3 Operations Supported by ACS
Operations and Results Sent from SSF to ACS
About Operations and Results Sent from SSF
This section lists the supported operations that can be sent from the Service Switching Function (SSF) to ACS, and provides details about the supported parameters for each operation. For example operations, see Example ACS Message Sequences.
The following operations and results are the only operations and results sent from the SSF that can be received by ACS:
- InitialDP Operation (CS1, CS2, CAP2, CAP3, CAP4)
- EventReportBCSM Operation
- ApplyChargingReport Operation
- CallInformationReport Operation
- InitiateCallAttempt Result
- Support for DisconnectLeg, SplitLeg and MergeCallsegments Operation Results
- ACS replies with TCAP_ABORT if it receives an unsupported operation from the SSF.
- ACS ignores any unsupported parameters in operations sent by the SSF.
This table lists the parameters used in InitialDP operations, and identifies which of these parameters are supported by ACS for which protocols. The parameters are listed in the order they appear in the specification documents.
| Parameter | Protocol | Supported | Description |
serviceKey
CS1, CS2, CAP2, CAP3, CAP4 | Yes |
ACS uses this parameter to determine which service and which control plan to run. The control plan can also make decisions based on this parameter and the contents of this parameter can be sent over other interfaces such as DIAMETER or SOAP. |
calledPartyNumber
ACS uses this parameter for some services (such as the 0800 service) to determine which control plan to run. ACS also uses this parameter in real time charging for rating the call. The control plan can also make decisions based on this parameter and the contents of this parameter can be sent over other interfaces such as DIAMETER or SOAP. |
callingPartyNumber
ACS uses this parameter in real time charging to identify the subscriber and for rating the call. See About InitialDP Parameters and Real Time Charging. The control plan can also make decisions based on this parameter and the contents of this parameter can be sent over other interfaces such as DIAMETER or SOAP. |
callingPartysCategory
CS1, CS2, CAP2, CAP3, CAP4 | Yes | The control plan can make decisions based on this parameter and the contents of this parameter can be sent over other interfaces such as DIAMETER or SOAP. |
cGEncountered
CS1, CS2, CAP3, CAP4 | No | |
iPSSPCapabilities
CS1, CS2, CAP2, CAP3, CAP4 | No | |
iPAvailable
CS1, CS2 | No | |
locationNumber
ACS uses this parameter in real time charging for rating the call. See About InitialDP Parameters and Real Time Charging. The control plan can also make decisions based on this parameter and the contents of this parameter can be sent over other interfaces such as DIAMETER or SOAP. |
locationInformation.ageOfLocationInformation
locationInformation.geographicalInformation
locationInformation.vlr-number
locationInformation.locationNumber
locationInformation.cellIdOrLAI
CAP2, CAP3, CAP4 | Yes | The control plan can make decisions based on this parameter (such as "in the zone" logic) and the contents of this parameter can be sent over other interfaces such as DIAMETER or SOAP. |
LocationInformation.locationInformationEPS.E-UTRANCellGlobalIdentity
CAP2, CAP3, CAP4 | Yes | The control plan can make decisions based on this parameter. |
LocationInformation.locationInformationEPS.TrackingAreaIdentity
originalCalledPartyID
extensions
Up to 10 individual extensions can be extracted, based on configurable rules, into strings of characters. You can use one of these extensions for rating the call. See About InitialDP Parameters and Real Time Charging. The control plan can also make decisions based on any of these extensions and the content of any of these extensions can be sent over other interfaces such as DIAMETER or SOAP. |
highLayerCompatibility
CS1, CS2, CAP2, CAP3, CAP4 | Yes | The control plan can make decisions based on this parameter. |
serviceInteractionIndicators
CS1, CS2 | No | |
additionalCallingPartyNumber
forwardCallIndicators
CS1, CS2 | No | |
bearerCapability
ACS uses this parameter when determining which control plan and service to run. The control plan can also make decisions based on this parameter and the contents of this parameter can be sent over other interfaces such as DIAMETER or SOAP. |
eventTypeBCSM
The value of this parameter, particularly whether it is from the originating basic call state model or the terminating basic call state model, is used to determine which event detection points to arm in subsequent RequestReportBCSMEvent operations. The control plan can also make decisions based on this parameter. |
redirectingPartyID
ACS uses this parameter in real time charging to identify the subscriber and for rating the call. See About InitialDP Parameters and Real Time Charging (). The control plan can also make decisions based on this parameter and the contents of this parameter can be sent over other interfaces such as DIAMETER or SOAP. |
redirectionInformation
CS1, CS2, CAP2, CAP3, CAP4 | Yes | The control plan can make decisions based on this parameter. See also redirectionInformation in the Connect operation. |
dialledDigits
CS2 | No | |
callingPartyBusinessGroupID
CS2 | No | |
callingPartySubaddress
CS2 | No | |
miscCallInfo
CS2 | No | |
serviceProfileIdentifier
CS2 | No | |
terminalType
CS2 | No | |
triggerType
CS2 | No | |
cause
componentType
CS2 | No | |
component
CS2 | No | |
componentCorrelationID
CS2 | No | |
iSDNAccessRelatedInformation
CS2 | No | |
iNServiceCompatibilityIndication
CS2 | No | |
genericNumbers
CS2 | No | |
serviceInteractionIndicatorsTwo
forwardGVNS
CS2 | No | |
createdCallSegmentAssociation
CS2 | No | |
uSIServiceIndicator
CS2 | No | |
uSIInformation
CS2 | No | |
iMSI
subscriberState
ext-basicServiceCode
callReferenceNumber
mscAddress
calledPartyBCDNumber
CAP2, CAP3, CAP4 | Yes | ACS uses this parameter, if present, instead of the
calledPartyNumber parameter.
timeAndTimezone
gsm-ForwardingPending
InitialDPArgExtension.naCarrierInformation
CAP2 | No | |
InitialDPArgExtension.gmscAddres
carrier
CAP3, CAP4 | No | |
cug-Index
CAP3, CAP4 | No | |
cug-Interlock
CAP3, CAP4 | No | |
cug-OutgoingAccess
CAP3, CAP4 | No | |
initialDPArgExtension.forwardingDestinationNumber
CAP4 | No | |
initialDPArgExtension.ms-Classmark2
CAP4 | No | |
initialDPArgExtension.iMEI
initialDPArgExtension.supportedCamelPhases
CAP4 | No | |
initialDPArgExtension.offeredCamel4Functionalities
CAP4 | No | |
initialDPArgExtension.bearerCapability2
CAP4 | No | |
initialDPArgExtension.ext-basicServiceCode2
CAP4 | No | |
initialDPArgExtension.highLayerCompatibility2
CAP4 | No | |
initialDPArgExtension.lowLayerCompatibility
CAP4 | No | |
initialDPArgExtension.lowLayerCompatibility2
CAP4 | No | |
initialDPArgExtension.enhancedDialledServicesAllowed
CAP4 | No | |
initialDPArgExtension.uu-Data
CAP4 | No | |
initialDPArgExtension.collectInformationAllowed
CAP4 | No | |
initialDPArgExtension.releaseCallArgExtensionAllowed
CAP4 | No |
ACS uses the following optional parameters in an initialDP operation to identify and locate the subscriber for real time charging:
- callingPartyNumber
- locationNumber
- locationInformation.vlr-number
- locationInformation.locationNumber
- locationInformation.locationInformationEPS
- originalCalledPartyID
- extensions
- additionalCallingPartyNumber
- redirectingPartyID
- iMSI
- mscAddress
ACS uses the parameters to deduce two numbers:
- The number to use to identify the calling subscriber, and so determine who should pay for the call.
- The number which best describes the location of the subscriber, and so rate the call.
You configure the order in which to search for these parameters in ACS. ACS looks for the parameters in the initialDP in the specified order and uses the first one it finds. For example, you can configure ACS to identify the subscriber from one of the following parameters, in the order listed:
If the redirectingPartyID does not exist, then ACS tries to use the originalCalledPartyID. If the originalCalled PartyID does not exist, then ACS uses the callingPartyNumber.
The following table lists the parameters used in EventReportBCSM operations, and identifies which parameters are supported by ACS for which protocols. The parameters are listed in the order they appear in the specification documents.
eventTypeBCSM
The following event detection points only are supported:
eventSpecificInformationBCSM
eventSpecificInformationBCSM is supported for these event detection points only:
legID
CS1, CS2, CAP2, CAP3, CAP4 | Yes | The service logic uses this parameter |
miscCallInfo
extensions
bcsmEventCorrelationID
CS2 | No | |
componentType
CS2 | No | |
component
CS2 | No | |
CS2 | No |
The ApplyChargingReport operation is defined in the CS1 and CS2 specifications. The CS1 and CS2 specifications do not define the contents of the ApplyChargingReport operation.
Note: ACS supports some non-standard CS1 implementations of ApplyChargingReport but this is beyond the scope of this compliance document.
The following table lists the parameters used in ApplyChargingReport operations, and identifies which parameters are supported by ACS for which protocols. The parameters are listed in the order they appear in the specification documents.
partyToCharge
timeInformation.timeIfNoTariffSwitch
CAP2, CAP3, CAP4 | Yes | Used to charge the call for real time charging. |
timeInformation.timeIfTariffSwitch.timeSinceTariffSwitch
ACS uses this parameter, if present, in real time charging to determine the charge for the call.
Note: Because ACS does not set the
timeInformation.timeIfTariffSwitch.tariffSwitchInterval
callActive
CAP2, CAP3, CAP4 | Yes | Used by the service logic |
callReleasedAtTcpExpiry
extensions
CAP3, CAP4 | No | |
aChChargingAddress
CAP4 | No |
The following table lists the parameters and protocols used in CallInformationReport operations, and identifies which parameters are supported by ACS for which protocols. The parameters are listed in the order they appear in the specification documents.
requestedInformationList.RequestedInformation.requestedInformationType
CS1 | Yes | ACS records information from this parameter in the ACS CDR. |
requestedInformationList.RequestedInformation.requestedInformationValue
extensions
CS1 | No | |
legID
CAP2 | No |
Because ACS ignores the contents of the InitiateCallAttempt results returned for InitiateCallAttempt operations, the service designer must ensure that ACS is configured to send to SSFs only InitiateCallAttempt operations that have the desired functionality. When a result with any contents is received, ACS allows the call to proceed.This table lists the parameters and protocols used in InitiateCallAttempt results, and identifies which parameters are supported by ACS for which protocols. The parameters are listed in the order they appear in the specification documents.
CAP4 | No | |
CAP4 | No | |
extensions
CAP4 | No | |
CAP4 | No |
Operations Sent from ACS to SSF
About Operations Sent from ACS to SSF
The following section lists the operations that can be sent from ACS to SSF, and provides details about the supported parameters for each operation. ACS includes only supported parameters in the operations that it sends to SSF, unsupported parameters are not included.
The following operations are the only operations that ACS sends to SSF. Operations that are not in the following list are never sent by ACS:
- EstablishTemporaryConnection Operation (CS1, CS2, CAP2, CAP3, CAP4)
- DisconnectForwardConnection Operation (CS1, CS2, CAP2, CAP3, CAP4)
- ConnectToResource Operation (CS1, CS2, CAP2, CAP3, CAP4)
- Connect Operation (CS1, CS2, CAP2, CAP3, CAP4)
- ReleaseCall Operation (CS1, CS2, CAP2, CAP3, CAP4)
- RequestReportBCSMEvent Operation (CS1, CS2, CAP2, CAP3, CAP4)
- CollectInformation Operation (CS1, CS2, CAP4)
- InitiateCallAttempt Operation (CS1, CS2, CAP4)
- FurnishChargingInformation Operation (CS1, CS2, CAP2, CAP3, CAP4)
- ApplyCharging Operation (CAP2, CAP3, CAP4)
- CallInformationRequest Operation (CS1, CS2, CAP2, CAP3, CAP4)
- SendChargingInformation Operation (CS1, CS2, CAP2, CAP3, CAP4)
- DisconnectForwardConnectionWithArgument Operation (CS2)
- ContinueWithArgument Operation (CS2, CAP4)
- DisconnectLeg Operation (CS2, CAP4)
- SplitLeg Operation (CS2)
- MergeCallSegments Operation (CS2)
ACS replies with TCAP_ABORT if it receives an unsupported operation from SSF.For example operations, see Example ACS Message Sequences.
The following table lists the parameters and protocols used in EstablishTemporaryConnection operations, and identifies which parameters are supported by ACS for which protocols. The parameters are listed in the order they appear in the specification documents.
| Parameter | Protocol | Supported | Notes |
assistingSSPIRoutingAddress
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You can configure ACS to send either the
correlationID and scfID parameters, or to
include the correlation ID and SCF ID in the
assistingSSPIPRoutingAddress parameter. The digits of
the assistingSSPIPRoutingAddress, the digits of the
SCF ID, and the number of digits in the correlation ID are all
configurable.
correlationID
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You can configure ACS to send the correlationID
parameter, or to include the correlation ID in the
assistingSSPIPRoutingAddress parameter. The number of
digits in the correlation ID are configurable.
scfID
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You can configure ACS to send the scfID parameter,
or to include the SCF ID in the
the SCF ID are configurable.
extensions
CS1, CS2 | No | |
partyToConnect/callSegmentID
CS2, CAP4 | No | ACS does not set this parameter even though there are some differences between CAP4 and CS2 for this parameter. |
carrier
CS2, CAP4 | No | |
na-info
chargeNumber
CAP3, CAP4 | No | |
CAP4 | No | |
callingPartyNumber
CAP4 | No |
ACS sends the DisconnectForwardConnection operation to SSF for protocols CS1, CS2, CAP2, CAP3, and CAP4. The DisconnectForwardConnection operation has no parameters.
The following table lists the parameters and protocols used in ConnectToResource operations, and identifies which parameters are supported by ACS for which protocols. The parameters are listed in the order they appear in the specification documents.
resourceAddress.ipRoutingAddress
CS1, CS2, CAP2, CAP3, CAP4 | Yes | This parameter is configurable per Specialized Resource Function (SRF). You can also configure ACS to set this parameter to none for a particular SRF. |
resourceAddress.none
CS1, CS2, CAP2, CAP3, CAP4 | Yes | This parameter is configurable per SRF. You can also configure the SRF to set this parameter to none. |
extensions
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You can configure ACS to set the Nokia specific
chargeableUI extension to 0, or to set the ZTE
specific bothwayThroughConnectionInd extension to
bothwayPathNotRequired. No other extensions are
supported in this operation.
CS1, CS2 | No | |
resourceAddress.legID
CS2 | Yes |
ACS sets this parameter to 2 (for leg 2) only in post answer beep scenarios. See Post Answer Beep or Announcement Message Sequence . Otherwise, ACS does not set this parameter. |
resourceAddress.ipAddressAndLegID
CS2 | No | |
resourceAddress.callSegmentID
CS2 | No | |
resourceAddress.ipAddressAndCallSegment
CS2 | No | |
callSegmentId
CAP4 | No |
The following table lists the parameters and protocols used in Connect operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
destinationRoutingAddress
CS1, CS2, CAP2, CAP3, CAP4 | Yes | (Required) Configurable in the control plan. ACS always sets this parameter to a value retrieved from the local database or from an external database via, for example, SOAP. |
alertingPattern
correlationID
CS1, CS2 | No | |
cutAndPaste
CS1, CS2 | Yes | Configurable in the control plan. ACS does not set this parameter by default. |
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You can set this parameter to be populated from a buffer. The buffer contents can be configured in the control plan or set to a value retrieved from the local database, or from an external database; for example, via SOAP. |
routeList
CS1, CS2 | No | |
scfID
CS1, CS2 | No | |
extensions
CS1, CS2 | No | |
callingPartyNumber
CS1, CS2 | Yes | You can set this parameter to be populated from a buffer. The buffer contents can be configured in the control plan or set to a value retrieved from the local database, or from an external database; for example, via SOAP. |
redirectingPartyID
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You can configure ACS to set the redirection counter within
redirectionInformation during control plan execution.
ACS copies all the other parts of
redirectionInformation from the InitialDP.
forwardingCondition
CS2 | No | |
CS2 | No | |
travellingClassMark
CS2 | No | |
carrier
CS2 | No | |
displayInformation
CS2 | No | |
CS2 | No | |
genericNumbers
Yes CS2 is not supported |
callingPartyNumber is not a parameter in Connect
operations for CAP protocols. However, if you configure ACS to send
callingPartyNumber in Connect operations, ACS adds
genericNumbers with a content of one additional
calling party number for CAP2, CAP3, and CAP4 protocols.
iNServiceCompatibilityResponse
CS2 | No | |
forwardGVNS
CS2 | No | |
backwardGVNS
CS2 | No | |
chargeNumber
callSegmentID
CS2 | No | |
legToBeCreated
CS2, CAP4 | No | |
suppressionOfAnnouncemen
CAP2, CAP3, CAP4 | Yes | You can configure the control plan to set this parameter. |
oCSIApplicable
na-Info
cug-Interlock
CAP3, CAP4 | No | |
cug-OutgoingAccess
CAP3, CAP4 | No | |
bor-InterrogationRequested
CAP4 | No | |
suppress-N-CSI
CAP4 | No |
The following table lists the parameters and protocols used in ReleaseCall operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
All the protocol specifications use the same coding of this parameter although the ASN.1 is different. ACS sets cause value to 31 by default (normal call clearing) but you can also specify the cause value in control plan configurations and, for error cases, in configuration files. |
associatedCallSegment
CS2 | No | |
allCallSegments
CS2 | No | |
allCallSegmentsWithExtension
CAP4 | No |
The following table lists the parameters and protocols used in RequestReportBCSMEvent operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
Note: For non-standard Service Switching Points (SSPs) that work only when each RequestReportBCSMEvent operation contains only detection points for a single leg, configure ACS to send two RequestReportBCSMEvent operations in the same TCAP message instead of one. The leg 1 events must be in the first operation.
bcsmEvents.eventTypeBCSM
CS1, CS2, CAP2, CAP3, CAP4 | Supported |
ACS supports only the following event detection points:
See the scenarios in Example ACS Message Sequences for details of which event section point is set in which circumstance. |
bcsmEvents.monitorMode
CS1, CS2, CAP2, CAP3, CAP4 | Supported | See the scenarios in Example ACS Message Sequences for
details of how monitorMode is set.
bcsmEvents.dPSpecificCriteria.numberOfDigits
CS1, CS2 | Supported | Set only for collectedInfo(2).
bcsmEvents.dPSpecificCriteria.applicationTimer
CS1, CS2, CAP2, CAP3, CAP4 | Supported | Set only for oAnswer(7) and
tNoAnswer(14). You can configure the timer value or
use the configured default value. If you configure ACS to leave
this parameter unset, then the no answer timer is determined by the
network.
extensions
CS2 | No | |
bcsmEvents.automaticRearm
CAP4 | No | |
bcsmEvents.dPSpecificCriteria.midCallControlInfo
CS2, CAP4 | No | |
bcsmEvents.dPSpecificCriteria.dpSpecificCriteriaAlt
CAP4 | No |
ACS sends the CollectInformation operation to ask the SSP to collect more digits. See CollectInformation Message Sequence for more information
Except for CS2 protocol, the CollectInformation operation has no defined parameters and therefore ACS does not set any parameters.
The following table lists the parameters and protocols used in CollectInformation operations. The CollectInformation operation parameters are not supported by ACS for any protocol. The parameters are listed in the order they appear in the specification documents.
extensions
CS1, CS2, CAP4 | No | |
numberingPlan
CS2 | No | |
CS2 | No | |
travellingClassMark
CS2 | No | |
callingpartyNumber
CS2 | No | |
dialledDigits
CS2 | No | |
CS2 | No | |
CS2 | No | |
forwardGVNS
CS2 | No | |
backwardGVNS
CS2 | No | |
CS2 | No | |
callSegmentID
CS2 | No | |
legToBeCreated
CS2 | No |
The InitiateCallAttempt operation has a return result only for CAP4. It does not have a return result for CS1 or CS2.ACS uses the InitiateCallAttempt operation only to make a new call. It does not use the InitiateCallAttempt operation to make a new leg for an existing call. Logically, the legToBeCreated parameter should therefore be set to 1. However, the CAP4 specification states that the legToBeCreated parameter should be set to 3 or higher, and does not explicitly state that this does not apply for new calls. (This may be an oversight.) Some CAP4 MSCs may insist on legToBeCreated being set to 3 or higher, therefore you should configure to set legToBeCreated to 3 on a per SSP basis. If legToBeCreated is set to 3, leg 3 will be used instead of leg 1 for all other operations sent by ACS.
The following table lists the parameters and protocols used in InitiateCallAttempt operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
CS1, CS2, CAP4 | Yes | (Required) Configurable in the control plan. ACS always sets this parameter to a value retrieved from the local database or from an external database via, for example, SOAP. |
alertingPattern
CS1, CS2 | No | |
extensions
CS1, CS2, CAP4 | Partially supported | For CS1 and CS2 (but not CAP4) ACS uses an Convergent Charging Controller extension field to hold the category of the calling party. This can be used internally within an Convergent Charging Controller system. No other extensions are supported. |
CS1, CS2 | No | |
callingPartyNumber
CS1, CS2, CAP4 | Yes | You can configure the source for calling party number in the control plan. It can be a fixed value or a value retrieved from the local database, or from an external database via, for example, SOAP. |
CS2 | No | |
travellingClassMark
CS2 | No | |
legToBeCreated
CS2, CAP4 | Supported for CAP4 only | Set to either 1 or 3, depending on configuration. ACS always sets this parameter for CAP4. |
newCallSegment
CS2, CAP4 | Supported for CAP4 only | Set to 1. ACS always sets this parameter for CAP4. |
CS2 | No | |
CS2 | No | |
callReferenceNumber
CAP4 | Yes | Set to the SLEE call ID, represented in decimal as a string of ASCII digits. |
gsmSCFAddress
CAP4 | Yes | The gsmSCFAddress is configured on a per SSP basis.
ACS always sets this parameter for CAP4. The
gsmSCFAddress is always the same as the global title
in the SCCP calling party number.
suppress-T-CSI
CAP4 | No |
In the CS1 specification, the contents of the FurnishChargingInformation operation are undefined, as follows:
FurnishChargingInformationArg ::=
FCIBillingChargingCharacteristicsFCIBillingChargingCharacteristics
::= OCTET STRING (SIZE (minFCIBillingChargingLength
..maxFCIBillingChargingLength))Where the FCIBillingChargingCharacteristics
parameter indicates the billing and charging characteristics, and
its content is network operator specific.
In the CAP2, CAP3, and CAP4 specifications the contents of FurnishChargingInformation are defined, but ACS does not provide explicit support for these definitions. Instead, you can configure a list of fixed binary Furnish Charging Information (FCI) contents for ACS. The control plan selects one of these FCI contents to put in a FurnishChargingInformation operation. To ensure that the configured binary contents conform to CAP2, CAP3, or CAP4, they must be coded by hand.
You can also use the Convergent Charging Controller Software Developer's Kit (SDK) to create a custom plugin library to insert dynamic data, such as called and calling party numbers, into FurnishChargingInformation operations. For more information about creating custom plugins by using the SDK, see SDK Developer's Guide.
ACS contains some pre-built plugins to support some non-standard FurnishChargingInformation formats but these are unlikely to be generally useful and are beyond the scope of this document.
Notes:
- ApplyCharging is defined as an operation in the CS1 and CS2 specifications but its contents are undefined. ACS does support some non-standard CS1 implementations of ApplyCharging, however this is beyond the scope of this compliance document.
- For most operations, the encoding of each individual parameter
is consistent across all the specifications; for example, a
parameter with the same tag that is present in CS1, CS2, CAP2,
CAP3, and CAP4 will have the same format for each protocol. This is
not the case for ApplyCharging where the encoding of the
releaseIfDurationExceededandtonetags are incompatible between CAP2, CAP3 and CAP4. ACS chooses the correct encoding based on the application context received in the TCAP message that contains the InitialDP operation.
The following table lists the parameters and protocols used in ApplyCharging operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
aChBillingChargingCharacteristics.maxCallPeriodDuration
CAP2, CAP3, CAP4 | Yes | You can configured ACS to set this parameter in control plans; for example, by using the Attempt Terminate with Pending TN Destination feature node in the control plan. |
aChBillingChargingCharacteristics.releaseIfdurationExceeded.tone
CAP2 | Yes | You can configured ACS to set this parameter in control plans. When set, a beep is played to the caller for a configurable number of seconds before funds for the call are exhausted. |
aChBillingChargingCharacteristics.releaseIfdurationExceeded.extensions
CAP2 | No | |
aChBillingChargingCharacteristics.tariffSwitchInterval
partyToCharge
CAP2, CAP3, CAP4 | Yes | You can configure ACS to always set this to the leg ID of the calling party (which will be leg 1 unless the call has been started with an InitiateCallAttempt for leg 2). By default this parameter is set to leg 1. |
extensions
CAP3,CAP4 | Yes | You can configured ACS to set this parameter and aChBillingChargingCharacteristics.tone in control plans. When set, a beep is played to the caller a configurable number of seconds before funds for the call are exhausted. |
CAP3 | Yes | You can configure ACS to set this parameter and aChBillingChargingCharacteristics.releaseIfdurationExceeded in control plans. When set, a beep is played to the caller a configurable number of seconds before funds for the call are exhausted. |
aChBillingChargingCharacteristics.extensions
CAP3, CAP4 | No | |
aChChargingAddress
CAP4 | Yes | ACS always sets this parameter to leg 2 for CAP4. |
aChBillingChargingCharacteristics.audibleIndicator
CAP4 | Yes | ACS omits this parameter or sets it to the value of
tone, depending on configuration. No other values are
supported.
This table lists the parameters used in CallInformationRequest operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order that they appear in the specification documents.
requestedInformationTypeListone
By default, ACS includes all five requested information types defined in CS1:
You can configure ACS to omit one or more of these items from the request. Because CAP2, CAP3, and CAP4 do not support calledAddress, you must configure ACS to omit calledAddress from the request if a CAP protocol is being used. |
extensions
correlationID
CS2 | No | |
legID
In the CS1 specification, the contents of SendChargingInformation are incompletely defined as follows:
SendChargingInformationArg ::= SEQUENCE
{sCIBillingChargingCharacteristics[0]
SCIBillingChargingCharacteristics,legID/partyToCharge [1]
LegID,extensions [2] SEQUENCE SIZE(1..numOfExtensions) OF
ExtensionField OPTIONAL--
...}SCIBillingChargingCharacteristics ::= OCTET STRING
(SIZE (minSCIBillingChargingLength
..maxSCIBillingChargingLength))Where the SCIBillingChargingCharacteristics
SCIBillingChargingCharacteristics are defined, but ACS
SCIBillingChargingCharacteristics contents for ACS. The control
plan selects one of these SCIBillingChargingCharacteristics
contents to put in a SendChargingInformation operation. To ensure
You can also use the SDK to create a custom plugin library to insert dynamic data (such as called and calling party numbers) in to SCIBillingChargingCharacteristics. For more information about creating custom plugins by using the SDK, see SDK Developer's Guide.
ACS contains some pre-built plugins to support some non-standard SendChargingInformation formats but these are unlikely to be generally useful and are beyond the scope of this document.
The following table lists the parameters and protocols used in SendChargingInformation operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
You can configure a list of fixed binary SCIBillingChargingCharacteristics contents for ACS. The control plan selects one of these SCIBillingChargingCharacteristics contents to put in a SendChargingInformation operation. See the descriptive text above for more information. |
legID/partyToCharge
This parameter is named:
The coding of this parameter is the same in all cases. ACS always sets this parameter to the leg ID of the calling party (which will be leg 1 unless the call has been started with an InitiateCallAttempt for leg 3). |
extensions
Note: ACS supports only the CS2 version of this operation. It does not support the CAP4 version.
The following table lists the parameters and protocols used in DisconnectForwardConnectionWithArgument operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
partyToDisconnect.legID
CS2 | Yes | ACS always sets this parameter to leg 2 because this operation is used only by the Post Answer Beep or Announcement Message Sequence. |
partyToDisconnect.callSegmentID / callSegmentID
CS2, CAP4 | No | Although the ASN.1 for this parameter differs between CS2 and CAP4, the encoding is the same. |
extensions
CS2, CAP4 | No |
The following table lists the parameters and protocols used in ContinueWithArgument operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
legID
CS2 | Yes | ACS always sets a leg ID, and uses the application context to work out whether to use this parameter (for CS2) or continueWithArgumentArgExtension.legOrCallSegment.legID (for CAP4). |
alertingPattern
CS2, CAP4 | No | |
genericName
CS2 | No | |
CS2 | No | |
forwardGVNS
CS2 | No | |
backwardGVNS
CS2 | No | |
extensions
CS2, CAP4 | No | |
CS2, CAP4 | No | |
CAP4 | No | |
genericNumbers
CAP4 | No | |
cug-Interlock
CAP4 | No | |
cug-OutgoingAccess
CAP4 | No | |
chargeNumber
CAP4 | No | |
carrier
CAP4 | No | |
suppressionOfAnnouncement
CAP4 | No | |
naOliInfo
CAP4 | No | |
CAP4 | No | |
suppress-O-CSI
CAP4 | No | |
continueWithArgumentArgExtension.suppress-D-CSI
CAP4 | No | |
continueWithArgumentArgExtension.suppress-N-CSI
CAP4 | No | |
continueWithArgumentArgExtension.suppressOutgoingCallBarring
CAP4 | No | |
continueWithArgumentArgExtension.legOrCallSegment.callSegmentID
CAP4 | No | |
CAP4 | Yes | This parameter is always set to a leg ID, and not a call segment
ID. ACS always sets a leg ID and uses the application context to
work out whether to use this parameter (for CAP4) or the
legID parameter (for CS2).
This table lists the parameters and protocols used in DisconnectLeg operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
legToBeReleased
CS2, CAP4 | Yes | ACS always sets this parameter to leg 2. |
releaseCause
CS2, CAP4 | Yes | ACS always sets this parameter to 31 for normal call clearing. |
extensions
CS2, CAP4 | No |
Note: Although the SplitLeg operation is supported in CAP4 and CS2, ACS supports only the CS2 version. ACS uses the SplitLeg operation only in the "Post answer beep or announcement" scenario, and this scenario requires the CS2 MergeCallSegments operation that is No in CAP4.
The following table lists the parameters and protocols used in SplitLeg operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
legToBeSplit
CS2 | Yes | ACS always sets this parameter to leg 2. |
newCallSegment
CS2 | No | |
extensions
CS2 | No |
The following table lists the parameters and protocols used in MergeCallSegments operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
sourceCallSegment
CS2 | Yes | ACS sets this parameter to 2 in post answer beep or announcement message sequences. See Post Answer Beep or Announcement Message Sequence. |
targetCallSegment
CS2 | Yes | ACS sets this parameter to 1 in post answer beep or announcement message sequences. See Post Answer Beep or Announcement Message Sequence. |
extensions
CS2 | No |
Operations Sent from ACS to an SRF
About Operations Sent from ACS to an SRF
The following section lists the operations that can be sent from ACS to a Specialized Resource Function (SRF), and provides details about the supported parameters for each operation. Unless explicitly stated, the SRF can be an SSF based (internal) SRF or an SRF on an external intelligent peripheral that is connected by using an EstablishTemporaryConnection operation. Operations not listed are not sent by ACS to an SRF.
The following operations are the only operations that ACS sends to an SRF. Operations that are not in the following list are not sent by ACS:
- PromptAndCollectUserInformation Operation (CS1, CS2, CAP2, CAP3, CAP4)
PlayAnnouncement Operation (CS1, CS2, CAP2, CAP3, CAP4)
The following table lists the parameters and protocols used in PlayAnnouncement operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
| Parameter | Protocol | Yes | Notes |
informationToSend.inbandinfo.messageID.elementaryMessageID
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You configure announcement name and language pairs to link to elementary message IDs in ACS. You select the announcement names in control plans and ACS maps them to the appropriate elementary message IDs. |
informationToSend.inbandinfo.messageID.text.messageContent
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You configure to put a Voice XML URL in this parameter in the ACS control plan. |
informationToSend.inbandinfo.messageID.text.attributes
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS sets textAttributes to "vxmlURL" when it sets
the messageContent parameter.
informationToSend.inbandinfo.messageID.elementaryMessageIDs
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS sets more than one elementary message ID for some functions.
You select and map the announcement names to elementary message IDs
as described for the elementaryMessageID
parameter.
informationToSend.inbandinfo.messageID.variableMessage.elementaryMessageID
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS uses variable part announcements for some functions. You
select and map the announcement names to variable elementary
message IDs as described for the elementaryMessageID
parameter.
informationToSend.inbandinfo.messageID.variableMessage.variableParts
ACS supports all five types of variable part (time, price, date, number, and integer). The contents of these parts can be:
informationToSend.inbandinfo.numberOfRepetitions
CS1, CS2, CAP2, CAP3, CAP4 | Yes | Configurable in the control plan |
informationToSend.inbandinfo.duration
informationToSend.inbandinfo.interval
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS sets this parameter to zero (0) |
informationToSend.tone.toneID
informationToSend.tone.duration
informationToSend.displayInformation
CS1, CS2 | No | |
disconnectFromIPForbidden
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS normally does not set this parameter, in which case the SRF should use the default value of TRUE. However, if the type of SRF is "ZTE" then ACS sets this parameter to FALSE. |
requestAnnouncementComplete
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS normally does not set this parameter, in which case the SRF should use the default value of TRUE. However, if the type of SRF is "ZTE" then ACS sets this parameter to TRUE. |
extensions
CS1, CS2, CAP2, CAP3, CAP4 | Yes | You can configure ACS to set the integer language ID in extension type 3 if the type of SRF for the announcement is "NAP" . Support for the extension type includes Unisys Network Application Protocol (NAP) SRFs as well as other SRFs. |
connectedParty.legID
CS2 | Yes | ACS sets this parameter to leg 2 in post answer beep or announcement message sequences. See Post Answer Beep or Announcement Message Sequence for more information. |
connectedParty.callSegmentID
CS2 | No | |
requestAnnouncementStartedNotification
CAP4 | No |
This table lists the parameters and protocols used in PromptAndCollectUserInformation operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
collectedInfo.collectedDigits.minimumNbOfDigits
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS always sets this parameter. |
collectedInfo.collectedDigits.maximumNbOfDigits
collectedInfo.collectedDigits.endOfReplyDigit
CS1, CS2, CAP2, CAP3, CAP4 | Yes | This parameter is configurable globally. ACS will not set this parameter if the type of SRF is "NORTEL". You can also configure ACS so that it never sets this parameter. |
collectedInfo.collectedDigits.interDigitTimeOut
CS1, CS2, CAP2, CAP3, CAP4 | Yes | This parameter is configurable globally. It may also be
overridden in a control plan when collecting a single digit, in
which case ACS sets firstDigitTimeOut and
interDigitTimeOut to the same value. ACS will not set
collectedInfo.collectedDigits.errortreatment
collectedInfo.collectedDigits.interruptableAnnInd
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS always sets this parameter to be TRUE always, or to be FALSE always, depending on configuration. |
collectedInfo.collectedDigits.voiceInformation
collectedInfo.collectedDigits.voiceBack
collectedInfo.iA5Information
CS2 | No | |
CS1, CS2, CAP2, CAP3, CAP4 | No | ACS does not set this parameter, and therefore the default of TRUE should be assumed. |
CS1, CS2, CAP2, CAP3, CAP4 | Yes | The informationToSendParameters for PromptAndCollectUserInformation are set in the same way as for PlayAnnouncement. |
parameter.
extensions
CS1, CS2, CAP2, CAP3, CAP4 | Yes | If the type of SRF is "NAP", then ACS adds the Unisys NAP type extension, type 3. See PromptAndCollectUserInformation NAP Extension Added by ACS for more information. |
callSegmentID
CS2, CAP4 | No | |
CAP4 | No |
The PromptAndCollectUserInfromation NAP Extension that ACS adds is valid for various SRFs including the Unsisys NAP type of SRF. The ASN.1 for the PromptAndCollectuserInformation extension type is equivalent to the following extension type definition:
NapExtension = SEQUENCE {language [0] INTEGER
(1..99) OPTIONAL,treatments [1] SEQUENCE {treat1stCancelDig
ENUMERATED { -- Treatment of first cancel digit
entered.rePrompt(0), rePromptAndReturnDigitToSCF(1),
returnDigitToSCF(2)} OPTIONAL,treat1stEORDig ENUMERATED { --
Treatment of first end of reply digit
entered.erroneousInput(0),returnDigitsToSCF(1)} OPTIONAL,
treatErroneousInput ENUMERATED { -- Treatment of erroneous
input.returnErrorToSCF(1), repromptThenReturnPatialEntr(2) }
OPTIONAL, treatCancelDig ENUMERATED { -- treatment of non-first
cancel digit. rePrompts(0), announceAndRePrompt(1) }
OPTIONAL}}For a NAP type SRF, ACS always adds all the announcement values defined in the treatments section. These values are globally configurable. For each announcement, you can also configure whether or not ACS adds the language.
Operations and Results Sent from an SRF to ACS
About Operations and Results Sent from an SRF to ACS
This section lists the operations and results that can be sent from a Specialized Resource Function (SRF) to ACS, and provides details about the supported parameters for each operation or result. Unless explicitly stated, the SRF can be an SSF based SRF (internal) or an SRF on an external intelligent peripheral that is connected to ACS by using an EstablishTemporaryConnection operation.
The following operations and results are the only operations and results sent from an SRF that can be received by ACS:
- AssistRequestInstructions Operation (CS1, CS2, CAP2, CAP3, CAP4) (external intelligent peripheral only)
- PromptAndCollectUserInformation Result (CS1, CS2, CAP2, CAP3, CAP4)
- SpecializedResourceReport (CS1, CS2, CAP2. CAP3, CAP4)
Notes:
- ACS raises an alarm and replies with TCAP_ABORT if it receives an unsupported operation from an SRF.
- ACS ignores any unsupported parameters in operations sent by the SRF.
The following table lists the parameters and protocols used in AssistRequestInstruction operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
Note: The AssistRequestInstruction operation can be sent to ACS only from an external intelligent peripheral.
correlationID
CS1, CS2, CAP2, CAP3, CAP4 | Yes | Identifies the call to which this operation relates. |
iPAvailable
CS1, CS2 | No | |
iPSSPCapabilities
extensions
This table lists the parameters and protocols used in PromptAndCollectUserInformation results, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
digitsResponse
CS1, CS2, CAP2, CAP3, CAP4 | Yes | ACS adds the digits to its announcement list in the chassis context where possible. |
iA5Response
CS2 | No |
The following table lists the parameters and protocols used in SpecializedResourceReport operations, and identifies which parameters and protocols are supported by ACS. The parameters are listed in the order they appear in the specification documents.
Note: ACS supports the SpecializedResourceReport operation for CS1, CS2, CAP2, CAP3, and CAP4, however only CAP4 specifies parameters for this operation.
allAnnouncementsComplete
CAP4 | No | |
firstAnnouncementStarted
CAP4 | No |
Operations and Results Sent Between ACS and an HLR
About Operations and Results Sent Between ACS and an HLR
The MAP AnyTimeInterrogation operation is the only operation used between core ACS and an Home Location Register (HLR).
This section provides details about the supported parameters for the AnyTimeInterrogation operation.
AnyTimeInterrogation Operation (MAP Protocol) Sent from ACS to HLR
The following table lists the parameters used in AnyTimeInterrogation operations sent from ACS to an HLR using the MAP protocol, and identifies which parameters are supported by ACS. The parameters are listed in the order they appear in the MAP specification documents.
subscriberIdentity.imsi
MAP | No | |
subscriberIdentity.msisdn
MAP | Yes | ACS always sets this parameter |
requestedInfo.locationInformation
requestedInfo.subscriberState
requestedInfo.extensionContainer
MAP | No | |
gsmSCF-Address
MAP | Yes | ACS always sets this parameter. Its value is configured globally. |
extensionContainer
MAP | No |
AnyTimeInterrogation Operation (MAP protocol) Sent from HLR to ACS
This table lists the parameters used in AnytimeInterrogation operations sent from an HLR to ACS using the MAP protocol, and identifies which parameters are supported by ACS. The parameters are listed in the order they appear in the MAP specification documents.
subscriberInfo.locationInformation.ageOfLocationInformation
MAP | No | |
subscriberInfo.locationInformation.geographicalInformation
MAP | No | |
subscriberInfo.locationInformation.vlr-number
MAP | Yes | Handled by ACS and can be stored in the chassis context |
subscriberInfo.locationInformation.locationNumber
subscriberInfo.locationInformation.cellIdOrLAI
subscriberInfo.locationInformation.extensionContainer
MAP | No | |
subscriberInfo.subscriberState
MAP | No | |
subscriberInfo.extensionContainer
MAP | No | |
extensionContainer
MAP | No |
