5 Voucher Recharges
Overview
Introduction
This chapter defines the CCS EDRs for voucher recharges.
Voucher Recharge Succeeds using Screens (EDR 4,15)
Introduction
Two or three EDRs are created for this event:
  • A type 4
  • A type 15
  • A type 16 when the Rewards plug-in is being used. See Rewards chapter for the EDR definition.
Mandatory EDR 4 fields
This list identifies the mandatory EDR record fields for voucher recharge succeeds using screens (EDR type 4):
  • ACCOUNT_TYPE (Product Type ID)
  • ACS_CUST_ID (ACS Customer ID)
  • BALANCE_TYPES (existing account)
  • BALANCES (pre-transaction account balances)
  • BATCH_DESCRIPTION (for voucher batch)
  • COSTS (rated calls)
  • CS (call status, S or D) (call status, S or D)
  • NEW_ACCT_EXPIRY (date after update)
  • NEW_BALANCE_EXPIRIES (dates after voucher recharge)
  • OLD_ACCT_EXPIRY (dates before update)
  • OLD_BALANCE_EXPIRIES (dates before voucher recharge)
  • TERMINAL (Network ID)
  • TYPE_DESCRIPTION (voucher type)
  • USER (operator logon name)
Optional EDR 4 fields
If they are not present, the ccsCDRLoader voucher plug-in does not process the EDR. For more information about ccsCDRLoader, see Process descriptions.
This list identifies the optional EDR record fields for voucher recharge succeeds using screens (EDR type 4):
  • REFERENCE (voucher freeform)
  • VOUCHER - one of:
    • VOUCHER (ID of redeemed voucher)
    • VOUCHER (serial number of redeemed voucher - 3.1.5)
Mandatory EDR 15 fields
This list identifies the mandatory EDR record fields for voucher recharge succeeds using screens (EDR type 15):
  • BALANCE_EXPIRIES (period hours)
  • REDEEMING_ACCT_REF (ID of account)
  • RESULT (voucher redemption, always Success)
  • VOUCHER - one of:
Optional EDR 15 fields
This list identifies the optional EDR record fields for voucher recharge succeeds using screens (EDR type 15):
  • NEW_ACCOUNT (ID of account type)
  • OLD_ACCOUNT (ID of account type)
  • REDEEMING_ACCT_TYPE (name of account type)
  • SCENARIO (voucher scenario number)
  • REDEEMING_SUBSCRIBER_ID (subscriber ID)
Account Activated additional fields
If the account is activated, the following fields are generated:
  • NEW_ACCT_STATE (always active - A)
  • OLD_ACCT_STATE (P or D before update)
Reload Bonus additional fields
If the account has a promotional reload bonus configured, the following fields are generated (EDR types 4, 15 and 16):
  • RELOAD_BONUS (promotion name)
  • RELOAD_BONUS_AMOUNT (amount applied)
  • RELOAD_BONUS_EXPIRY (date remaining bonus expires)
  • RELOAD_BONUS_LEFT (bonus amount remaining)
MSISDN additional fields
If the MSISDN ccsCDRLoader plug-in is installed on the SMS, the following field will be present:
  • MSISDN (account calling number)
Example EDR 4
BILLING_ENGINE_ID=21|SCP_ID=110537566|SEQUENCE_NUMBER=139450184|CDR_TYPE=4|
RECORD_DATE=20040803152956|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|
VOUCHER=7609766|VOUCHER_NUMBER=0000000067|CS=S|USER=SU| ACCOUNT_TYPE=1|
BALANCE_TYPES=1|BALANCES=1001800|COSTS=-1000|NEW_BALANCE_EXPIRIES=|
OLD_BALANCE_EXPIRIES=0
Example EDR 15
BILLING_ENGINE_ID=21|SCP_ID=110537566|SEQUENCE_NUMBER=139450184|CDR_TYPE=15|
RECORD_DATE=20070719111321|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|REDEEMING_ACCT_REF=61|VOUCHER=7608766|VOUCHER_NUMBER=0000000067|RESULT=Success|BALANCE_TYPES=1|COSTS=-1000|BALANCE_EXPIRIES=|ACCOUNT_TYPE=24
If the useVoucherRedeemCDR parameter in the ccsCDRLoader section of eserv.config in SMS is set as true, then additional voucher related fields are also returned as shown in the below example:
BILLING_ENGINE_ID=42|SCP_ID=55771394|SEQUENCE_NUMBER=0|CDR_TYPE=15|RECORD_DATE=20180328121357|ACCT_ID=3|ACCT_REF_ID=4|ACS_CUST_ID=21|REDEEMING_ACCT_REF=4|REDEEMING_ACCT_TYPE=21|RESULT=Success|VOUCHER=184|VOUCHER_NUMBER=60045|BALANCE_TYPES=78|COSTS=-10|BALANCE_EXPIRIES=|USER=SU|TERMINAL=10.191.235.82|WALLET_TYPE=5|BARCODE=12|TEXT=adding|CARD_DESIGN=90|DISTRIBUTOR_CHANNEL=fields|RETAIL_CHANNEL=for a|FREE_TEXT_FIELD_1=CDR|FREE_TEXT_FIELD_2=test|FREE_TEXT_FIELD_3=case|PROVISIONING_DATE=20180313091814
Note
The sequence of all fields output in an EDR is not guaranteed.
Voucher Recharge Succeeds using IVR (EDR 4,15)
Introduction
  • A type 4
  • A type 15
This list identifies the mandatory EDR record fields for voucher recharge succeeds using IVR (EDR type 4):
  • WALLET_TYPE (ID of wallet changed)
This list identifies the optional EDR record fields for voucher recharge succeeds using IVR (EDR type 4):
  • VOUCHER - one of:
This list identifies the mandatory EDR record fields for voucher recharge succeeds using IVR (EDR type 15):
  • VOUCHER - one of:
This list identifies the optional EDR record fields for voucher recharge succeeds using IVR (EDR type 15):
Example EDR 4
BILLING_ENGINE_ID=21|SCP_ID=366273322|SEQUENCE_NUMBER=488297|
CDR_TYPE=4|RECORD_DATE=20040804103532|ACCT_ID=61|ACCT_REF_ID=61|
ACS_CUST_ID=1|VOUCHER=7609766|VOUCHER_NUMBER=0000000081|CS=S|
 WALLET_TYPE=1|ACCOUNT_TYPE=1|BALANCE_TYPES=1|BALANCES=1005800|
COSTS=-1000|NEW_BALANCE_EXPIRIES=|OLD_BALANCE_EXPIRIES=0
Example EDR 15
CDR_TYPE=15|RECORD_DATE=20040803152952|ACCT_ID=61|ACCT_REF_ID=61|
ACS_CUST_ID=1|REDEEMING_ACCT_REF=61|VOUCHER=7609766|VOUCHER_NUMBER=0000000081| RESULT=Success
Note
Voucher Recharge Succeeds using PI (EDR 4,15)
Introduction
  • A type 4
  • A type 15
  • A type 16 when the Rewards plug-in is being used.. See Rewards chapter for the EDR definition.
This list identifies the mandatory EDR record fields for voucher recharge succeeds using PI (EDR type 4):
  • PI (logon name and IP address)
This list identifies the optional EDR record fields for voucher recharge succeeds using PI (EDR type 4):
  • VOUCHER - one of:
This list identifies the mandatory EDR record fields for voucher recharge succeeds using PI (EDR type 15):
  • VOUCHER - one of:
This list identifies the optional EDR record fields for voucher recharge succeeds using PI (EDR type 15):
Example EDR 4
BILLING_ENGINE_ID=21|SCP_ID=161986004|SEQUENCE_NUMBER=2|CDR_TYPE=4|
RECORD_DATE=20040804111124|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|
VOUCHER=7609766|VOUCHER_NUMBER=0000000086|CS=S|PI=adminAT192.168.25.106|
 WALLET_TYPE=1|ACCOUNT_TYPE=1|BALANCE_TYPES=1|BALANCES=1006800|
Example EDR 15
ACS_CUST_ID=1|REDEEMING_ACCT_REF=61|VOUCHER=7609766|VOUCHER_NUMBER=0000000086|RESULT=Success
Note
Voucher Recharge Succeeds using USSD (EDR 4,15)
Introduction
  • A type 4
  • A type 15
  • A type 16 when the Rewards plug-in is being used. See the Rewards chapter for the EDR definition.
This list identifies the mandatory EDR record fields for voucher recharge succeeds using USSD (EDR type 4):
This list identifies the optional EDR record fields for voucher recharge succeeds using USSD (EDR type 4):
  • VOUCHER - one of:
This list identifies the mandatory EDR record fields for voucher recharge succeeds using USSD (EDR type 15):
  • VOUCHER - one of:
This list identifies the optional EDR record fields for voucher recharge succeeds using USSD (EDR type 15):
Example EDR 4
BILLING_ENGINE_ID=1|SCP_ID=114207220|SEQUENCE_NUMBER=139450184|CDR_TYPE=4|
RECORD_DATE=20041216162449|ACCT_ID=46|ACCT_REF_ID=46|ACS_CUST_ID=1|
VOUCHER=7609766|VOUCHER_NUMBER=23439221779469|CS=S|
USSD=VOUCHER_REDEEMED|ACCOUNT_TYPE=23|BALANCE_TYPES=1|
BALANCES=113495,113495|COSTS=1,-20500|NEW_BALANCE_EXPIRIES=,|
OLD_BALANCE_EXPIRIES=0,0|RELOAD_BONUS_AMOUNT=500|
RELOAD_BONUS_LEFT=113494
Example EDR 15
ACCT_REF_ID=61| ACS_CUST_ID=1| REDEEMING_ACCT_REF=61|
VOUCHER=7609766|VOUCHER_NUMBER=0000000086| RESULT=Success
Note
Voucher Recharge Fails using Screens or IVR (EDR 4)
Introduction
In this scenario, recharge fails because the account is in either a frozen or suspended state.
A type 4 EDR is created for this event.
This list identifies the mandatory EDR record fields for voucher recharge failures using screens or IVR (EDR type 4):
  • CS (call status, always D)
  • NACK (long list of codes)
  • RESULT (frozen or suspended)
This list identifies the optional EDR record fields for voucher recharge failures using screens or IVR (EDR type 4):
  • VOUCHER - one of:
Example EDR 4
RECORD_DATE=20040804105430|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|
VOUCHER=7609766|VOUCHER_NUMBER=0000000085|CS=D|RESULT=Frozen Wallet
Note
Voucher Recharge Fails using Screens or IVR (EDR 15,33)
Introduction
The recharge fails because the voucher details entered are invalid or the voucher is in an invalid state. There are two EDR records created for this event:
  • A EDR of type 15
  • A EDR of type 33
This list identifies the mandatory EDR record fields for voucher recharge failure using screens or IVR (EDR type 15):
  • RESULT (general cause)
  • VOUCHER - one of:
    • VOUCHER_NUMBER (redeemed voucher)
This list identifies the optional EDR record fields for voucher recharge failures using screens or IVR (EDR type 15):
Mandatory EDR 33 fields
This list identifies the mandatory EDR record fields for voucher recharge failure using screens or IVR (EDR type 33):
  • ACS_CUST_ID
  • BAD_PINS
  • TERMINAL
  • USER
Optional EDR 33 fields
This list identifies the optional EDR record fields for voucher recharge failures using screens or IVR, when the account is frozen due to the maximum number of bad pins being exceeded (EDR type 33):
  • NEW_ACCT_STATE (frozen)
  • OLD_ACCT_STATE (active)
Example
BILLING_ENGINE_ID=21|SCP_ID=366273322|SEQUENCE_NUMBER=488298|CDR_TYPE=15|RECORD_DATE=20070719113914|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|REDEEMING_ACCT_REF=61|VOUCHER=8709766|VOUCHER_NUMBER=0000000086|BATCH_DESCRIPTION=Test Batch|TYPE_DESCRIPTION=STANDARD|RESULT=Failed Auth|ACCOUNT_TYPE=24|USER=SU|TERMINAL=192.168.25.108
Example EDR 33
BILLING_ENGINE_ID=21|SCP_ID=366273322|SEQUENCE_NUMBER=488298|CDR_TYPE=33|RECORD_DATE=20070703145823|ACCT_ID=61|ACCT_REF_ID=61|BAD_PINS=1|ACS_CUST_ID=1|ACCOUNT_TYPE=24|USER=SU|TERMINAL=192.168.25.108
Note
Voucher Type Recharge
Introduction
A type 47 EDR is created for this event.
Note: The type 47 EDR contains fields identical to a type 4. It is given its own EDR number because it is handled differently from a normal voucher recharge. A type 4 EDR generates a recharge notification from the EDR loader plug-in. In the case of the type 47, the notification is generated by the process calling it. This process can be a control plan, periodic charge or a credit transfer.
Mandatory EDR 47 fields
This list identifies the mandatory EDR record fields for voucher type recharge (EDR type 47):
  • VOUCHER_TYPE (name)
Optional EDR 47 fields
This list identifies the optional EDR record fields for voucher type recharge (EDR type 47):
  • NEW_ACCT_TYPE (ID of account after recharge)
  • OLD_ACCT_TYPE (ID of account before recharge)
