4 Credit Control Requests
Introduction
Introduction
The DCD can send both session and event based credit control requests. The type used is determined by the CCS request made of the DCD , and the CCS configuration.
To enable the maximum interoperability with billing engines, the structure of the CCRs that the client sends (and the CCAs that it expects to receive) is highly configurable. This configuration is per CCS action type requested, so not all CCRs need have the same structure.
Non-configurable AVPs
AVP List descriptions
The first set of AVPs in any CCR or CCA are not determined by the structure config, but rather the current CCS state and the action requested.
These AVPs are:
| AVP Name | AVP Code | Data Type | Comment |
| Session-Id | 263 | UTF8String |
Format: DiameterIdentity;Unix time_t;SLEE_CallID where the time is the time of the first request. |
| Origin-Host | 264 | DiameterIdentity | Set from configuration |
| Origin-Realm | 296 | DiameterIdentity | Set from configuration |
| Destination-Realm | 283 | DiameterIdentity | From CCS configuration |
| Auth-Application-Id | 258 | Unsigned32 | Set from configuration |
| Service-Context-Id | 461 | UTF8String | Set from configuration |
| CC-Request-Type | 416 | Enumerated | All 4 values are used. |
| CC-Request-Number | 415 | Unsigned32 | Starts at 0, and consecutively incremented by each message of the session. |
| Destination-Host | 293 | DiameterIdentity | Set from configuration |
| User-Name | 1 | UTF8String | Not included in CCRs |
| CC-Sub-Session-Id | 419 | Unsigned64 | Not included in CCRs |
| Acct-Multi-Session-Id | 50 | UTF8String | Not included in CCRs |
| Origin-State-Id | 278 | Unsigned32 | Can be set from configuration. Due to the multiple process nature of slee_acs, this should not be set, and this AVP will then not be included. |
| Event-Timestamp | 55 | Time | The time of the request construction. |
Re-Authorization Answer (RAA)
DCD can be configured to handle Re-A uthorization Request (RAR) messages. Incoming RAR messages are converted to SLEE events for upstream processing by the DIAMETER Control Agent (DCA). When DCD receives an RAA response from DCA, that message is forwarded to the requesting server. If there is no matching session, DCD responds with DIAMETER_UNKNOWN_SESSION_ID. If RAR support is not configured, DCD responds with DIAMETER_COMMAND_UNSUPPORTED.
Structure Configurable AVPs
Structure configurable AVPs
The AVPs following the Event-Timestamp are massively configurable. The configuration defines a tree structure of which AVPs to include, which CCS variables they represent, and how they are formatted. There is separate configuration for each CCS action involved. The CCS actions for which CCRs can be configured are:
- ConfirmNamedEventReservation
- ConfirmTimeReservation
- DirectNamedEvent
- DirectTimeCharge
- ExtendTimeReservation
- GetNamedEventRates
- InitialTimeReservation
- NamedEventReservation
- RevokeNamedEventReservation
- RevokeTimeReservation
- WalletInfo
- CreateEDR
- WalletRecharge
ccsConcepts
To match an AVP to a variable in CCS, the DCD has "ccsConcepts". These can be a specific parameter of the CCS action, a general CCS variable, some of the call's context, or even an ACS profile value.
The DCD provides functionality to scale values by a factor, and also allows a mapping of one set of integers to another while reading/writing to CCS concepts. The specific formatting of the value field is quite configurable, see the Diameter Charging Driver Technical Guide for formatting details.
Note: All concepts are available to be set from Responses. The availability only refers to requests.
The complete list of CCS concepts that are available to CCRs/CCAs is:
| Concept Label | Availability | Comment |
| acsCallID | always | The call ID from the SLEE |
| acsProductType | always | The ACS product type ID |
| acsServiceProvider | always | The ACS service provider ID |
| acsSubscriber | always | The CCS subscriber ID |
| acsSubscriberReference | always | The CCS subscriber number (ie their MSISDN) |
| acsWallet | always | The CCS wallet ID (BE_WALLET.ID) |
| acsWalletReference | always | The CCS wallet Reference (the Billing System's reference to the wallet) |
| acsWalletType | always | The CCS wallet type. (CCS_WALLET_TYPE.ID) |
| acsChargingDomain | always | The destined billing domain (logical collection of wallets) for this request. |
| acsTariffCode | After an initial reservation. | Tariff Code string returned in the Initial Reservation Response (if present). |
| acsUnnormalisedCalledNumber | always | The called party number digits from the IDP, without any attempt at normalization. |
| acsProfile | always | An ACS profile buffer from the Call plan. If the buffer is not set, then the AVP is not included. |
| discountMaxCharge | After a setDiscount | Present after a setDiscount node or a response that has the discountMaxCharge present. |
| discountPeriod | After a setDiscount | Present after a setDiscount node or a response that has the discountPeriod present. |
| tariffPlan | After a setTariffPlan | Integer representing the tariff Plan. |
| tariffCugName | After a setTariffPlan | The Closed User Group Name. |
| cascade | After a setCascade Override. | Also can be set by previous responses. The integer ID of the cascade to apply. |
| chargeInfoBalanceType | After a chargeInfo response | The CCS ID of the balance Type for the current balance of the Charge structure. |
| chargeInfoBalanceUnitType | After a chargeInfo response | The CCS ID of the balance Unit for the current balance of the Charge structure. This is not necessary for a ChargeInfo in a response, it can be derived from the balance type. |
| chargeInfoBalanceSystemValue | After a chargeInfo response | The balance Unit for the current item of the Charge structure. This is in units of the system currency. |
| chargeInfoBalanceUserValue | After a chargeInfo response | The balance Unit for the current item of the Charge structure. This is in units of the user's currency. Note that the system currency value is mandatory, while this entry is optional. |
| walletInfoBalanceUnitType | After a walletInfo response | The CCS ID of the balance Unit for the current balance item of the Wallet structure. This is not necessary for a balance in a response, it can be derived from the balance type. |
| walletInfoBalanceType | After a walletInfo response | The CCS ID of the balance Type for the current balance of the Wallet structure. |
| walletInfoBalanceSystemValue | After a walletInfo response | The balance Unit for the current item of the balance structure. This is in units of the system currency. |
| walletInfoBalanceUserValue | After a walletInfo response | The balance Unit for the current item of the balance structure. This is in units of the user's currency. Note that the system currency value is mandatory, while this entry is optional. |
| walletInfoBalanceExpiry | After a walletInfo response | The expiry date (in time_t) of the current balance. The DCD handles conversion from time_t to DIAMETER times. |
| walletInfoBalanceMaxCredit | After a walletInfo response | The maximum amount of credit allowed for this subscriber. |
| walletInfoBalanceLimitType | After a walletInfo response | The balances limit type: An integer representing one of: limitedPostpaid, postpaid, prepaid, singleUsePrepaid |
| walletInfoBalanceExponent | After a walletInfo response | An exponent to apply to the balance system value. |
| walletInfoExpiry | After a walletInfo response | The expiry date (in time_t) of the wallet. The DCD handles conversion from time_t to DIAMETER times. |
| walletInfoState | After a walletInfo response | A single character representing the wallet's state. One of: 'A' = Active, 'D' = Dormant, 'F' = Frozen, 'P' = Pre-Use, 'S' = Suspended, 'T' = Terminated. Note that conversion to different representations is possible. |
| walletInfoLastAccess | After a walletInfo response | time_t of the wallet's last access. The DCD handles conversion from time_t to DIAMETER times. |
| walletInfoActivationDate | After a walletInfo response | time_t of the wallet's activation date. The DCD handles conversion from time_t to DIAMETER times. |
| walletInfoMaxConcurrent | After a walletInfo response | The maximum number of concurrent users allowed for this wallet. |
| walletInfoSystemCurrency | After a walletInfo response | The system currency. |
| walletInfoUserCurrency | After a walletInfo response | The CCS_ACCT.CURRENCY value for this wallet. |
| cli | After a DirectTimeCharge or InitialTimeReservation | |
| destinationNumber | After a DirectTimeCharge or InitialTimeReservation | |
| callerTimeZone | After a DirectTimeCharge or InitialTimeReservation | |
| expectedReservationTotal | InitialTimeReservation and ExtendTimeReservation | |
| expectedReservationDelta | InitialTimeReservation and ExtendTimeReservation | |
| callDurationTotal | Any Time Charging Action | |
| callDurationDelta | Any Time Charging Action | |
| lowCreditBuffer | After set from a response | Usually part of an initialTimeReservationResponse. Number of seconds from the end of the last good reservation period until a low credit beep should be played |
| freeCallDisposition | After set from a response | Usually part of an initialTimeReservationResponse. |
| singleReservation | After set from a response | Usually part of an initialTimeReservationResponse. |
| initialLowBalanceIndicator | After set from a response | Usually part of an initialTimeReservationResponse. If present and non zero the indicated pre call warning announcement should be played to the subscriber. |
| initialLowBalanceAnnouncement | After set from a response | Usually part of an initialTimeReservationResponse. The Announcement ID of the announcement to play. |
| maxCallLength | After set from a response | Usually part of an initialTimeReservationResponse. |
| retrieveLCRNumbers | After set from a response | Usually part of an initialTimeReservationResponse. |
| validityPeriod | After set from a response | |
| reservedLengthTotal | After set from a response | Usually part of an xxxTimeReservationResponse. |
| reservedLengthDelta | After set from a response | Usually part of an xxxTimeReservationResponse. |
| timeReservationStatus | After set from a response | Usually part of an xxxTimeReservationResponse. |
| maxSeconds | After set from a response | Session Time left. Usually part of an xxxTimeReservationResponse. |
| callAnsweredTime | ConfirmTimeReservation | |
| confirmTimeReservationStatus | After set from a response | Usually part of an confirmTimeReservationResponse. |
| revokeTimeReservationStatus | After set from a response | Usually part of an revokeTimeReservationResponse. |
| eventClass | NamedEvent Actions | A string representing the CCS event Class. |
| eventName | NamedEvent Actions | A string of the CCS event name. |
| eventType | NamedEvent Actions | An integer representing the type of CCS named event. |
| minUnitsRequested | NamedEvent Actions | |
| maxUnitsRequested | NamedEvent Actions | |
| discountPercentage | After a setDiscount or DirectNamedEvent or NamedEventReservation | Present after a setDiscount node or a response that has the discountPeriod present. |
| extraInformation | Usually call information for adding to Billing EDRs. Contents varies for each action. | |
| ignoreBalanceLimit | DirectNamedEvent, DirectTimeCharge, NamedEventReservation | |
| numUnitsGranted | After set from a response | |
| numUnitsUsed | ConfirmNamedEventReservation | |
| ratingPrecision | InitialTimeReservation | Integer representing one of seconds, tenths-of-a-second or hundredths-of-a-second |
| callDate | DirectTimeCharge | |
| balanceUnitFilter | WalletInfo | Request the billing engine to only return balances of this unit. |
| balanceTypeFilter | WalletInfo | Request the billing engine to only return balances of this type. |
| setFreeform | always | The next AVP of concept "freeform" will instead use/update the concept indexed by the value of this AVP. |
| freeform | always | Uses/updates the concept previously defined by setFreeform. |
| voucherInfoVoucher | After a VoucherRedeem response | The ID of the voucher that was redeemed (for example in the Voucher Management system). Not to be confused with voucher number as known to customer – that will normally be available as a profile variable set or captured in the control plan. |
| voucherInfoWalletExpiryExtension | After a VoucherRedeem response | How much of an extension to apply to the wallet (expressed in units of time given by VoucherInfoWalletExpiryExtensionType). |
| voucherInfoWalletExpiryExtensionType | After a VoucherRedeem response | Specifies the unit of time referred to by the value in voucherInfoWalletExpiryExtension. Hours (0) or Months (1). |
| voucherInfoWalletExpiryExtensionPolicy | After a VoucherRedeem response |
An enumeration that shows how the wallet expiry is to be updated by a voucher redemption: best = 0 extend extendFromToday override dontChange |
| voucherInfoBalanceType | After a VoucherRedeem response | This is the ID of the CCS balance type of the current VoucherValue ‘slot’ in the VoucherInfo structure, obtained from the last voucher redemption. |
| voucherInfoValue | After a VoucherRedeem response | This is the monetary value from the current VoucherValue ‘slot’ in the VoucherInfo structure, obtained from the last voucher redemption. |
| voucherInfoBalanceExpiryExtension | After a VoucherRedeem response | How much of an extension to apply to the wallet balance referred to by the current VoucherValue ‘slot’ in the VoucherInfo structure (expressed in units of time given by VoucherInfoBalanceExpiryExtensionType). |
| voucherInfoBalanceExpiryExtensionType | After a VoucherRedeem response | Specifies the unit of time referred to by the voucherInfoBalanceExpiryExtension value in the current VoucherValue ‘slot’ of the VoucherInfo structure. Hours (0) or Months (1). |
An enumeration that shows how the current voucher value balance expiry is to be updated by a voucher redemption:
| voucherInfoNewBucket | After a VoucherRedeem response | States whether the money amount from the current VoucherValue ‘slot’ of the VoucherInfo structure should be stored in a new bucket ir added to an existing one. |
| voucherInfoMissingBalancePolicy | After a VoucherRedeem response |
States how to handle the lack of any existing balance of this type in the wallet:
| voucherInfoReplaceBalance | After a VoucherRedeem response | Specifies whether or not the current voucher value replaces any existing balance of that type in the wallet. |
| scpAction | Set after a response |
For handling CCAs only. May be set based on an enumerated AVP to indicate combinations of:
Where such an enumerated AVP exists, it may appear more than once with different values. This will result in DCD context values (booleans) being set according to each of the above names. These boolean values may be copied back into profile locations using the ContextCopy section in eserv.config, for the purposes of branching within control plans. See Diameter Charging Driver Technical Guide for further details. |
Balance structure limitations
There is a small limitation to the flexibility of AVP structures to define balances. Multiple balances are allowed for charge, wallet and voucher information, but all properties of the balance must be grouped together.
Basically, CCS must parse all information about a particular balance before parsing a different balance. So two grouped AVPs of balance value and balance type is fine, but a grouped AVP of all balance values and another grouped AVP of all balance types cannot be parsed by CCS.
This approach was established for the BalanceInfo transaction, and has been followed for the management of VoucherInfo structures, which define the proceeds from a voucher redemption. The information comprises a set of wallet information, and a recurring set of VoucherValue structures that each identify how to update a single wallet balance type. Accordingly CCS must parse all information about a particular voucher value before parsing fields from a different one.
Configuring different types of DirectNamedEvent
This CCS action allows for highly configurable types of billing even to be triggered by the SLC. It is obviously desirable to be able to configure different AVPs for different types of DirectNamedEvent. The feature node that is used to emit a DirectNamedEvent is told what type of event it should trigger, categorized by event class (a kind of subject matter grouping) and event name. Both aspects are fully configurable in the CCS screens.
To make the DNE action more useful, its DCD implementation looks first for a request AVP named DirectNamedEventRequest-xxx, where xxx is the configured name of the CCS named event.
- If one is found, it is used to generate the outgoing AVP.
- If none is found, the code then falls back to the more general "DirectNamedEventRequest".
A similar logic applies to the processing of responses: that is, DCD looks first for DirectNamedEventResponse-xxx, then DirectNamedEventResponse.
Result Code Mapping
Introduction
The mapping of DIAMETER result codes to CCS node responses is not configurable, and depends on the CCS Action involved.
Initial time reservation
This table lists the mapped responses for initial time reservation.
| DIAMETER Result Code | InitialTimeReservationResponse |
| DIAMETER_SUCCESS | success |
| DIAMETER_LIMITED_SUCCESS | success |
| DIAMETER_UNABLE_TO_DELIVER | declineCommunicationError |
| DIAMETER_CREDIT_LIMIT_REACHED | declineInsufficientFunds |
| DIAMETER_USER_UNKNOWN | declineUnknownWallet |
| DIAMETER_END_USER_SERVICE_DENIED | declineCallRestricted |
| DIAMETER_CREDIT_CONTROL_NOT_APPLICABLE | freecall |
| DIAMETER_RATING_FAILED | declineSystemError |
| all others | declineSystemError |
Extend time reservation
This table lists the mapped responses for extend time reservation.
| DIAMETER_END_USER_SERVICE_DENIED | declineSystemError |
Confirm time reservation
This table lists the mapped responses for confirm time reservation.
| DIAMETER_END_USER_SERVICE_DENIED | declineWalletDisabled |
Revoke time reservation
This table lists the mapped responses for revoke time reservation.
Named event reservation
This table lists the mapped responses for named event reservation.
| DIAMETER_CREDIT_CONTROL_NOT_APPLICABLE | declineSystemError |
| DIAMETER_END_USER_SERVICE_DENIED | declineNotAllowed |
Confirm named event reservation
This table lists the mapped responses for confirm named event reservation.
Revoke named event reservation
This table lists the mapped responses for revoke named event reservation.
| all others | failed |
Direct named event
This table lists the mapped responses for direct named event.
Direct time charge
This table lists the mapped responses for direct time charge.
Get named event rates
This table lists the mapped responses for get named event rates.
| DIAMETER_CREDIT_CONTROL_NOT_APPLICABLE | success |
| DIAMETER_RATING_FAILED | rateNotAvailable |
Wallet Info
This table lists the mapped responses for wallet info.
