1 ACS Main Screen
The Advanced Control Services main screen is displayed when you successfully log in to the ACS UI. This screen displays icons that represent the configuration options available in ACS. Click a button in the Advanced Control Services main screen to open the configuration screen for that option.
This Help set contains ACS component related information. Other component Help sets are available at the following index page:
https://docs.oracle.com/en/industries/communications/convergent-charging-controller/15.1/index.html
You can also use the search functionality in the index page to search for any keyword across multiple Help sets.
ACS Configuration Options
The following table describes the Advanced Control Services configuration options.
| Configuration Option | Function |
| Control Plans | Accesses the Control Plan Editor Overview where you configure your ACS control plans. |
| Numbers | Accesses the Numbers screen where you configure the access numbers that trigger control plans such as service numbers (SN) or caller line identifier (CLI) numbers. |
| Configuration | Accesses the Configuration screen where you configure the ACS resources used in control plans such as geography sets, holidays and announcements. |
| Resources | Accesses the Resources screen where you configure service provider resources such as termination ranges and number translations. |
| Customer | Accesses the Customer screen where you configure service provider information such as resource limits and contact information. |
| Tools | Accesses the Tools screen where you configure system defaults such as system languages, SMS user access, networks, and termination ranges. |
| Password |
Note: This option is not available to users who access ACS through the SMS. For SMS logins, ACS uses the SMS security mechanism, so the user's password must be changed through the SMS. Accesses the Change Password screen. Users who can access this screen can set up user passwords. |
