7 Create OCNADD Restore Job
- Restore the OCNADD database by executing the following steps:
- Go to the custom-templates folder inside the extracted ocnadd-release
package and update the ocnadd_restore.yaml file based on the restore
requirements:
- The value of BACKUP_ARG can be set to DB, KAFKA, and ALL. By default, the value is 'ALL'.
- The value of BACKUP_FILE can be set to folder name which needs to be restored, if not mentioned the latest backup will be used.
- Update other values as
below:
apiVersion:batch/v1 kind:Job metadata: name:ocnaddrestore namespace:ocnadd-deploy #---> update the namespace spec: template: metadata: name:ocnaddrestore spec: volumes: -name:backup-vol persistentVolumeClaim: claimName:backup-mysql-pvc -name:config-vol configMap: name:config-backuprestore-scripts serviceAccountName:ocnadd-deploy-gitlab-admin #---> update the service account name. Format:<namespace>-gitlab-admin containers: -name:ocnaddrestore image:<repo-path>/ocnaddbackuprestore:1.0.0 #--->update repository path volumeMounts: -mountPath:"work-dir" name:backup-vol -mountPath:"config-backuprestore-scripts" name:config-vol env: -name:HOME value:/tmp -name:DB_USER valueFrom: secretKeyRef: name:db-secret key:MYSQL_USER -name:DB_PASSWORD valueFrom: secretKeyRef: name:db-secret key:MYSQL_PASSWORD -name:BACKUP_ARG value:ALL -name:BACKUP_FILE value: command: - /bin/sh - -c - | cp /config-backuprestore-scripts/*.sh /tmp chmod +x /tmp/*.sh echo "Executing restore script" ls -lh /work-dir/backup bash /tmp/restore.sh $BACKUP_ARG $BACKUP_FILE sleep 15m restartPolicy:Never status:{}
requirements:
- Execute the below command to run the restore
job:
kubectl create -f ocnadd_restore.yaml - Restart the ocnaddconfiguration, ocnaddalarm, and ocnaddhealthmonitoring pods once the restore job gets completed.
If the backup is not available for the mentioned date, the pod will be in an error state, notifying the Backup is not available for the given date: $DATE, in such case provide the correct backup dates and repeat the procedure.
