OCNADD_POD_MEMORY_USAGE_ALERT
Table 5-2 OCNADD_POD_MEMORY_USAGE_ALERT
Field Details
Triggering Condition POD Memory usage is above set threshold (default 70%)
Severity Major
Description OCNADD Pod High Memory usage detected for the continuous period of 5min
Alert Details
Summary:
'namespace: {{ "{{" }}$labels.namespace}}, podname: {{ "{{" }}$labels.pod}}, timestamp: {{ "{{" }} with query "time()" }}{{ "{{" }} . | first | value | humanizeTimestamp }}{{ "{{" }} end }}: Memory usage is {{ "{{" }} $value | printf "%.2f" }} which is above threshold {{ .Values.global.cluster.memory_threshold }} % '
Expression:
(sum(container_memory_working_set_bytes{image!="" , pod=~".*ocnadd.*"}) by (pod,namespace) > 2*1024*1024*1024*{{ .Values.global.cluster.memory_threshold }}/100) or (sum(container_memory_working_set_bytes{image!="" , pod=~".*kafka.*"}) by (pod,namespace) > 24*1024*1024*1024*{{ .Values.global.cluster.memory_threshold }}/100) or (sum(container_memory_working_set_bytes{image!="" , pod=~".*zookeeper.*"}) by (pod,namespace) > 1*1024*1024*1024*{{ .Values.global.cluster.memory_threshold }}/100) or (sum(container_memory_working_set_bytes{image!="" , pod=~".*egw.*"}) by (pod,namespace) > 2*1024*1024*1024*{{ .Values.global.cluster.memory_threshold }}/100) or (sum(container_memory_working_set_bytes{image!="" , pod=~".*adapter.*"}) by (pod,namespace) > 2*1024*1024*1024*{{ .Values.global.cluster.memory_threshold }}/100)
OID 1.3.6.1.4.1.323.5.3.51.29.4005
Metric Used
Note : This is a Kubernetes metric used for instance availability monitoring. If the metric is not available, use the similar metric as exposed by the monitoring system.
Resolution
The alert gets cleared when the memory utilization is below the critical threshold.
Note: The threshold is configurable in the ocnadd/values.yaml file. If guidance is required, contact unresolvable-reference.html#GUID-6BEC5E06-7EC9-457A-8A82-15663EEAE8AF .
