3 Customizing OCNADD
This chapter describes how to customize the Oracle Communications Network Analytics Data Director (OCNADD) deployment and provides a list of configuration parameters in the helm file that are used for customization. The OCNADD deployment is customized by overriding the default values of various configurable parameters.
Perform the following procedure to customize the values.yaml files as per requirements for both parent and sub-charts.
Ensure that you have the Data Director charts tgz file, which is available in the extracted release package. For information about how to download the release package from MOS, see Downloading OCNADD Package.
Extract the Data Director charts tgz file if not already extracted.
Change the directory to ocnadd to access the parent
values.yaml. This file is used to customize the deployment parameters during installation.Change the following parameters in the file and save the file.:1. Update the repository path in global.env.repo.REPO_HOST_PORT: <customer repository path> 2. Update the CLUSTER-INFO parameters a) cluster.clusterName: <customer cluster name> b) cluster.nameSpace.name: <created namespace of DD> 3. Change the Prometheus Monitoring Details, bases on the desired MPS profile, default threshould MPS is 40K cluster.mps: 40000
Customize the rules file
<chartpath>/templates/ocnadd-alerting-rules.yaml:- If OCNADD is to be installed in OCCNE Setup, then all the services will be monitored by Prometheus By default. So There will not be any Modifications in the Helm Chart. All the Prometheus Alert Rules Present in Helm Chart will be Updated in Prometheus Server. (Here the Label Used to Update the Prometheus Server is "role: cnc-alerting-rules", which is added By Default in Helm Charts)
If OCNADD is to be installed in Tanzu Setup, then modify the "metadata.labels" value in <chartpath>/templates/ocnadd-alerting-rules.yaml file as below, Example "release: prom-operator" instead of "role: cnc-alerting-rules",
To obtain the labels details use the below command:kubectl get prometheus <Prometheus_Configuration_NAME> -n <Prometheus_Namespace> -o=jsonpath='{.spec.ruleSelector.matchLabels}'Example:
$ kubectl get prometheus prom-operator-kube-prometh-prometheus -n occne-infra -o=jsonpath='{.spec.ruleSelector.matchLabels}'{"release: prom-operator"}
Sample Alert File:apiVersion: monitoring.coreos.com/v1 kind: PrometheusRule metadata: labels: release: prom-operator name: ocnadd-alerting-rules namespace: {{ .Values.global.cluster.nameSpace.name }} -
Update the following default parameters of helm charts before installation:
Service Name Parameter Name Parameter Value FilePath Admin Service OCNADD_ADAPTER_THIRD_PARTY_INTERVAL 2000 ocnadd/charts/ocnaddadminsvc/values.yaml Admin Service OCNADD_ADAPTER_MAX_PARTITION 20 ocnadd/charts/ocnaddadminsvc/values.yaml Admin Service OCNADD_ADAPTER_MAX_POLL_RECORDS 25 (is the default value)
[50-600] (when Message size > 3000 Bytes and Replication factor >1 for MAIN topic)
ocnadd/charts/ocnaddadminsvc/values.yaml Admin Service OCNADD_DEPLOYMENT_TERMINATION_GRACE 5 ocnadd/charts/ocnaddadminsvc/values.yaml
Global Parameters
Table 3-1 Global Parameters
| Parameter Name | Data Type | Range | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | Description |
| ocnaddalarm.enabled | BOOLEAN | true/false | true | M | To enabled alarm charts |
| ocnaddconfiguration.enabled | BOOLEAN | true/false | true | M | To enabled configuration charts |
ocnaddhealthmonitoring .enabled |
BOOLEAN | true/false | true | M | To enabled healthmonitoring charts |
| ocnaddfilter.enabled | BOOLEAN | true/false | true | M | To enabled filter charts |
| ocnaddaggregation.enabled | BOOLEAN | true/false | true | M | To enabled aggregation charts |
| ocnaddbackuprestore.enabled | BOOLEAN | true/false | true | M | To enabled backuprestore charts |
| ocnaddkafka.enabled | BOOLEAN | true/false | true | M | To enabled kafka charts |
| ocnaddadminsvc.enabled | BOOLEAN | true/false | true | M | To enabled adminsvc charts |
| ocnaddbackendrouter.enabled | BOOLEAN | true/false | true | M | To enabled backendrouter charts |
| nodeName | STRING | - | occne-ocdd-k8s-node-x | O | Defines the worker NodeName of the k8 cluster. |
| OCNADD_SSL_KEY_TYPE | STRING | - | PKCS12 | M | Type of ssl key |
| OCNADD_SSL_TRUST_TYPE | STRING | - | PKCS12 | M | Type of ssl store |
| OCNADD_TRUST_KEYSTORE | STRING | true/false | true | M | Enable trust keystore |
| OCWEBCLIENT_TIMEOUT | INTEGER | - | 30 | M | Webclient timeout in seconds |
| OCWEBCLIENT_KEEPALIVE_IDLE | INTEGER | - | 90 | M | Webclient keepalive idle time in seconds |
| scaleDownOnePodAtATime | BOOLEAN | true/false | false | M | Scale Down Pods One at a Time |
| stabilizationWindowSeconds | INTEGER | - | 60 | M | Stabilization period in seconds post which scale down starts |
| scaleDownPeriodSeconds | INTEGER | - | 30 | M | Period of each scale down opeartion in seconds |
| scaleDownValue | INTEGER | - | 1 | M | Number of pods which shall go down in every scaleDownPeriodSeconds |
| global.cluster.nameSpace.name | STRING | - | ocnadd-deploy | M | Namespace name |
| global.cluster.mysqlNameSpace | STRING | - | occne-cndbtierone | O | DB Tier Namespace |
| global.cluster.secret.name | STRING | - | ***** | M | DB secret name |
| global.cluster.secret.data.dbUsername | STRING | - | ***** | M | DB User name (value shoud be converted into base64) |
| global.cluster.secret.data.dbPassword | STRING | - | ***** | M | DB Password (value shoud be converted into base64) |
| global.cluster.serviceAccount.create | BOOLEAN | true/false | true | M | To create a ServiceAccount (true/false) |
| global.cluster.serviceAccount.name | STRING | - | ocnadd-deploy-sa | M | Service Account Name used during RBAC authorization creation |
| global.cluster.clusterRole.create | BOOLEAN | true/false | true | M | To create clusterRole (true/false) |
| global.cluster.clusterRole.name | STRING | - | ocnadd-deploy-cr | M | ClusterRole name used during RBAC authorization creation |
| global.cluster.clusterRoleBinding.create | BOOLEAN | true/false | true | M | To create clusterRoleBinding (true/false) |
| global.cluster.clusterRoleBinding.name | STRING | - | ocnadd-deploy-crb | M | ClusterRoleBinding name used during authorization creation |
| global.cluster.prometheusScrapePort | INTEGER | - | 9000 | O | Port to scape metrics required if metrics enabled |
| global.cluster.prometheusPortName | STRING | - | cnc-metrics | O | Role required to define in alert rules yaml |
| global.cluster.max_latency | FLOAT | - | 0.05 | M | Max latency range of 50ms |
| global.cluster.memory_threshold | INTEGER | [0-100] | 70 | M | Max Threshold limit for memory |
| global.cluster.cpu_threshold | INTEGER | [0-100] | 70 | M | CPU max threshold limit |
| global.cluster.mps | INTEGER | - | 5000 | M | Default MPS rate |
| global.cluster.egwGroupLatencyMessageCountMax | INTEGER | - | 50 | M | Max latency count for Egress Gateway |
| serviceAccount.create | BOOLEAN | true/false | true | M | Disable if Service Account already created and not required to create again |
| clusterRole.create | BOOLEAN | true/false | true | M | ClusterRole creation parameter make it false if already created |
| clusterRoleBinding.create | BOOLEAN | true/false | true | M | ClusterRoleBinding creation parameter make it false if already created |
| ocnaddhelmhook.config.name | STRING | - | helmhook-configmap | M | Name of ConfigMap |
| ocnaddhelmhook.cluster.secret.name | STRING | - | db-secret | M | Name of database secret object |
| ocnaddhelmhook.name | STRING | - |
M | Helm Hook Name |
| ocnaddhelmhook.container.name | STRING | - |
M | Container Name of Helm Hook Job |
| ocnaddhelmhook.container.image | STRING | - | ***** | M | Image will be depending on setup and image repo |
| ocnaddhelmhook.container.imagePullPolicy | STRING | IfNotPresent/Always/Never | IfNotPresent | M | Image Pull Policy |
Aggregation Service Parameters
Table 3-2 Aggregation Service Parameters
| OCNADD_AGGREGATION_NAME | STRING | - | ocnaddnrfaggregation | M | Name of the application |
| OCNADD_AGGREGATION_ACTIVE_PROFILE | STRING | dev, prod | prod | M | Active Profile to be used by the application. |
| OCNADD_AGGREGATION_SERVICE_SOURCE_TOPIC | STRING | SCP/NRF | SCP | M | Source topic details for Aggregation Service (i.e., To Read) |
| OCNADD_AGGREGATION_SERVICE_SOURCE_NAME | STRING | - | AGGREGATION_SOURCE | M | Name of the Kafka Stream Source Node. |
| OCNADD_AGGREGATION_SERVICE_PROCESSROR_NAME | STRING | - | AGGREGATION_PROCESSOR | M | Name of the Kafka Stream Processor Node. |
| OCNADD_AGGREGATION_SERVICE_SINK_NAME | STRING | - | AGGREGATION_SINK | M | Name of the Kafka Stream Sink Node. |
| OCNADD_AGGREGATION_LOG_ROOT | STRING | - | INFO | O | Default Log level set for the application. |
| OCNADD_AGGREGATION_LOG_NETTY | STRING | - | INFO | O | Default Netty Log level set for the application. |
| OCNADD_AGGREGATION_LOG_FILENAME | STRING | - | logs/aggregation-service.log | O | Location where the application specific logs are stored. |
| OCNADD_AGGREGATION_APPLICATION_NAME | STRING | - | OCNADD | O | Aggregation Service Pod name to capture metrics related information. |
| OCNADD_AGGREGATION_MICROSERVICE_NAME | STRING | ocnadd-aggregation-service | O | Aggregation Service Name to communicate & Capture Metrics related information. | |
| OCNADD_AGGREGATION_ENABLED_SCHEDULING_JOBS | BOOLEAN | true, false | false | O | Parameters to enable scheduling Jobs (i.e., Calculating the Metrics) for CPU, Memory, Kafka Lag and Kafka Streams. |
| OCNADD_METRICS_CPU_THRESHOLD | FLOAT | [ 0, 1 ] | 0.75 | O |
| OCNADD_METRICS_MEM_THRESHOLD | FLOAT | [ 0, 1 ] | 0.95 | O |
| ALARM_SERVICE_URL | STRING | - | http://ocnaddalarm:9099 | M | Alarm Service API Root to raise alarm |
| OCNADD_PRODUCER_SERVER_SSL_ENABLED | BOOLEAN | true, false | false | M | Parameter to enable SSL support for the application. |
| KAFKA_PRODUCER_SECURITY_PROTOCOL | STRING | - | PLAINTEXT | M | Kafka Producer Secutiry Protocol. |
| OCNADD_PRODUCER_SSL_KEYSTORE_LOCATION | STRING | - | <location in pod> | M | SSL Key store file location. |
| OCNADD_PRODUCER_SSL_TRUSTSTORE_LOCATION | STRING | - | <location in pod> | M | SSL Trust store file location. |
| KAFKA_PRODUCER_SSL_PROTOCOL | STRING | - | TLSv1.3 | M | SSL Protocol |
| KAFKA_PRODUCER_SASL_MECHANISM | STRING | - | PLAIN | M | Kafka Producer SSAL Mechanism. |
| KAFKA_PRODUCER_SSL_CLIENT_AUTH | BOOLEAN | true, false | false | M | Kafka SSL client authentication. |
| KAFKA_BOOTSTRAP_SERVER | STRING | - | kafka-broker1:9092 | M | Kafka Boot strap server address. |
| AGGREGATION_SERVICE_KAFKA_APPLICATION_ID | STRING | - | ocnadd-aggregation-service | M | Aggregation Service Kafka Stream application Id (By using this name Kafka Consumer Group will be created). |
| AGGREGATION_SERVICE_KAFKA_GROUP_NAME | STRING | - | ocnadd-aggregation-service-group | M | Aggregation Service Kafka Consumer Group Id. |
| KAFKA_STREAM_STATE | STRING | - | /tmp/ocnadd/kafka/state | M | Location to store any stateful information by the application. |
| KAFKA_REPLICATION_FACTOR | INTEGER | >= 1 | 1 | M | The replication factor for changelog topics and repartition topics created by the application. |
| KAFKA_OFFSET_CONFIG | STRING | latest, earliest | latest | M | A flag to tell Kafka application from where to start reading offsets in case you do not have any 'commit' yet. |
| KAFKA_ENABLE_AUTO_COMMIT | STRING | true, false | false | M | A flag for consumer auto commit, to guarantee at-least-once processing semantics. |
| KAFKA_AUTOCOMMIT_INT_CONFIG | INTEGER | - | 10000 | M | A hard auto commit by the Kafka set in the application. |
| KAFKA_COMMIT_INT_CONFIG | INTEGER | - | 10000 | M | The frequency with which to save the position (offsets in source topics) of tasks. |
| KAFKA_NUMBER_THREADS_CONFIG | INTEGER | >= 1 | 2 | M | The number of threads to execute stream processing. |
| KAFKA_MAX_AGE_CONFIG | INTEGER | - | 10000 | M | The period of time in milliseconds after which we force a refresh of metadata. |
| OCNADD_AGGREGATION_HEALTH_SVC_TYPE | STRING | - | AGGREGATION | M | Service Type |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | true, false | false | M | Enable to secure connection via OCWeb Client. |
| OCNADD_TRUST_CLIENT_TRUST_STORE | STRING | - | <location of truststore> | M | OCWeb Client Trust Store location. |
Configuration Service Parameters
Table 3-3 Configuration Service Parameters
| OCNADD_CONFIGURATION_PROFILE | STRING | dev,prod | prod | O | Application profile to use |
| ALARM_SERVICE_URL | STRING | - | http://ocnaddalarm:9099 | M | Alarm Application URL |
| CONFIGURATION_SSL_ENABLED | BOOLEAN | - | FALSE | M | whether to enable ssl |
| SPRING_MVC_LOG_DETAILS | BOOLEAN | - | true | M | - |
| CONFIGURATION_ROOT_LOG_LEVEL | STRING | - | INFO | O | Set Default Log Level for Spring Application |
| CONFIGURATION_WEB_LOG_LEVEL | STRING | - | INFO | O | Set Default Log level for Spring Web |
| CONFIGURATION_DB_SHOW_SQL | BOOLEAN | - | false | O | Whether to enable logging of SQL statements. |
| CONFIGURATION_DB_SQL_COMMENTS | BOOLEAN | - | false | O | If turned on, Hibernate will generate comments inside the SQL, for
easier debugging, defaults to . |
| CONFIGURATION_DB_QUERY_TIMEOUT | INTEGER | - | 30000 | M | sets the length of time to wait for an SQL request to complete. |
| CONFIGURATION_DB_LOCK_TIMEOUT | INTEGER | - | 30000 | M | sets the length of time to wait on a blocked resource. |
| DB_DATASOURCE_URL | STRING | - | jdbc:mysql://<DB_IP>:3306//configuration_schema | M | Ip address of Database service |
| DB_DATASOURCE_USER | STRING | - | ****** | M | Database User name from secret |
| DB_DATASOURCE_PASSWORD | STRING | - | ****** | M | Database User Password from secret |
Consumer Adapter Service Parameters
Table 3-4 Consumer Adapter Service Parameters
| Parameter Name | Data Type | Default Value | Mandatory(M)/Optional(O)/Conditional(C) |
| OCNADD_CONSUMER_ADAPTER_PORT | Integer | 9182 | M |
| OCNADD_CONSUMER_ADAPTER_PROTOCOL | String | http | M |
| OCNADD_CONSUMER_ADAPTER_SERVICE_NAME | String | ocnadd-consumeradapter | M |
| CONSUMER_ADAPTER_SELF_URL | String | ${protocol}://${spring.application.name}:${server.port}/ocnadd-consumeradapter/v1/notifications | O |
| EGRESS_GATEWAY_ENDPOINT | String | http://10.75.245.109:32122/ | M |
| THIRD_PARTY_CONSUMER-ENDPOINT | String | http://10.75.245.109:30513/ocdd-consumer/v1/messages | M |
| BOOTSTRAP_SERVER | String | 10.75.245.109:30511 | M |
| OCNADD_CONSUMER_ADAPTER_TOPIC | String | FILTER | M |
| OCNADD_CONSUMER_ADAPTER_CONFIGURATION_NAME | String | first1 | M |
| OCNADD_CONSUMER_ADAPTER_FETCH_MIN_BYTES | String | 1024 | M |
| OCNADD_CONSUMER_ADAPTER_FETCH_MAX_WAIT_MS | String | 50 | M |
| OCNADD_CONSUMER_ADAPTER_FETCH_MAX_BYTES | String | 52428800 | M |
| OCNADD_CONSUMER_ADAPTER_MAX_PARTITION_FETCH_BYTES | String | 250000000 | M |
| OCNADD_CONSUMER_ADAPTER_AUTO_OFFSET_RESET | String | earliest | M |
| OCNADD_CONSUMER_ADAPTER_MAX_POLL_RECORDS | String | 10000 | M |
| OCNADD_CONSUMER_ADAPTER_AUTO_COMMIT | String | false | M |
| OCNADD_CONFIGURATION_SERVICE_API_ROOT | String | http://localhost:9192/ocnadd-configuration/v1/subscription | M |
| OCNADD_CONSUMER_ADAPTER_ENABLE_FIRE_AND_IGNORE | String | true | M |
| OCNADD_CONSUMER_ADAPTER_PAGE_NUMBER | String | 10 | M |
| OCNADD_CONSUMER_ADAPTER_PAGE_SIZE | String | 100 | M |
| EGRESS_RETRY_INTERVAL | Integer | 10000 | M |
| INITIAL_DATA_DELIVERY_DELAY | Integer | 0 | - |
| SERVICEID_RETRY | Integer | 20 | - |
| OCNADD_CONSUMER_ADAPTER_CONFIG_RETRY_COUNT | Integer | 0 | - |
| OCNADD_CONSUMER_ADAPTER_CONFIG_RETRY_DELAY | Integer | 10 | - |
| CONNECTION_THRESHOLD | Integer | 5 | - |
| PUBLISHER_THRESHOLD | Integer | 1000 | - |
| THIRD_PARTY_RETRY_INTERVAL_MS | Integer | 10000 | - |
| OCNADD_CONSUMER_ADAPTER_MAX_PARTITION | Integer | 15 | - |
| KAFKA_SESSION_TIMEOUT_MS | Integer | 5000 | - |
| CONFIGURATION_HTTP2_ENABLED | String | true | - |
| CONFIGURATION_SSL_ENABLED | String | false | - |
| OCNADD_SSL_KEY_TYPE | String | PKCS12 | - |
| OCNADD_SSL_KEY_STORE | - | - | - |
| OCNADD_SSL_KEY_STORE_PASSWORD | String | secret | - |
| OCNADD_SSL_TRUST_TYPE | String | PKCS12 | - |
| OCNADD_SSL_TRUST_STORE | - | - | - |
| OCNADD_SSL_KEY_TRUST_PASSWORD | String | secret | M |
| OCNADD_TRUST_CLIENT_KEY_STORE | - | - | M |
| OCNADD_TRUST_CLIENT_TRUST_STORE | String | src/main/resources/keystore/clientTrustStore.p12 | M |
| OCNADD_TRUST_CLIENT_PASSWORD | String | secret | M |
| OCNADD_TRUST_CLIENT_KEY_TYPE | String | PKCS12 | M |
| OCNADD_TRUST_KEYSTORE | String | true | M |
| OCNADD_TRUST_PASSWORD | String | secret | M |
| OCNADD_CONSUMER_ADAPTER_TARGET_CONSUMER_NAME | Integer | 100 | M |
| ADAPTER_TIMEOUT | Integer | 10 | M |
| ADAPTER_CHANNEL_TIMEOUT | Integer | 60 | M |
| ADAPTER_CONN_POOL_MAX_CNT | Integer | 400 | M |
| ADAPTER_CONN_POOL_MAX_IDLE | Integer | 90 | M |
| ADAPTER_CONN_POOL_MAX_LIFE | Integer | 3600 | M |
| ADAPTER_CONN_POOL_MAX_PENDING | Integer | 50 | M |
| ADAPTER_PENDING_CONN | Integer | 50 | M |
| ADAPTER_KEEPALIVE_IDLE | Integer | 60 | M |
| ADAPTER_KEEPALIVE_INT | Integer | 60 | M |
| ADAPTER_KEEPALIVE_CNT: | Integer | 10 | M |
| ADAPTER_PUBLISHER_TIMEOUT | Integer | 12 | M |
| OCWEBCLIENT_TIMEOUT | Integer | 60 | O |
| OCWBCLIENT_CHANNEL_TIMEOUT | Integer | 60 | O |
| OCWEBCLIENT_SSL_HANDSHAKE_TIMEOUT | Integer | 30 | O |
| OCWEBCLIENT_SSL_FLUSH_TIMEOUT | Integer | 10 | O |
| OCWEBCLIENT_SSL_READ_TIMEOUT | Integer | 10 | O |
| OCWEBCLIENT_CONN_POOL_MAX_CNT | Integer | 50 | O |
| OCWEBCLIENT_CONN_POOL_MAX_IDLE | Integer | 60 | O |
| OCWEBCLIENT_CONN_POOL_MAX_LIFE | Integer | 120 | O |
| OCWEBCLIENT_CONN_POOL_MAX_PENDING | Integer | 120 | O |
| OCWEBCLIENT_KEEPALIVE_IDLE | Integer | 60 | O |
| OCWEBCLIENT_KEEPALIVE_INT | Integer | 60 | O |
| OCWEBCLIENT_KEEPALIVE_CNT | Integer | 10 | O |
| OCNADD_CONSUMER_ADAPTER_MAX_REPLICA | Integer | 1 | M |
| OCNADD_ALARM_SVC_URL | String | - | M |
| SPRING_MVC_LOG_DETAILS | String | true | M |
| ADAPTER_LOG_LEVEL | String | INFO | M |
| OCNADD_CONSUMER_ADAPTER_LOG_LEVEL | String | INFO | M |
| OCNADD_CONFIGURATION_SERVICE_LOG_FILENAME | String | configuration-service.log | M |
| OCNADD_CONSUMER_ADAPTER_HEALTH_RETRY_COUNT | Integer | 3 | M |
| OCNADD_CONSUMER_ADAPTER_HEALTH_RETRY_DELAY | Integer | 10 | M |
| OCNADD_CONSUMER_ADAPTER_HEALTH_ENDPOINT | Integer | - | M |
| OCNADD_CONSUMER_ADAPTER_HEALTH_HB_TIMER | Integer | 120000 | M |
| OCNADD_CONSUMER_ADAPTER_HEALTH_SVC_TYPE | String | CONSUMER_ADAPTER | M |
| OCNADD_CONSUMER_ADAPTER_HEALTH_SELF_ENDPOINT | String | https://ocnadd-consumeradapter:9182/healthmonitoring | M |
Health Monitoring and Alarm Service Parameters
Table 3-5 Health Monitoring Service Parameters
| Parameter Name | Data Type | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | Description |
| DD_HEALTH_PROFILE_ACTIVE | STRING | Prod | M | Service profile |
| ALARM_SERVICE_URL | STRING | http://ocnaddalarm:9099/ocnadd-alarm/v1 | M | Alarm Application URL |
| ALARM_FOR_DEREGISTEREDSERVICE | BOOLEAN | True | M | Alarm on deregistered service |
| HEALTH_MONITORING_TIMER | INTEGER | 5000 | M | Timer to check Health of integrated services |
| HEALTH_METRICS_SCHEDULED | BOOLEAN | FALSE | M | Scheduler for metrics |
| HEALTH_METRICS_TIMER | INTEGER | 120000 | M | Timer for health metrics |
| HEALTH_PURGE_TIME_HR | INTEGER | 24 | M | Health profile purging timer in hour |
| HEALTH_MONITORING_CPUTHRESHOLD | INTEGER | 75 | M | CPU threshold to raise alarm |
| HEALTH_MONITORING_MEMORYTHRESHOLD | INTEGER | 95 | M | Memory threshold to raise alarm |
| Logging Properties | ||||
| HEALTH_LOG_HTTPCLIENT | STRING | INFO | O | Set Default Log level for Http Client |
| HEALTH_LOG_SPRING_WEB | STRING | INFO | O | Set Default Log level for Spring Web |
| HEALTH_LOG_REQUEST_DETAILS | BOOLEAN | TRUE | O | Set detailed log for spring mvc |
| HEALTH_APPLICATION_LOG_LEVEL | STRING | INFO | O | Set application logger level |
| DATA Source Properties | ||||
| DB_URL | STRING | jdbc:mysql://<DB_HOST>:<DB_PORT>/<HEALTH SCHEMA> | M | Ip address of Database service |
| MYSQL_USER | STRING | <Secret> | M | Database User name |
| MYSQL_PASSWORD | STRING | <Secret> | M | Database User Password |
| SHOW_SQL | BOOLEAN | FALSE | O | Whether to enable logging of SQL statements. |
| LOGGING_LEVEL_SQL | STRING | INFO | O | SQL Logs |
| HTTP2 Properties | ||||
| HEALTH_SSL_ENABLED | BOOLEAN | FALSE | M | whether to enable ssl |
Table 3-6 Alarm Service Parameters
| OCNADD_ALARM_PORT | INTEGER | - | 9099 | M | Server HTTP port |
| OCNADD_ALARM_PROFILE | STRING | dev,prod | prod | M | Alarm Service Profile (choose Based on Environment) |
| Alarm Purging Properties | |||||
| ALARM_PURGE_DAYS | INTEGER | >1 | 30 | M | Delete the Alarms which are terminated more than this no of days |
| ALARM_SCHEDULED_CRON | STRING | - | 0 0 0 * * 0 | M |
cron expression for scheduled deletion of alarms. Default: once a week or can also mention macros i.e( @yearly,@monthly,@weekly,@daily,@hourly,@midnight) |
| Logging Properties | |||||
| ALARM_WEB_LOG_LEVEL | STRING | - | INFO | O | Set Default Log level for Spring Web |
| ALARM_ROOT_LOG_LEVEL | STRING | - | INFO | O | Set Default Log Level for Spring Application |
| ALARM_LOGGING_TYPE | STRING | STDOUT/LOGJSON | STDOUT | O | Logging Type Standard Out / JSON |
| JPA Properties | |||||
| ALARM_DB_SHOW_SQL | BOOLEAN | - | false | O | Whether to enable logging of SQL statements. |
| ALARM_DB_SQL_COMMENTS | BOOLEAN | - | true | O | If turned on, Hibernate will generate comments inside the SQL, for
| ALARM_DB_QUERY_TIMEOUT | INTEGER | - | 30000 | M | sets the length of time to wait for an SQL request to complete. |
| ALARM_DB_LOCK_TIMEOUT | INTEGER | - | 30000 | M | sets the length of time to wait on a blocked resource. |
| DATA Source Properties | |||||
| MYSQL_URL | STRING | - | localhost | M | Ip address of Database service |
| MYSQL_PORT | INTEGER | - | 3306 | M | Port for Database service |
| ALARM_SCHEMA_NAME | STRING | - | alarm_schema | M | Name of Alarm Schema |
| DB_DATASOURCE_USER | STRING | - | ocdd | M | Database User name |
| DB_DATASOURCE_PASSWORD | STRING | - | ocdd | M | Database User Password |
| HTTP2 Properties | |||||
| ALARM_SSL_ENABLED | BOOLEAN | - | false | M | whether to enable ssl |
Admin Service Parameters
Table 3-7 Admin Service Parameters
| ADMINSVC_HTTP2_ENABLED | BOOLEAN | true | M | Whether to enable HTTP2 |
| ADMINSVC_SSL_ENABLED | BOOLEAN | false | M | Whether to enable ssl |
| OCNADD_SSL_KEY_TYPE | STRING | PKCS12 | M | - |
| OCNADD_SSL_KEY_STORE | STRING | - | M | - |
| OCNADD_SSL_KEY_STORE_PASSWORD | STRING | - | M | - |
| OCNADD_SSL_TRUST_TYPE | STRING | PKCS12 | M | - |
| OCNADD_SSL_TRUST_STORE | STRING | - | M | - |
| OCNADD_SSL_KEY_TRUST_PASSWORD | STRING | - | M | - |
| OCNADD_TRUST_CLIENT_KEY_STORE | STRING | - | M | - |
| OCNADD_TRUST_CLIENT_TRUST_STORE | STRING | - | M | - |
| OCNADD_TRUST_CLIENT_PASSWORD | STRING | - | M | - |
| OCNADD_TRUST_CLIENT_KEY_TYPE | STRING | PKCS12 | M | - |
| OCNADD_TRUST_KEYSTORE | STRING | - | M | - |
| OCNADD_TRUST_PASSWORD | STRING | - | M | - |
| OCWebClient | ||||
| OCWEBCLIENT_TIMEOUT | INTEGER | 60 | M | - |
| OCWBCLIENT_CHANNEL_TIMEOUT | INTEGER | 60 | M | - |
| OCWEBCLIENT_SSL_HANDSHAKE_TIMEOUT | INTEGER | 30 | M | - |
| OCWEBCLIENT_SSL_FLUSH_TIMEOUT | INTEGER | 10 | M | - |
| OCWEBCLIENT_SSL_READ_TIMEOUT | INTEGER | 10 | M | - |
| OCWEBCLIENT_CONN_POOL_MAX_CNT | INTEGER | 50 | M | - |
| OCWEBCLIENT_CONN_POOL_MAX_IDLE | INTEGER | 60 | M | - |
| OCWEBCLIENT_CONN_POOL_MAX_LIFE | INTEGER | 120 | M | - |
| OCWEBCLIENT_CONN_POOL_MAX_PENDING | INTEGER | 120 | M | - |
| OCWEBCLIENT_KEEPALIVE_IDLE | INTEGER | 60 | M | - |
| OCWEBCLIENT_KEEPALIVE_INT | INTEGER | 60 | M | - |
| OCWEBCLIENT_KEEPALIVE_CNT | INTEGER | 10 | M | - |
| Configurable Kafka parameters and their default values | ||||
| OCNADD_KAFKA_BOOTSTRAP_SERVER | URL | - | M | - |
| Configurable Kubernetes Parameters | ||||
| OCNADD_NAMESPACE | STRING | - | M | - |
| OCNADD_NODE_NAME | STRING | - | M | - |
| OCNADD_NODE_KEY | STRING | - | M | - |
| OCNADD_NODE_OPERATOR | STRING | In | M | - |
| OCNADD_STORAGE_CLASS | STRING | standard | M | - |
| Consumer Adapter Properties | ||||
| OCNADD_CONSUMER_GROUP_NAME | STRING | consumer | M | - |
| OCNADD_EGRESS_GATEWAY_ENDPOINT | URL | - | M | - |
| OCNADD_THIRD_PARTY_CONSUMER_ENDPOINT | URL | - | M | - |
| OCNADD_CONSUMER_ADAPTER_IMAGE_NAME | STRING | - | M | - |
| OCNADD_CONSUMER_GROUP_MAX_REPLICAS | INTEGER | 1 | M | - |
| OCNADD_SERVICE_ACCOUNT | STRING | - | M | - |
| OCNADD_CONSUMER_TOPIC_NAME | STRING | FILTER | M | - |
| CONFIGURATION_SERVICE_API_ROOT | URL | - | M | - |
| OCNADD_CONSUMER_PORT | INTEGER | - | M | - |
| OCNADD_CONSUMER_PROTOCOL | STRING | - | M | - |
| OCNADD_CONSUMER_ADAPTER_SERVICE_NAME | STRING | - | M | - |
| CONSUMER_ADAPTER_SELF_URL | URL | ocnaddconsumeradapter | M | - |
| OCNADD_ADMINSVC_HEALTH_RETRY_COUNT | INTEGER | 3 | M | - |
| OCNADD_ADMINSVC_HEALTH_RETRY_DELAY | INTEGER | 10 | M | - |
| OCNADD_ADMINSVC_HEALTH_ENDPOINT | URL | - | M | - |
| OCNADD_ADMINSVC_HEALTH_HB_TIMER | INTEGER | 120000 | M | - |
| OCNADD_ADMINSVC_HEALTH_SVC_TYPE | STRING | - | M | - |
| OCNADD_ADMINSVC_HEALTH_SELF_ENDPOINT | URL | - | M | - |
| ALARM_SERVICE_URL | URL | - | M | - |
| Egress Gateway Parameter | ||||
| OCNADD_NAMESPACE | STRING | <namespace> | M | Namespace to spawn egw |
| OCNADD_CONSUMER_EGW_TLS_CN | STRING | egw | M | Suffix for egw configuration |
| OCNADD_CONSUMER_EGW_IMAGE_PULLPOLICY | STRING | IfNotPresent | M | Image Pull Policy for deployment |
| OCNADD_CONSUMER_EGW_IMAGE_PULLSECRET | STRING | <secret> | M | Image pull secret to pull image from Repo |
| OCNADD_CONSUMER_EGW_INIT_IMAGE | STRING | <Init Image> | O | Init Image |
| OCNADD_CONSUMER_EGW_IMAGE_NAME | STRING | <EGW Image> | M | Image to spawn Egw |
| OCNADD_CONSUMER_EGW_CPU_LIMIT | STRING | 4 | M | CPU Limit for EGW |
| OCNADD_CONSUMER_EGW_CPU_REQUEST | STRING | 4 | M | CPU Min requirement for EGW |
| OCNADD_CONSUMER_EGW_MEMORY_LIMIT | STRING | 6Gi | M | Memory limit for EGW |
| OCNADD_CONSUMER_EGW_MEMORY_REQUEST | STRING | 6Gi | M | Memory Min Requirement for EGW |
| OCNADD_CONSUMER_EGW_MAX_REPLICA | INTEGER | 16 | M | Max Replicas for EGW |
| OCNADD_CONSUMER_EGW_MIN_REPLICA | INTEGER | 1 | M | Min Replicas for EGW |
| OCNADD_CONSUMER_EGW_MAX_SURGE | INTEGER | 1 | M | Amount of pods more than the desired number of Pods |
| OCNADD_CONSUMER_EGW_MAX_UNAVAILABLE | INTEGER | 0 | M | Amount of pods that can be unavailable during the update process |
| OCNADD_CONSUMER_EGW_BOOTUP_MINREADYSEC | INTEGER | 0 | M | The bootup time of your application, Kubernetes waits specific time till the next pod creation to serve traffic |
| OCNADD_CONSUMER_EGW_AVG_CPU_UTIL | INTEGER | 70 | M | Average CPU Utilization |
| OCNADD_CONSUMER_EGW_POD_SCALE_DOWN | INTEGER | 1 | M | No. of pod scale down |
| OCNADD_CONSUMER_EGW_POD_SCALE_DOWN_PERIOD | INTEGER | 30 | M | Scale down in seconds |
| OCNADD_CONSUMER_EGW_POD_SCALE_DOWN_STABLE | INTEGER | 60 | M | Stabilization period in seconds post which scale down starts |
| OCNADD_DEPLOYMENT_TERMINATION_GRACE | INTEGER | 30 | M | Grace Termination of Pods in seconds |
| OCNADD_CONSUMER_EGW_PROFILE_ACTIVE | STRING | prod | M | Active profile |
| OCNADD_CONSUMER_EGW_HTTP_CLIENT_POOL_MAX_ACQUIRE | INTEGER | 60000 | O | Max time to acquire connection pool in ms |
| OCNADD_CONSUMER_EGW_HTTP_CLIENT_POOL_MAX_CONN | INTEGER | 300 | O | Max number of connections per pool |
| OCNADD_CONSUMER_EGW_HTTP_CLIENT_POOL_MAX_IDLE | INTEGER | 40 | O | Max number of connection in a pool to be idle |
| OCNADD_CONSUMER_EGW_HTTP_CLIENT_CONNECT_TIMEOUT | INTEGER | 30000 | O | Connection timeout parameter |
| OCNADD_CONSUMER_EGW_HTTP_CLIENT_RESPONSE_TIMEOUT | STRING | 8s | O | Response timeout parameter |
| OCNADD_EGW_EMPHEMERAL_STORAGE_LIMIT | STRING | 400Mi | M | Ephemeral storage Max |
| OCNADD_EGW_EMPHEMERAL_STORAGE_REQUEST | STRING | 200Mi | M | Ephemeral storage Min |
| ENABLE_EGW_COUNTER_METRICS | BOOLEAN | true | M | Counter Metrics Enable |
| ENABLE_EGW_LATENCY_METRICS | BOOLEAN | true | M | Latency Metrics Enable |
| OCNADD_EGW_LIVENESS_DELAY | INTEGER | 60 | O | Pod liveliness delay |
| OCNADD_EGW_LIVENESS_PERIOD | INTEGER | 15 | O | Pod liveliness Timeperiod |
| OCNADD_EGW_LIVENESS_FAILURE | INTEGER | 5 | O | Liveliness failure in seconds |
| OCNADD_EGW_LIVENESS_TIMEOUT | INTEGER | 20 | O | Pod Liveliness Timeout |
| EGW_MIN_EXPECTED_VALUE_LATENCY_MS | INTEGER | 50 | M | Min expected latency for metrics |
| EGW_MAX_EXPECTED_VALUE_LATENCY_MS | INTEGER | 50 | M | Max expected latency for metrics |
| EGW_MIN_EXPECTED_VALUE_ETE_LATENCY_MS | INTEGER | 50 | M | Min expected latency for metrics |
| EGW_MAX_EXPECTED_VALUE_ETE_LATENCY_MS | INTEGER | 50 | M | Max expected latency for metrics |
| Logging | ||||
| SPRING_MVC_LOG_LEVEL | STRING | INFO | M | Mvc logs |
| SPRING_MVC_LOG_TYPE | STRING | STDOUT | M | STDOUT output in pod logs |
Kafka Configuration Parameters
Table 3-8 Kafka Configuration Parameters
| Parameter Name | Data Type | Range | Default Value | Mandatory(M)/ Optional(O)/ Conditional(C) | Description |
| chart.name | String | ocdd-kafka | M | Defines the name of the kafka chart | |
| broker.id | Int | -1 | M |
Gives the broker an int as an identifier. -1 will let the cluster choose an unqiue identifier automatically |
| delete.topic.enable | boolean | true | C | Enables the feature of deleting a topic | |
| group.initial.rebalance.delay.ms | Int | 20 | The amount of time the group coordinator will wait for more consumers to join a new group before performing the first rebalance. | ||
| log.dir | String | /tmp/kafka-logs | M | The path to store the kafka logs | |
| zookeeper.ssl.client.enable | boolean | true | M | To enable or disable ssl in the connection between the kafka broker and the zookeeper | |
| zookeeper.ssl.protocol | String | TLSv1.2 | M | SSL protocol for connection between kafka broker and zookeeper | |
| zookeeper.ssl.truststore.location | String | M | Path to where the zookeeper truststore is mounted. | ||
| zookeeper.ssl.truststore.password | String | M | Password for the zookeeper truststore | ||
| zookeeper.ssl.keystore.location | String | M | Path to where the zookeeper keystore is mounted. | ||
| zookeeper.ssl.keystore.password | String | M | Password for the zookeeper keystore | ||
| security.inter.broker.protocol | String | PLAINTEXT | M | Protocol for inter broker communication | |
| auto.create.topics.enable | boolean | false | When set to true, when applications attempt to produce, consume, or fetch metadata for a non-existent topic, Kafka will automatically create the topic with the default replication factor and number of partitions. | ||
| super.users | String | Super users are allowed to perform any operation on any resource in a Kafka cluster | |||
| kafkaBroker.name | String | Name of the kafka broker | |||
| minReplicas | Int | 1 | The minumum number of replicas that must be available at all times | ||
| maxReplicas | Int | 2 | The maximum number of replicas allowed for the pod | ||
| replicas | Int | 1 | The number of replicas that you want to be available for the pod | ||
| target.averageCpuUtilPercentage | Int | 50 | The target average CPU utilization percentage | ||
| target.memoryUtilPercentage | Int | 80 | The target average memory utilization percentage | ||
| container.port | 9098 | The port which at which the kafka container is exposed for connection | |||
| container.saslPort | 9099 | The port which at which the kafka container is exposed for SASL connection | |||
| kafkaBroker.container.image | String | The url of the kafka image that is to be pulled | |||
| kafkaBroker.container.pullPolicy | String | IfNotPresent | The image pull policy for the container.image | ||
| sharedVolumeName | String | The name of the volume that is mounted | |||
| mountPath | String | The path within the container where the volume will be mounted | |||
| resource.requests.cpu | Int | The requested number of CPU cores | |||
| resource.requests.memory | String | The requested size of memory | |||
| resource.limits.cpu | The maximum limit for the number of CPUs used for the container | ||||
| resource.limits.memory | Int | The maximum limit for the size of the memory used for the container | |||
| partitions | Int | The number of partitions in the broker | |||
| replicationFactor | Int | The number of copies of the partitions that are to be maintained | |||
| kafkaSvcName | String | The name of the kafka service name | |||
| service.type | String | The type of the kafka service | |||
| serivce.targetPort | The port at which the service will send requests to | ||||
| service.saslSslTargetPort | The port at which the service will send SASL requests to | ||||
| log.dir | String | M | /tmp/kafka-logs | The path to store the kafka logs | |
| zookeeper.ssl.client.enable | boolean | M | true | To enable or disable ssl in the connection between the kafka broker and the zookeeper | |
| zookeeper.ssl.protocol | String | M | TLSv1.2 | SSL protocol for connection between kafka broker and zookeeper | |
| ssl.truststore.location | Path to where the truststore for connection between broker and clients is mounted. | ||||
| ssl.truststore.password | Password of the truststore for conection between broker and clients. | ||||
| ssl.keystore.location | Path to where the keystore for coneection between broker and clients is mounted. | ||||
| ssl.keystore.password | Password of the keystore for conection between broker and clients. | ||||
| num.io.threads | 8 | Number of threads that pick up requests from the request queue to process them | |||
| num.network.threads | Network threads handle requests to the Kafka cluster, such as produce and fetch requests from client applications | ||||
| socket.send.buffer.bytes | Denotes the value of the buffer size for sending messages | ||||
| socket.receive.buffer.bytes | Denotes the value of the buffer size for receiving messages | ||||
| num.recovery.threads.per.data.dir | This parameter is used to specify the number of threads used for log loading at startup and flushing at shutdown. |
Backend Router Parameters
Table 3-9 Backend Router Parameters
| OCNADD_BKNROUTER_APPLICATION_NAME | String | ocnaddbackendrouter | M | Application Name | |
| OCNADD_BKNROUTER_PORT | Int | 8988 | M | Server port | |
| OCNADD_BKNROUTER_ROOT_LOG_LEVEL | String | INFO |
Root log level configuration (INFO,DEBUG,ERROR) |
| OCNADD_BKNROUTER_COM_LOG_LEVEL | String | INFO |
Log level configuration (INFO,DEBUG,ERROR) |
| OCNADD_BKNROUTER_LOG_LEVEL | String | INFO |
| OCNADD_BKNROUTER_LOG_FILENAME | String | var/occne/ocnaddbackendrouter.dir | Log file directory update. | ||
| OCNADD_BKNROUTER_CONFIG_REDIRECTURI | String | http://ocnaddconfiguration:12590 | M | Configuration service URl | |
| OCNADD_BKNROUTER_HEALTHSVC_REDIRECTURI | String | http://ocnaddhealthmonitoring:12591 | M | Health service URI | |
| OCNADD_BKNROUTER_AlARM_REDIRECTURI | String | http://ocnaddalarm:9099 | M | Alarm Service URI | |
| OCNADD_BKNROUTER_CONFIG_PATH_PATERN | String | /ocnadd-configuration/** | |||
| OCNADD_BKNROUTER_HEALTH_PATH_PATERN | String | /ocnaddapi/ocnadd-health/** | |||
| WEBCLIENT_MAX_BUFFER_SIZE | String | 17777216 |
