4 Capturing tcpdump from CNE
Perform the following steps to capture tcpdump in CNE:
- Run the following command to identify the worker node for the running
pod:
$ kubectl get pods -n ocnadd -o wide - Login to the worker node and run the following command to search for the IP address of the pod:
$ ip a - Run the following command to start tcpdump on the identified network
interface:
$ sudo tcpdump -n -s0 -i <interface> w <file-name>.pcap -Z <node-user-name> - Run the following command to change the file
permissions:
$ chmod 777 <file-name>.pcap - Exit the worker node and run the following command to
scpthe file from the bastion host:$ scp <user-name>@<worker node>:/home/ocnadd-tiger/filename.pcap
