6 About Installation and Removal
Overview
Introduction
This chapter provides information about the installed components for the Oracle Communications Convergent Charging Controller application described in this guide. It also lists the files installed by the application that you can check for, to ensure that the application installed successfully.
Installation and Removal Overview
Checking the Installation
Introduction
Refer to these checklists to ensure that SIGTRAN TCAP Interface has installed correctly.
Checklist - SMS
Follow the steps in this checklist to ensure SIGTRAN TCAP Interface has been installed on a SMS machine correctly.
| Step | Action |
| 1 | Log into the system as acs_oper. |
| 2 |
Enter Note: No password is required. |
| 3 | Ensure that the SMF_STATISTICS_DEFN table in the SMF database has been updated to include SIGTRAN TCAP Interface entries. |
Checklist - non-SMS
Follow the steps in this checklist to ensure SIGTRAN TCAP Interface has been installed on a non-SMS machine correctly.
| Step | Action |
| 1 | Log into the machine as the user which operates the SLEE running on this machine. |
| 2 | Check the /IN/service_packages/SLEE directory structure exists with subdirectories. |
| 3 |
Check the /IN/service_packages/SLEE/bin directory contains the following files:
| 4 |
Check the /IN/service_packages/SLEE/etc directory contains the following files:
