2 Troubleshooting OCNADD
kubectl commands might vary based on the platform
deployment. Replace kubectl with Kubernetes environment-specific
command line tool to configure Kubernetes resources through
kube-api server. The instructions provided in this document
are as per the Oracle Communications Cloud Native Environment (OCCNE) version of
kube-api server.
Generic Checklist
The following sections provide a generic checklists for troubleshooting OCNADD.
Deployment Checklist
- Run the following command to verify if OCNADD deployment, pods, and services created are running and available:
Verify the output, and check the following columns:# kubectl -n <namespace> get deployments,pods,svc- READY, STATUS, and RESTARTS
- PORT(S) of service
It is normal to observe the Kafka broker restart during deployment. - Verify if the correct image used and correct environment variables set in the deployment.
To check, run the following command:
# kubectl -n <namespace> get deployment <deployment-name> -o yaml - Check if the microservices can access each other through a REST interface.
Example:# kubectl -n <namespace> exec <pod name> -- curl <uri>kubectl exec -it pod/ocnaddconfiguration-6ffc75f956-wnvzx -n ocnadd-system -- curl 'http://ocnaddadminservice:9181/ocnadd-admin-svc/v1/topic'Note:
These commands are in their simple format and display the logs only if ocnaddconfiguration and ocnadd-admin-svc pods are deployed.
The list of URIs for all the microservices:
http://ocnaddconfiguration:<port>/ocnadd-configuration/v1/subscriptionhttp://oncaddalarm:<port>/ocnadd-alarm/v1/alarm?&startTime=<start-time>&endTime=<end-time>Use off-set date time format, for example, 2022-07-12T05:37:26.954477600Z
<ip>:<port>/ocnadd-admin-svc/v1/topic/<ip>:<port>/ocnadd-admin-svc/v1/describe/topic/<topicName><ip>:<port>/ocnadd-admin-svc/v1/alter<ip>:<port>/ocnadd-admin-svc/v1/broker/expand/entry<ip>:<port>/ocnadd-admin-svc/v1/broker/health
Application Checklist
# kubectl -n <namespace> logs -f <pod name>Use the option -f to follow the logs or grep option to obtain a specific pattern in the log output.
# kubectl -n ocnadd-system logs -f $(kubectl -n ocnadd-system get pods -o name |cut -d'/' -f 2|grep nrfaggregation)Above command displays the logs of the ocnaddnrfaggregation service.
# kubectl logs -n ocnadd-system <pod name> | grep <pattern>Note:
These commands are in their simple format and display the logs only if there is atleast onenrfaggregation pod deployed.
Helm Install and Upgrade Failure
This section describes the various helm installation or upgrade failure scenarios and the respective troubleshooting procedures:
Incorrect Image Name in ocnadd/values File
Problem
helm install fails if an incorrect image name
is provided in the ocnadd/values.yaml file or if the image is
missing in the image repository.
Error Code or Error Message
When you run kubectl get pods -n <ocnadd_namespace>, the status of the pods might be ImagePullBackOff or ErrImagePull.
Solution
Perform the following steps to verify and correct the image name:
- Edit the
ocnadd/values.yamlfile and provide the release specific image names and tags. - Run the
helm installcommand. - Run the
kubectl get pods -n <ocnadd_namespace>command to verify if all the pods are in Running state.
Docker Registry is Configured Incorrectly
Problem
helm install might fail if the docker registry is not configured in
all primary and secondary nodes.
Solution
Configure the docker registry on all primary and secondary nodes. For information about docker registry configuration, see Oracle Communications Cloud Native Environment Installation Guide.
Continuous Restart of Pods
Problem
helm install might fail if MySQL primary or
secondary hosts are not configured properly in
ocnadd/values.yaml.
<ocnadd_namespace>, the pods shows restart count increases
continuously or there is a Prometheus alert for continuous pod restart.
Verify MySQL connectivity.
MySQL servers(s) may not be configured properly. For more information about the MySQL configuration, see Oracle Communications Network Analytics Data Director Installation Guide.
- Describe the POD to check more details on the error, troubleshoot further based on the reported error.
- Check the POD log for any error, troubleshoot further based on the reported error.
Adapter Pods Does Not Receive Update Notification
Problem
Update notification from configuration service/GUI is not reaching Adapter pods..
On triggering update notification from GUI/Configuration Service, the configuration changes on Adapter does not take place.
Solution
- Check the Adapter pod logs
with:
"kubectl logs <adapter app name> -n <namespace> - If the update notification logs are not present in the Adapter logs execute the
below command to re-read the configurations with the following
command:
kubectl rollout restart deploy <adapter app name> -n <namespace>
Values.yaml File Parse Failure
This section explains the troubleshooting procedure in case of failure while
parsing the ocnadd/values.yaml file.
Problem
Unable to parse the ocnadd/values.yaml file or any
other while running Helm install.
Error: failed to parse ocnadd/values.yaml: error
converting YAML to JSON: yaml
Symptom
When parsing the ocnadd/values.yaml file, if
the above mentioned error is received, it indicates that the file is not
parsed because of the following reasons:
- The tree structure may not have been followed
- There may be a tab space in the file
Solution
Download the latest OCNADD custom templates zip file from MOS. For more information, see Oracle Communications Network Analytics Data Director Installation Guide.
Kafka Brokers Continuously Restart after Reinstallation
Problem
When re-installing OCNADD in the same namespace without deleting the PVC that was used for the first installation, Kafka brokers will go into crashloopbackoff status and keep restarting.
When you run, kubectl get pods -n <ocnadd_namespace> the broker pod's
status might be Error/crashloopbackoff and it might keep restarting continuously, with
"no disk space left on the device" errors in the pod logs.
Solution
- Delete the Stateful set (STS) deployments of the brokers. Run
kubectl get sts -n <ocnadd_namespace>to obtain the Stateful sets in the namespace. - Delete the STS deployments of the services with disk full issue. For example run the command
kubectl delete sts -n <ocnadd_namespace> kafka-broker1 kafka-broker2. - Delete the PVCs in the namespace, which is used by kafka-brokers. Run
kubectl get pvc -n <ocnadd_namespace>to get the PVCs in that namespace.The number of PVCs used is based on the number of brokers deployed. Therefore, select the PVCs that have the name kafka-broker or zookeeper, and delete them. To delete the PVCs, run
kubectl delete pvc -n <ocnadd_namespace> <pvcname1> <pvcname2>.
For example:
For a three broker setup in the namespace ocnadd-deploy, delete the following PVCs:
kubectl delete pvc -n ocnadd-deploy broker1-pvc-kafka-broker1-0, broker2-pvc-kafka-broker2-0, broker3-pvc-kafka-broker3-0, kafka-broker-security-zookeeper-0, kafka-broker-security-zookeeper-1 kafka-broker-security-zookeeper-2Kafka Brokers Continuously Restart After the Disk is Full
Problem
This issue occurs when the disk space is full on the broker or zookeeper.
When you run kubectl get pods -n <ocnadd_namespace>, the broker pod's status might be error or crashloopbackoff and it might keep restarting continuously.
Solution
- Delete the STS(Stateful set) deployments of the brokers:
- Get the STS's in the namespace with the following
command:
kubectl get sts -n <ocnadd_namespace> - Delete the STS deployments of the services with disk full
issue:
kubectl delete sts -n <ocnadd_namespace> <sts1> <sts2>For example, for three broker setup:kubectl delete sts -n ocnadd-deploy kafka-broker1 kafka-broker2 kafka-broker3 zookeeper
command:
- Delete the PVCs in that namespace that is used by the removed kafka-brokers. To get
the PVCs in that
namespace:
kubectl get pvc -n <ocnadd_namespace>The number of PVCs used will be based on the number of brokers you deploy. So choose the PVCs that have the name kafka-broker or zookeeper and delete them.
- To delete PVCs,
run:
kubectl delete pvc -n <ocnadd_namespace> <pvcname1> <pvcname2>For example, For a three broker setup in namespace ocnadd-deploy, you will need to delete these PVCs;
kubectl delete pvc -n ocnadd-deploy broker1-pvc-kafka-broker1-0 broker2-pvc-kafka-broker2-0 broker3-pvc-kafka-broker3-0 kafka-broker-security-zookeeper-0 kafka-broker-security-zookeeper-1 kafka-broker-security-zookeeper-2
- To delete PVCs,
run:
3. Once the STS and PVC's are deleted for the services, edit the respective broker's values.yaml to increase the PV size of the brokers at the location:
<chartpath>/charts/ocnaddkafka/values.yaml.If any formatting or indentation issues occur while editing, refer to the files in<chartpath>/charts/ocnaddkafka/defaultTo increase the storage edit the fields pvcClaimSize for each broker.
4. Upgrade the helm chart after increasing the PV size
helm upgrade <release-name> <chartpath> -n <namespace> - Create the required topics.
Kafka Brokers Restart on Installation
Problem
Kafka brokers re-start during OCNADD installation.
The output of the command kubectl get pods -n <ocnadd_namespace> displays the broker pod's status as restarted.
Solution
The Kafka Brokers wait for a maximum of 3 minutes for the Zookeepers to come online before they are started. If the Zookeeper cluster does not come online within the given interval, the broker will start before the Zookeeper and will error out as it does not have access to the Zookeeper.This may Zookeeper may start after the 3 interval as the node may take more time to pull the images due to network issues.Therefore, when the zookeeper does not come online within the given time this issue may be observed.
Database Goes into the Deadlock State
Problem
MySQL locks get struck.
ERROR 1213 (40001): Deadlock found when trying to get lock; try restarting the transaction.
Symptom
Unable to access MySQL.
Solution
Perform the following steps to remove the deadlock:
- Run the following command on each SQL
node:
This command retrieves the list of commands to kill each connection.SELECT CONCAT('KILL ', id, ';') FROM INFORMATION_SCHEMA.PROCESSLIST WHERE `User` = <DbUsername> AND `db` = <DbName>;Example:select CONCAT('KILL ', id, ';') FROM INFORMATION_SCHEMA.PROCESSLIST where `User` = 'ocnadduser' AND `db` = 'ocnadddb'; +--------------------------+ | CONCAT('KILL ', id, ';') | +--------------------------+ | KILL 204491; | | KILL 200332; | | KILL 202845; | +--------------------------+ 3 rows in set (0.00 sec) - Run the kill command on each SQL node.
Readiness Probe Failure
The helm install might fail due to the readiness probe URL
failure.
If the following error appears, check for the readiness probe URL
correctness in the particular microservice helm charts under the charts folder:
Low Resources
Helm install might fail due to low
resources, and the following error may appear:
In this case, check the CPU and memory availability in the Kubernetes cluster.
