17 Change 'Disable Incoming Calls when Roaming' Flag
DICWR Flag Change Succeeds using Screens (EDR 29)
Mandatory EDR 29 fields
This list identifies the mandatory EDR record fields for a successful DICWR change using screens (EDR type 29):
- ACCOUNT_TYPE (Product Type ID)
- ACS_CUST_ID (ACS Customer ID)
- CLI (for the account that will be changed)
- DICWR (Disable Incoming Calls When Roaming)
- USER (operator logon name)
- WALLET_TYPE (ID of wallet recharged)
MSISDN additional fields
If the MSISDN ccsCDRLoader plug-in is installed on the SMS, the following field will be present:
- MSISDN (account calling number)
DICWR Flag Change Succeeds using PI (EDR 29)
This list identifies the mandatory EDR record fields for a successful DICWR change using PI (EDR type 29):
- PI (logon name and IP address)
Example EDR 29
BILLING_ENGINE_ID=2|SCP_ID=110537566|SEQUENCE_NUMBER=1061|CDR_TYPE=29|RECORD_DATE=20070809120324|ACCT_ID=1032|ACCT_REF_ID=1032|CLI=11023|ACS_CUST_ID=1|WALLET_TYPE=1|PI=adminat192.168.25.108|DICWR=TRUE|MSISDN=11023|ACCOUNT_TYPE=24
