10 About Installation and Removal
Overview
Introduction
This chapter provides information about the installed components for the Oracle Communications Convergent Charging Controller application described in this guide. It also lists the files installed by the application that you can check for, to ensure that the application installed successfully.
Installation and Removal Overview
Checking the Installation
Checking smcbScp installation
Once the installation is complete, refer to this checklist to ensure that installation has been successful.
| Step | Action |
| 1 |
Use SQLPLUS as the smf oracle user to check 3 database tables are created, by typing:
| 2 | Check /IN/service_packages/SMCB/smcbScp.install.log for errors. |
| 3 |
Check the following entries are placed in /IN/service_packages/ACS/etc/acs.conf (1)
| 4 |
Check /IN/service_packages/SLEE/etc/SLEE.cfg contains the following entries (1):
| 5 | Add the SMCB Macro node configuration to the eserv.config file, as detailed in the smcbMacroNodes section. |
Checking smcbSms installation
| Step | Action |
| 1 |
Use SQLPLUS as the smf oracle user to check 2 database tables are created, by typing:
| 2 | Check /IN/service_packages/SMCB/smcbSms install.log for errors. |
SMS Reload Procedure
Procedure
Follow these steps to reload (remove and reinstall) the SMCB system.
| Step | Action |
| 1 | Remove SMCB service plans from the CCS Resources->Product Type->Control Plans window. |
| 2 | Delete data in ACS Control Plan Editor for all service plans that contain the SMCB Feature Node. |
| 3 | Remove the SMCB SMS package (see below for more information). |
| 4 | Install the SMCB SMS package (see above for more information). |
| 5 | Create the service plans for SMCB in CPE (see below for more information). |
| 6 | Select the ACS Control Plan Editor service plan in the CCS Resources->Product Type->Control Plans window. |
| 7 | Initialize the ACS Control Plan Editor replication (replicate the data to the SLC). |
