B Increasing Persistent Volume Claim (PVC)
Increasing the PVC size to support scalability is a mandatory task and
must be performed only after the Helm installation or upgrade is complete.
The PVC size increment must not be performed during the Helm installation or upgrade.Perform the following steps to increase the PVC:
- Set the
ALLOWVOLUMEEXPANSION
to True for the Storageclass. The default value is standard. - Run the following command to scale down the statefulset for the
namespace.
When the statefulset is scaled down, the pod will go to terminate state.kubectl scale sts provgw-auditor-service --replicas=0 -n <namespace>
- Run the following command to edit the
PVC.
You can change thekubectl edit pvc dynamic-auditor-pvc-provgw-auditor-service-0 -n <namespace >
storage
space to the required value and save the details.spec: accessModes: - ReadWriteOnce resources: requests: storage: 10Gi storageClassName: standard volumeMode: Filesystem volumeName: pvc-87978b35-2320-4da5-9ca0-1dae183d29e7 status: accessModes: - ReadWriteOnce capacity: storage: 10Gi phase: Bound
- Run the following command to scale-up the
statefulset.
kubectl scale sts provgw-auditor-service --replicas=1 -n <namespace>
- Run the following command to view the increased storage in the
pod.
kubectl get pvc -n <namespace>
