OCNADD_KAFKA_PACKET_DROP_THRESHOLD_10PERCENT_MPS
Table 5-26 OCNADD_KAFKA_PACKET_DROP_THRESHOLD_10PERCENT_MPS
| Field | Details |
| Triggering Condition | The packet drop rate in Kafka streams is above the configured critical threshold of 10% of total supported MPS |
| Severity | Critical |
| Description | The packet drop rate in Kafka streams is above the configured critical threshold of 10% of total supported MPS in the period of 5 min |
| Alert Details |
Summary: 'namespace: {{ "{{" }}$labels.namespace}}, podname: {{ "{{" }}$labels.pod}}, timestamp: {{ "{{" }} with query "time()" }}{{ "{{" }} . | first | value | humanizeTimestamp }}{{ "{{" }} end }}: Packet Drop rate is above 10% thereshold of Max messages per second:{{ .Values.global.cluster.mps }}'Expression: expr: sum(rate(kafka_stream_task_dropped_records_total[5m])) by (namespace) > 0.1*{{ .Values.global.cluster.mps }} |
| OID | 1.3.6.1.4.1.323.5.3.51.29.5011 |
| Metric Used | kafka_stream_task_dropped_records_total |
| Resolution | The alert is cleared automatically when the packet drop rate goes below the critical threshold (10%) alert level of supported MPS |
