5 Rollback OCNADD
This chapter describes the OCNADD rollback procedure from a target release to a previous supported version.
Supported Rollback Path
The following table lists the supported rollback paths for OCNADD:
Table 5-1 Supported Rollback Path
| Source Release | Traget Release |
| 22.0.0 | 22.0.0 |
Rollback Steps
- (Optional) A timeout interval of 15 minutes can be set while performing an upgrade as only one POD of the Data Director services is upgraded at a time.
- Ensure the status for the target version is not in failed or error state.
- Run the following command to check the revision you must roll
back
to:
$ helm history <release_name> -n <release_namespace>Where,
<release_name> is the release name used by the Helm command.
<release_namespace> is the OCNADD release name, for example, ocnadd.
Example:
- Run the command to rollback to the required
revision:
helm rollback <release_name> <REVISION_number> --namespace <release_namespace> --timeout=15mWhere, <REVISION_number> is the release version to which Data Director needs to be rolled back is obtained in the previous step.
Example:
helm rollback ocnadd 1 --namespace ocnadd --timeout=15m
If the rollback is not successful, perform the troubleshooting steps mentioned in Oracle Communications Network Analytics Data Director Troubleshooting Guide..
