3 SCAP Compliance
This chapter explains the summary of changes that affect DCD to make it SCAP compliant.
SCAP
Ericsson SCAP is a vendor specific protocol that utilizes the Draft version 8 of the Diameter Base Protocol (the predecessor to RFC 3588).
The Convergent Charging Controller Diameter protocol is based upon the final version of RFC 3588. The base protocol is further extended to support the use of CCR (Credit-Control-Request) / CCA (Credit-Control-Answer) messages, described by RFC 4006.
SCAP, on the other hand, adds Attribute Value Pair (AVP)s to Diameter base protocol’s Accounting-Request (ACR) and Accounting-Answer (ACA) commands.
DCD may be reconfigured to permit it to interact with an Ericsson SCAP compliant server as a SCAP client. Variances between the SCAP and normal Credit-Control charging approaches available within DCD are described below.
The necessary changes will take effect only if the enableDraft8 is set totrue.
Application-Identifiers Values
This table lists the different Application-identifier values between the Diameter Base Protocol Draft 8 and RFC 3588 final version.
Table 3-1 Comparison of Application-Identifier Values in Diameter Base Protocol Draft 8 and RFC 3588
| Draft 8 | Final |
| - | Diameter Common Messages 0 |
| NASREQ 1 | NASREQ 1 |
| CMS Security 2 | Mobile-IP 2 |
| Mobile IP 4 | - |
| Relay 0xffffffff | Relay 0xffffffff |
Message Header
This table describes the changes to message header values.
Table 3-2 Message Header Values
| Section Heading | Comment |
| Vendor-Id |
This should be changed in outbound messages (at the Oracle Diameter stack level). See Vendor-Id for SCAP specific changes. |
| T-flag |
The T-flag (retransmit) is used by a Diameter client to indicate to the server that a message has been retransmitted (possibly due to loss of message). This flag is not supported by Draft 8, and hence it is not set while retransmitting duplicate DCD messages to SCAP. |
Supported AVPs
This table describes the changes to the supported AVPs to enable SCAP compliance.
Table 3-3 Supported AVPs
| Supported AVP | Comment |
| Event-Timestamp | DCD to send vendor specific version for Ericsson SCAP. |
| Inband-Security-Id | This AVP is not sent during capabilities exchange, if SCAP
support is configured, that is, when enableDraft8 is set to
true.
Result-Codes
This table describes the changes to the Result-Codes to enable SCAP compliance.
Table 3-4 Result Code Changes for SCAP Compliance
| Result Code | [DRAFT8] Value | [3588] Value |
| DIAMETER_UNSUPPORTED_TRANSFORM | 5010 | - |
| DIAMETER_NO_COMMON_APPLICATION | 5011 | 5010 |
| DIAMETER_UNSUPPORT_VERSION | 5012 | 5011 |
| DIAMETER_UNABLE_TO_COMPLY | 5013 | 5012 |
| INVALID_BIT_IN_HEADER | 5014 | 5013 |
| INVALID_AVP_LENGTH | 5015 | 5014 |
| INVALID_MESSAGE_LENGTH | 5016 | 5015 |
| INVALID_AVP_BIT_COMBO | 5017 | 5016 |
| DIAMETER_NO_COMMON_SECURITY | - | 5017 |
