1 Convergent Charging Controller OUI Installer Screens
Installation Inventory
Specify the name and location of the directory where all Oracle installations are done.
| Field | Description |
| Inventory Directory | Enter the name and the full path to the directory where all Oracle installations are done. |
| Operating System Group | Select the primary Oracle inventory group. |
Installation Location
Specify the name and location of the directory in which to install Convergent Charging Controller.
| Name | Enter the name and the full path to the /IN directory in which to install Convergent Charging Controller. |
Installation Type
Select the installation type.
| SMS |
Installs the Convergent Charging Controller Service Management System (SMS) application and the SMS database. You use the SMS GUI to configure and manage Convergent Charging Controller. |
| SLC |
Installs the Convergent Charging Controller Service Logic Controller (SLC) application and the SLC database. You use SLC to provide the logic to manage the calls, sessions, messages in Convergent Charging Controller. Note: Ensure that SMS is installed before installing SLC. |
| SLC With Test Tools |
Installs the Convergent Charging Controller Service Logic Controller (SLC) application, the SLC database, and the SLC test tools. Note: Ensure that SMS is installed before installing SLC With Test Tools. |
| VWS |
Installs the Convergent Charging Controller Voucher and Wallet Server (VWS) application and VWS database. The Voucher and Wallet Server manages charging, vouchers, balances, and subscribers. Note: Ensure that SMS is installed before installing VWS. |
Oracle User
Enter the Oracle database user details.
| Oracle DB owner | Retain the default, oracle, which is the user name with permissions to create the Oracle database instance. |
| Oracle DB group | The OS group which owns the Oracle database. For example ‘dba’. |
Application User
Enter the CCC runtime user details.
| Application owner | The CCC_runtime_user i.e. the OS user that will run the application. |
| Application group | The CCC OS group. Fixed to ‘esg’. |
Database Location
Select one from the provided options.
| Option | Description |
| The database, schema and application will all be installed | Select this option to install all items on the same node. |
| The database already exists and both the schema and application will be installed | Select this option if you have already created the database including datafiles on this or a remote node but not the database schema or application. |
| The database and schema already exists and only the application will be installed | Select this option if the database and schema already exists on this or a remote node and you want to only install the application. |
Database Datafiles
Database Server Paths
Specify the location of the base directory and the Oracle home directory.
| Base directory | Enter the name and the full path to the oracle base directory in which the database creation scripts are installed. The oracle base directory is the directory in which the Oracle database is installed. |
| Oracle home | Enter name and the full path to the Oracle Database home directory in which Oracle 12c database is installed. |
Database Password
Enter the previously existing Oracle database password administrative account.
| Oracle SID | Enter the Oracle SID. |
| Database hostname | Enter the hostname where the database is located. |
| Database user (smf, scp or e2be) | Enter the database user name. |
| Oracle database password | Enter the password for the Oracle database administrative accounts. |
| Database Port | Enter the port that is required to connect to the database host. |
| Service database hostname | Enter the fully qualified service DB hostname. |
SMS GUI
Enter the information for SMS GUI.
| Screen superuser password |
Enter the password for the SMS GUI administrator user account. Note: The password must match with the Oracle password defined for the Oracle database installed on the SMS node. |
| Confirm password | Enter the password again for confirmation. |
| Timezone | Enter the time zone in which the date and time are displayed in the SMS GUI. |
PI Admin
Enter the information for Provisioning Interface (PI) configuration.
| PI admin password | Enter the password for PI administrator user account. |
SMS EDR Paths
Enter the path to the directories in which the SMS event data record (EDR) files are stored.
| CDR Loader Input directory | Retain the default path to the directory of a single file system to store CDR input files. |
| CDR Loader Output directory | Retain the default path to the directory of a single file system to store CDR output files. |
Default Template
Select the option to install default template.
| Install PCST | Check the box to install Prepaid Charging Service Template (PCST). |
Default Currency
Enter the details of default system currency.
| System Currency |
Select the currency name from the Name drop down box. Note: Only valid currency names are available from the list. |
| Base Value |
Enter the ratio of subunits to main units of currency in the Base field. Example: 100 cents per euro = a ratio of 100. |
| Big Symbol | Enter the symbol that represents the main unit of the currency in the Big Symbol field (for example, € for euros). |
| Little Symbol | Enter the symbol that represents the subunit of the currency in the Little Symbol field (for example, c for cents). |
| Seperator |
Enter the separator used to separate the main unit from the subunit of the currency in the Separator field. Example: In the currency of: Euros - the separator is a comma (for example, 3,20) Dollars - the separator is a decimal point (for example, $4.00) |
Replication
Enter the information of the SMS host from which the current node is replicated.
| SMS Host name | Enter the qualified hostname for the SMS server used to configure the clients that will connect to the SMS server. |
VWS Config
Enter the information Voucher and Wallet Server (VWS) configuration.
| SMS EDR Input directory | Enter the name and the full path to the directory in which the SMS event data record (EDR) input files are stored. |
| Primary VWS node | Select to install the primary node of a VWS pair. |
