8 Convergent Charging Controller Directory Structure and Contents
Component directory structure and contents
This table lists the product directory structure for each component product. The default installation directory for each product is:
/IN/service_packages/product_home/
Each component product is installed in this directory, for example, /IN/service_packages/ACS/ is the product home directory for the ACS product.
| Directory | Description |
| /IN/service_packages/product_home/ | Product Home directory. |
| /IN/service_packages/product_home/bin | Product Binary executables and .sh files. |
| /IN/service_packages/product_home/tmp | Product log files. |
| /IN/service_packages/product_home/etc | Product configuration files. |
| /IN/service_packages/product_home/lib | Product library executable files. |
| /IN/service_packages/product_home/db | Product database installation scripts. |
| /IN/service_packages/product_home/cdr | Product EDR files. |
Component Product Directories and Description
This table lists the set of component (product home) directories installed as part of an Convergent Charging Controller install and which conform to the product directory structure as described in the Component directory structure and contents.
Notes:
- Not all component products exist on each Convergent Charging Controller server.
- Not all sub-directories will exist for each component product.
- The component list will depend on the specific Convergent Charging Controller installation and will most likely be a sub-set of all Convergent Charging Controller components.
| Component | Description |
| OSD | Open Services Development |
| PI | Provisioning Interface |
| DAP | Data Access Pack |
| ACS | Advanced Control Services |
| SMCB | Short Message Charging |
| USSD | USSD Roaming Application |
| RAP | Roaming Application Part (Camel Roaming) |
| VSSP | Virtual SSP |
| SMSC | SMS Interface |
| SCA | Session Control Agent |
| IS41 | U-CA-IS41 (CDMA) |
| DCA | Diameter Control Agent |
| DCD | Diameter Control Driver |
| SLEE | Service Logic Execution Environment |
| CCS | Charging Control Services |
| XMS | Messaging Manager application |
| SMS | Service Management System |
| E2BE | Voucher and Wallet Server |
| RIMS | Routing Information for Mobile Services |
| LCP | Location Capabilities Pack |
