3 Background Processes
This chapter explains the process which runs automatically as part of the Oracle Communications Convergent Charging Controller application. This process is started automatically by the system services (/IN/bin/OUI_systemctl.sh) in the SLC node.
RESTClient
Purpose
The RESTClient (REST) interface is used to trigger REST requests towards REST server endpoints.
Startup
This task is started by the system services, by the following line in the service files:
/IN/service_packages/REST/bin/RestClientStartup.sh config.json
Configuration
The high-level structure of the REST client is shown below:
"maxthreadcount": 1000,
"port": 4050,
"webroot": "/tmp",
"walletlocation": "Location",
"walletkey": "key",
"restendpoint": {
"BalanceTransfer" : {
"endpoint" : "BalanceTransferEndpoint",
"servergroupid" : "BRM",
"resourceid": 840,
"chargesource": false,
"chargedestination": false
"ApplyLoan" : {
"endpoint" : "ApplyLoanEndpoint",
"serviceType" : "/service",
"servergroupid" : "BillingCare",
"resourceid": 840
"GenericRequest" : {
"endpoint" : "GenericRequestEndpoint",
"type" : "POST",
"serverlist": {
"BRM": {
"tokenendpoint":"BRMOAuthEndpoint",
"clientid":"username"
"BillingCare": {
"tokenendpoint":"BCOAuthEndpoint",
Parameters
Parameters of the REST client are listed below.
maxthreadcount
| Syntax: | maxthreadcount:
"value" |
| Description: | Maximum number of thread the java process can have. |
| Type: | Integer |
| Optionality: | Optional |
| Allowed: | NA |
| Default: | 1000 |
| Example: | maxthreadcount: "1000" |
port
| Syntax: | port: "value" |
| Description: | Port on which REST client is listening to DAP requests. |
| Type: | Integer |
| Allowed: | NA |
| Default: | 4050 |
| Example: | port: "4050" |
webroot
| Syntax: | webroot: "value" |
| Description: | Path to which client will be listening. When “/” is specified, the client will be listening to “http://localhost:port/”. In API, “/” should be present at the end in the DAP configuration screen. |
| Type: | String |
| Allowed:: | NA |
| Default: | "/" |
| Example: | webroot: "/tmp" |
walletlocation
| Syntax: | walletlocation:
"value" |
| Description: | Location where the wallet is created, which stores the REST endpoint username and password. |
| Type: | String |
| Allowed: | NA |
| Default: | "/IN/service_packages/REST/etc/wallet" |
| Example: | walletlocation:
| Syntax: | walletkey= "value" |
| Description: | Base64 encrypted password for the wallet. |
| Type: | String |
| Optionality: | Mandatory |
| Allowed: | NA |
| Default: | “” |
| Example: | walletkey: "key” |
| Syntax: |
| Description: | Group of REST operations. |
| Type: | JSON |
| Allowed: | NA |
| Default: | NA |
| Example: |
| Syntax: | endpoint: "value" |
| Description: | Endpoint to which the request is triggered. |
| Type: | String |
| Allowed: | NA |
| Default: | “” |
| Example: | endpoint:
"http:localhost:restopertion/" |
| Syntax: | type: "value" |
| Description: | The type of request. This applies to GenericRequest handler only. |
| Type: | String |
| Allowed: | The allowed values are:
| Default: | POST |
| Example: | type: "POST" |
| Syntax: | servergroupid: "value" |
| Description: | ID of the oauth credential present in serverlist. |
| Type: | String |
| Allowed: | Servergroupid should be present in the
serverlist, so that corresponding oAuth
endpoint and clientid is used to generate the token.
| Default: | “” |
| Example: | servergroupid: "BRM" |
| Syntax: | resourceid: "value" |
| Description: | Resourceid used for requesting BalanceTransfer and ApplyLoan. |
| Type: | Integer |
| Allowed: | Only used in BalanceTransfer and ApplyLoan. |
| Default: | 840 |
| Example: | resourceid: "840" |
| Syntax: | chargesource: "Boolean" |
| Description: | This is a boolean flag to indicate whether the
source account to be charged for balance transfer. The
<chargeSource> xml input field will hold
this value. If xml does not carry this information, then a default
value is taken from the config.json file.
| Type: | Boolean |
| Allowed: | Only used in BalanceTransfer. |
| Default: | false |
| Example: | chargesource: "false" |
| Syntax: | chargedestination: "Boolean" |
target/destination account to be charged for balance transfer. The
<chargeDestination> xml input field will
hold this value. If xml does not carry this information, then a
default value is taken from the config.json file.
| Type: | Integer |
| Default: | false |
| Example: | chargedestination: "false" |
| Syntax: | serviceType : "value" |
| Description: | This is the MSISDN Service type for which apply loan
details are requested. The <serviceType> xml
input field will hold this value. If xml does not carry this
information, then a default value is taken from the
config.json file
| Type: | String |
| Allowed: | Only used in ApplyLoan. |
| Default: | /service |
| Example: | serviceType : "/service" |
| Syntax: |
| Description: | Group of OAuth credentials. |
| Type: | JSON |
| Allowed: | NA |
| Default: | NA |
| Example: |
| Syntax: | tokenendpoint: "value" |
| Description: | Endpoint to which token request will be triggered. |
| Type: | String |
| Allowed: | NA |
| Default: | “” |
| Example: | tokenendpoint: "OAuthendpoint" |
| Syntax: | clientid: "value" |
| Description: | Username used for OAuth token request. Corresponding password should be added in the wallet. |
| Type: | String |
| Allowed: | NA |
| Default: | NA |
| Example: | clientid: "username" |
