information
The following table lists the port used by SCP microservices.
Table D-12 SCP Microservices Port Information
Service Application Container Listen Port Type of Port Service Mesh Included(No means excluded from SM)
SCP-Worker (SCP Data plane) 8080 Container Target Port Yes
8091 Container Target Port Yes
8095/8096 Container Target Port No
9000/30000 Service Port/Container Target Port Yes
9443 Container Target Port No
scp-worker-int 8092 Container Target Port No
SCP Control plane SCPC-Configuration 8081 Internal Service Port / Container Target Port Yes
scpc-configuration-int 8092 Container Target Port No
SCP Control plane SCPC-Subscription 8091 Container Target Port Yes
SCP Control plane SCPC-Notification 8082 Container Target Port Yes
scpc-notification-int 8092 Container Target Port No
SCP Control plane SCPC-Audit 8083 Container Target Port Yes
scpc-audit-int 8092 Container Target Port No
SCP Control plane SCPC-Alternate-Resolution 8084 Container Target Port Yes
scpc-alternate-resolution-int 8092 Container Target Port No
SCP-Cache (SCP Data plane) 8010 Container Target Port Yes
9000/30000 Service Port / Container Target Port Yes
SCP-Nrfproxy (SCP Data plane) 8086 Container Target Port Yes
SCP-Mediation(SCP Data Plane) 9090/30081 Service Port/Container Target Port No
SCP-Load-Manager (SCP Data plane) 8091 Container Target Port Yes
SCP-Nrfproxy-Oauth (SCP Data plane) 8081 container target Port Yes
8091 container target Port Yes
8040 container target Port Yes
8000 container target Port Yes
8095/8096 container target Port No
