9 About Installation and Removal
This chapter provides information about the installed components for the Oracle Communications Convergent Charging Controller application described in this guide. It also lists the files installed by the application that you can check for, to ensure that the application installed successfully.
For information about the following requirements and tasks, see Installation Guide:
  • Convergent Charging Controller system requirements.
  • Pre-installation tasks.
  • Installing and removing Convergent Charging Controller packages.
ACS Packages
An installation of ACS includes the following packages, on the:
  • SMS:
    • acsSms
    • acsCluster (for clustered SMS)
  • SLC:
    • acsScp
  • VWS:
    • acsBe
Installing acsSms Packages on a Clustered SMS
Raw Devices
ACS can allocate tablespace storage based on raw (without a file system) partitions. This enhances the performance of ACS on the SMS.
If you are using the raw devices option, you must create the raw partitions before installing the database using tools such as the system’s format command.
The raw devices file (which you will be prompted to complete during the installation) must contain the full paths of the device files for the appropriate partitions.
The partitions must be at least as big as the required datafile sizes listed in the sizing file used by the installation.
Raw Devices Configuration
Follow these steps to configure raw devices:
This is required only if the installation uses raw devices in place of datafiles.
  1. If your database sizing was set to large, create disk partitions of the following sizes:
    • 2501 MB
    • 1501 MB
    • 1501 MB
    For more information about the format command, see man format.
    If your database sizing was set to medium, create disk partitions of the following sizes:
    • 7002 MB
    • 5002 MB
    • 4002 MB
    • 201 MB
    • 101 MB
    • 2 MB
  2. Edit the acs_devices.sh file specified above.
  3. Change the line:
    ACS_DATA_DATAFILE=
    to
    ACS_DATA_DATAFILE=/dev/did/rdsk/partition
    Where:
    partition is the name of the partition (for example. d8s0).
  4. Check the device files for the new partitions are readable and writable by the oracle user prior to commencing/continuing the installation.
    Example Command:
    chmod ugo+rw /dev/rdsk/d8s*
Example acs_devices.sh file
This is an example acs_devices.sh file.
#!/bin/sh
# The following file is the structure required for knowledge of
# raw device utilisation.
# Raw device specification for datafile paths.
ACS_DATA_DATAFILE=/dev/did/rdsk/d14s0
ACS_INDEX_DATAFILE1=/dev/did/rdsk/d14s1
ACS_INDEX_DATAFILE2=/dev/did/rdsk/d14s2
export ACS_DATA_DATAFILE ACS_INDEX_DATAFILE1 ACS_INDEX_DATAFILE2
Checking the Installation
Refer to these checklists to ensure that ACS has installed correctly. The end of the package installation process specifies a script designed to check the installation just performed. They must be run from the command line.
Checklist for SMS
Follow the steps to ensure ACS has been installed on an SMS machine correctly:
  1. Log in to SMS machine as root.
  2. Check the following directory structure exists with subdirectories:
    • /IN/service_packages/ACS
    • /IN/html/Acs_Service
  3. Check that directories contain subdirectories and that all are owned by:
    • acs_oper user (group oracle)
  4. Log into the system as acs_oper.
    This step is to check that the acs_oper user is valid
  5. Enter sqlplus /. No password is required.
    This step is to check that the acs_oper user has valid access to the database.
  6. Check the entries of the /etc/inittab file.
    Inittab Entries Reserved for ACS on SMS:
    1. acs0 /IN/service_packages/ACS/bin/acsCompilerDaemonStartup.sh (runs acsCompilerDaemon).
    2. acs1 /IN/service_packages/ACS/bin/acsStatisticsDBInserterStartup.sh(runs acsStatisticsDBInserter).
    3. acs2 /IN/service_packages/ACS/bin/acsProfileCompilerStartup.sh (runs acsProfileCompiler).
  7. Check that the processes listed in the process lists are running on the relevant machine. For a list of the processes which should be running, see Process list for SMS.
Checklist for SLC
Follow the steps in this checklist to ensure ACS has been installed on an SLC machine correctly.
  1. Log in to SLC machine as root.
    Inittab Entries Reserved for ACS on SLC:
    • acs3 /IN/service_packages/ACS/bin/acsStatsMasterStartup.sh (runs acsStatsMaster).
  7. Check that the processes listed in the process lists are running on the relevant machine. For a list of the processes which should be running, see Process list for SLC.
If the application is running correctly, the following processes should be running on each SMS:
  • Started from the inittab:
    • acsCompilerDaemonacs
    • StatisticsDBInserter
    • acsProfileCompiler
If the application is running correctly, the following processes should be running on each SLC:
    • acsStatsMaster
  • Started during SLEE startup:
    • slee_acs
System Manifest
Advanced Control Services (ACS) consists of several software processables and directories.
SMS Packages
The ACS application on the SMS will have the following directory structure in the directory /IN/service_packages/ACS.
Directory File Description
/bin
This directory contains run-time service processables and shell scripts.
acsCompilerDaemonStartup.sh Start up script.
Startup.sh
Start up script.
acsProfileCompiler
Startup.sh
Start up script.
acsLogCleanerStartup.sh Start up script.
acsDbCleanup.sh Start up script.
acsAddCallPlan NA
acsAddCustomer NA
acsAddGeography NA
acsAddServiceNumber NA
acsDecompile NA
acsMonitorCompiler NA
acsProfile NA
acsScheduleCallPlan NA
acsSetupAnnouncement NA
/db This directory contains install-time database scripts.
/etc This directory contains run-time configuration files.
/etc/inittab
This directory contains background processes.
acsCompilerDaemon Background process.
acsStatisticsDBInserter Background process.
acsProfileCompiler Background process.
/lib This directory contains run-time shared libraries and install-time shell scripts.
/tmp
This directory contains run-time and install-time log files.
acsCompilerDaemon.log Error log file.
acsStatisticsDBInserter.log Error log file.
acsProfileCompiler.log Error log file.
acsLogCleaner.log Error log file.
acsDbCleanup.sh.log Error log file.
/tmp/archive This directory contains archived log files.
SLC Packages
The ACS application on the SLC will have the following directory structure in the directory /IN/service_packages/ACS.
Directory Directory Files Description
/bin
acsStatsMasterStartup.sh Start up script.
acsDecompile NA
acsLogCleanerStartup.sh NA
acsProfile NA
acsStatsLocalSLEE NA
acsSLSStartup.sh NA
cmnPushFilesStartup.sh NA
pinLogFileCleanup.sh NA
acsTriggerIF NA
acsTriggerIF.sh NA
/etc/inittab
acsStatsMaster Background process.
/install This directory contains install-time scripts for optional SLEE rc.d auto-start.
/tmp
acsStatsMaster.log Error log file.
