6 About Installation and Removal
This chapter provides information about the installed components for the Oracle Communications Convergent Charging Controller application described in this guide. It also lists the files installed by the application that you can check for, to ensure that the application installed successfully.
Installation and Removal Overview
For information about the following requirements and tasks, see Installation Guide:
  • Convergent Charging Controller system requirements.
  • Pre-installation tasks.
  • Installing and removing Convergent Charging Controller packages.
DCD Packages
An installation of DCD includes the following packages, on the:
  • SMS
  • dcdSms
  • SLC
  • dcdScp
Checking the Installation
Refer to these check lists to ensure the package has been installed correctly.
DCD SLC Directories and Files
The DCD installation on the SLC creates the following directories:
  • /IN/service_packages/DCD/bin
  • /IN/service_packages/DCD/etc
  • /IN/service_packages/DCD/lib
  • /IN/service_packages/DCD/tmp
The DCD installation installs the following binaries and interfaces:
  • /IN/services_packages/DCD/bin/diameterBeClient
The DCD installation installs the following example configuration file:
  • /IN/services_packages/DCD/etc/eserv.config.dcd.example
The DCD installation installs the following shared library:
  • /IN/services_packages/DCD/lib/diamActions.so
DCD SMS Directories
Check that the statistics and control plans have been installed correctly.
The DCD installation on the SMS creates the following directories:
  • /IN/service_packages/DCD/db
