Configure Media Flow Engine
Use this REST API endpoint to add, edit, or remove MFE nodes, specifying details such as the engine’s name, IP address, port settings, and protocol support.
URL Syntax
/management/weblogic/latest/edit/customResources/IntelligentMediaConnector/customResource/mediaFlowEngines
HTTP Methods
  • GET
  • POST
  • DELETE
Parameters
Table 17-25 URL Parameters
Names Description
links Set to none if you want to remove the links from the response. Set to an enumerated list of the links to return. For example:
.../?links=none
Examples
Example 17-65 Get all Media Flow Engines
curl -u 'weblogic:<password>' \
    "http://10.0.0.1:7001/management/weblogic/latest/edit/customResources/IntelligentMediaConnector/customResource/mediaFlowEngines?links=none"
Example response:
  "items": [
      "identity": [
        "customResources",
        "IntelligentMediaConnector",
        "customResource",
        "mediaFlowEngines",
        "MF2"
      "managementIP": "10.0.0.2",
      "managementPort": 8081,
      "sslEnabled": false,
      "serverName": "MF2",
      "secondaryPort": 8080
      "identity": [
        "customResources",
        "customResource",
        "mediaFlowEngines",
        "MF3"
      "managementIP": "10.0.0.3",
      "serverName": "MF3",
Example 17-66 Get a specific Media Flow Engine
curl -X GET -u 'weblogic:<password>' \
  "http://10.0.0.1:7001/management/weblogic/latest/edit/customResources/IntelligentMediaConnector/customResource/mediaFlowEngines/MF3?links=none"
Example response body:
  "identity": [
    "customResources",
    "customResource",
    "mediaFlowEngines",
    "MF3"
Example 17-67 Add a Media Flow Engine
curl -X POST -u 'weblogic:<password>' \
  -H "X-Requested-By: ConsoleBackendRestClient" \
  -H "Content-Type: application/json" \
  -d@mediaFlowEngines.json \
  "http://10.0.0.1:7001/management/weblogic/latest/edit/customResources/IntelligentMediaConnector/customResource/mediaFlowEngines"
Example request body:
The Converged Application Server responds with a 201 Created.
Example 17-68 Delete a Media Flow Engine
curl -X DELETE -u 'weblogic:<password>' \
  "http://10.0.0.1:7001/management/weblogic/latest/edit/customResources/IntelligentMediaConnector/customResource/mediaFlowEngines/MF3"
The Converged Application Server responds with a 200 OK.
