OCNADD_MPS_WARNING_EGRESS_THRESHOLD_CROSSED
Table 5-16 OCNADD_MPS_WARNING_EGRESS_THRESHOLD_CROSSED
Field Details
Triggering Condition The total egress MPS crossed the warning threshold alert level of 80% of the supported MPS
Severity Warn
Description Total Egress Message Rate is above configured warning threshold alert (80%) for the period of 5 min
Alert Details
Summary:
'namespace: {{ "{{" }}$labels.namespace}}, podname: {{ "{{" }}$labels.pod}}, timestamp: {{ "{{" }} with query "time()" }}{{ "{{" }} . | first | value | humanizeTimestamp }}{{ "{{" }} end }}: Message Rate is above 80% of Max messages per second:{{ .Values.global.cluster.mps }}'
Expression:
expr: sum (rate(ocnadd_egressgateway_http_requests_total[5m])) by (namespace) > 0.80*{{ .Values.global.cluster.mps }}
OID 1.3.6.1.4.1.323.5.3.51.29.5008
Metric Used ocnadd_egressgateway_http_requests_total
Resolution The alert is cleared automatically when the the MPS rate goes below the warning threshold alert level of 80% of supported MPS
