OCNADD_MPS_MINOR_INGRESS_THRESHOLD_CROSSED
Table 5-13 OCNADD_MPS_MINOR_INGRESS_THRESHOLD_CROSSED
Field Details
Triggering Condition The total ingress MPS crossed the minor threshold alert level of 90% of the supported MPS
Severity Minor
Description Total Ingress Message Rate is above configured minor threshold alert (90%) for the period of 5 min
Alert Details
Summary:
'namespace: {{ "{{" }}$labels.namespace}}, podname: {{ "{{" }}$labels.pod}}, timestamp: {{ "{{" }} with query "time()" }}{{ "{{" }} . | first | value | humanizeTimestamp }}{{ "{{" }} end }}: Message Rate is above 90 Percent of Max messages per second:{{ .Values.global.cluster.mps }}'
Expression:
expr: sum(rate(kafka_stream_processor_node_process_total[5m])) by (namespace) > 0.9*{{ .Values.global.cluster.mps }}
OID 1.3.6.1.4.1.323.5.3.51.29.5007
Metric Used kafka_stream_processor_node_process_total
Resolution The alert is cleared automatically when the the MPS rate goes below the minor threshold alert level of 90%.
