3 Customizing OCNADD
This chapter describes how to customize the Oracle Communications Network Analytics Data Director (OCNADD) deployment, supported deployment models, and provides a list of configuration parameters in the Helm file that are used for customization. The OCNADD deployment is customized by overriding the default values of various configurable parameters.
3.1 Global Parameters
Table 3-1 Global Parameters
Parameter Name Data Type Range Default Value Mandatory(M)/Optional(O)/Conditional(C) Description
ocnaddalarm.enabled BOOLEAN true/false true M To enabled alarm charts
ocnaddconfiguration.enabled BOOLEAN true/false true M To enabled configuration charts
ocnaddhealthmonitoring
.enabled
BOOLEAN true/false true M To enabled healthmonitoring charts
ocnaddfilter.enabled BOOLEAN true/false true M To enabled filter charts
ocnaddaggregation.enabled BOOLEAN true/false true M To enabled aggregation charts
ocnaddbackuprestore.enabled BOOLEAN true/false true M To enabled backuprestore charts
ocnaddkafka.enabled BOOLEAN true/false true M To enabled kafka charts
ocnaddadminsvc.enabled BOOLEAN true/false true M To enabled adminsvc charts
ocnaddbackendrouter.enabled BOOLEAN true/false true M To enabled backendrouter charts
ocnaddgui.enabled BOOLEAN true/false true M To enabled gui charts
env.ocwebclient.OCWEBCLIENT_TIMEOUT INTEGER - 30 O Webclient timeout in seconds
env.ocwebclient.OCWEBCLIENT_KEEPALIVE_IDLE INTEGER - 90 O Webclient keepalive idle time in seconds
scaleDownOnePodAtATime BOOLEAN true/false false M Scale Down Pods One at a Time
stabilizationWindowSeconds INTEGER - 60 M Stabilization period in seconds post which scale down starts
scaleDownPeriodSeconds INTEGER - 30 M Period of each scale down opeartion in seconds
scaleDownValue INTEGER - 1 M Number of pods which shall go down in every scaleDownPeriodSeconds
initContainers.name STRING - ocnaddinitcontainer M Name of initContainer for SSL support
initContainers.image STRING - jdk17-openssl:1.0.6 M InitContainer Image
initContainers.REPO_PATH STRING - utils.repo M Repo path where init image is stored
initContainers.volumeMounts.ts_ks_volumeName STRING - truststore-keystore-volume M Volume name for truststore
initContainers.volumeMounts.ts_ks_volumePath STRING - /var/securityfiles/keystore M Path where keystore files are stored
initContainers.volumeMounts.certificateName STRING - client-server-certificate M Volume name for server certificates
initContainers.volumeMounts.certificatePath STRING - /var/securityfiles/certs M Path where cert files are stored
initContainers.env.cert_file_params.SERVER_CERT_FILE STRING - servercert.pem M Server cert filename
initContainers.env.cert_file_params.CLIENT_CERT_FILE STRING - clientcert.pem M Client cert filename
initContainers.env.cert_file_params.SERVER_KEY_FILE STRING - serverprivatekey.pem M Server Private Key filename
initContainers.env.cert_file_params.CLIENT_KEY_FILE STRING - clientprivatekey.pem M Client Private Key filename
initContainers.env.ks_file_params.SERVER_KEY_STORE STRING - serverKeyStore.p12 M Server Keystore file
initContainers.env.ks_file_params.CLIENT_KEY_STORE STRING - clientKeyStore.p12 M Client Keystore file
initContainers.env.ks_file_params.TRUST_STORE STRING - trustStore.p12 M Truststore file
initContainers.cacert.key STRING - CA_CERT_FILE M Cacert key file
initContainers.cacert.value STRING - cacert.pem M Cacert file
ssl.intraTlsEnabled BOOLEAN true/false false M Enable internal service TLS
ssl.mTLS BOOLEAN true/false false M Enable MTLS support for internal OCNADD services
image.ocnaddadminsvc.name STRING   ocnaddadminsvc:1.0.72 M Admin Service Image
image.ocnaddconsumeradapter.name STRING   ocnaddconsumeradapter:1.0.76 M Consumer Adapter Image
image.ocnaddaggregation.name STRING   ocnaddaggregation:1.0.51 M Aggregation Service Image
image.ocnaddalarm.name STRING   ocnaddalarm:1.0.45 M Alarm Service Image
image.ocnaddconfiguration.name ocnaddfilter:1.0.29-dev   ocnaddconfiguration:1.0.61 M Configuration Service Image
image.ocnaddegressgateway.name STRING   ocnaddegressgateway:1.0.41-dev M Egress gateway image
image.ocnaddfilter.name STRING   ocnaddfilter:1.0.29-dev M Filter Service Image
image.ocnaddhealthmonitoring.name STRING   ocnaddhealthmonitoring:1.0.52 M Health Monitoring Image
image.ocnaddbackendrouter.name STRING   ocnaddbackendrouter:1.0.48 M Backend Router Image
image.ocnaddbackuprestore.name STRING   ocnaddbackuprestore:1.0.7 M Backup Restore Image
image.ocnadd_kafka_healthclient.name STRING   ocnadd-kafka-healthclient-3.2.3:1.0.11 M Kafka Image
image.ocnadd_jmx_exporter.name STRING   jmx-exporter-jdk-17.0.6:0.17.2 M JMX exporter image
image.ocnaddaggregation.name STRING   ocnaddgui:23.6.9-feature-mergeTest M OCNADD GUI Image
cluster.clusterName STRING   occne-ocdd M Default cluster name of setup
cluster.secret.name STRING   db-secret M Database Secret name where DB credentials are stored
cluster.mysqlNameSpace.name STRING   occne-cndbtierone M DBTier namespace
cluster.mysqlPod STRING   ndbmysqld-0 M DBTier Pod Name
cluster.database.db_ip STRING   mysql-connectivity-service.occne-cndbtierone M Hostname or IP of DBTier
cluster.database.db_port INTEGER   3306 M DB Port
cluster.database.configuration_db STRING   configuration_schema M Configuration Service Schema Name
cluster.database.alarm_db STRING   alarm_schema M Alarm Service Schema Name
cluster.database.health_db STRING   healthdb_schema M Health Service Schema Name
cluster.storageClass STRING   standard M Storage Class Name
cluster.nameSpace.name STRING - ocnadd-deploy M OCNADD Namespace
cluster.serviceAccount.create BOOLEAN true/false true M To create a ServiceAccount (true/false)
cluster.clusterRole.create BOOLEAN true/false true M To create clusterRole (true/false)
cluster.clusterRoleBinding.create BOOLEAN true/false true M To create clusterRoleBinding (true/false)
cluster.terminationGracePeriodSeconds INTEGER - 5 O Pod grace termination
cluster.imagePullSecret.enable BOOLEAN true/false false M Image Pull secret creation
cluster.imagePullSecret.name STRING - regcred O Set to regcred if cluster.imagePullSecret.enable is true
cluster.kafka.ocnadd_kafka_bootstrap_servers STRING - kafka-broker:9092 M Bootstrap server for PLAINTEXT
cluster.kafka.ocnadd_kafka_bootstrap_servers_ssl STRING - kafka-broker:9093 M Bootstrap server for SSL
cluster.kafka.ocnadd_kafka_bootstrap_servers_sasl STRING - kafka-broker:9094 M Bootstrap server for SASL
cluster.prometheusScrapePort INTEGER - 9000 O Port to scape metrics required if metrics enabled
cluster.prometheusPortName STRING - cnc-metrics O Role required to define in alert rules yaml
cluster.max_latency FLOAT - 0.05 M Max latency range of 50ms
cluster.memory_threshold INTEGER [0-100] 90 M Max Threshold limit for memory
cluster.cpu_threshold INTEGER [0-100] 70 M CPU max threshold limit
cluster.mps INTEGER - 55000 M Default MPS rate
cluster.egwGroupLatencyMessageCountMax INTEGER - 50 M Max latency count for Egress Gateway
cluster.prometheus_url STRING - http://localhost:9000/cluster-name/prometheus/api/v1/query_range M Prometheus URL to scrape metrics
network.policy.enable BOOLEAN true/false false M Network Policy enable for intercommunication of OCNADD services
network.ingress.denyall BOOLEAN true/false false C Deny all ingress traffic
network.ingress.kafka BOOLEAN true/false true C Allow ingress traffic for kafka
network.ingress.aggregation BOOLEAN true/false true C Allow ingress traffic for aggregation service
network.ingress.filter BOOLEAN true/false true C Allow ingress traffic for filter service
network.ingress.adapter BOOLEAN true/false true C Allow ingress traffic for adapter service
network.ingress.egw BOOLEAN true/false true C Allow ingress traffic for egress service
network.ingress.config BOOLEAN true/false true C Allow ingress traffic for configuration service
network.ingress.alarm BOOLEAN true/false true C Allow ingress traffic for alarm service
network.ingress.health BOOLEAN true/false true C Allow ingress traffic for health monitoring service
network.ingress.admin BOOLEAN true/false true C Allow ingress traffic for admin service
network.ingress.namespaces STRING -
- occne-infra
- occncc
C Network communication between allowed namespaces
network.ingress.external.enable BOOLEAN true/false false C Allow kafka LoadBalancer IP to be created
network.ingress.external.cidrs STRING - - 10.0.0.0/8 C Cidr for network communication
network.egress.denyall BOOLEAN true/false false C Deny egress traffic
3.2 Helm Hook Parameters
Table 3-2 Helm Hook Parameters
ocnaddhelmhook.config.name STRING - helmhook-configmap M Name of ConfigMap
ocnaddhelmhook.config.upgrade_name STRING - helmhook-upgrade-configmap M Name of Upgrade ConfigMap
ocnaddhelmhook.config.rollback_name STRING - helmhook-rollback-configmap M Name of Rollback ConfigMap
ocnaddhelmhook.name STRING - ocnaddhelmhook M Helm Hook Name
ocnaddhelmhook.container.name STRING - ocnaddhelmhook M Container Name of Helm Hook Job
ocnaddhelmhook.container.image STRING - pre-install-image:1.0.5 M Image used for pre-install hooks
ocnaddhelmhook.container.imagePullPolicy STRING IfNotPresent/Always/Never IfNotPresent M Image Pull Policy
ocnaddpostinstallhelmhook.name STRING - ocnaddpostinstallhelmhook M Post Install Hook Name
ocnaddpostupgradehelmhook.name STRING - ocnaddpostupgradehelmhook M Post Upgrade Hook Name
ocnaddpostrollbackhelmhook.name STRING - ocnaddpostrollbackhelmhook M Post Rollback hook name
ocnaddpreupgradehelmhook.name STRING - ocnaddpreupgradehelmhook M Pre Upgrade Hook Name
ocnaddprerollbackhelmhook.name STRING - ocnaddprerollbackhelmhook M Pre Rollback Hook Name
3.3 Aggregation Service Parameters
Table 3-3 Aggregation Service Parameters
ocnaddnrfaggregation.name STRING - ocnaddnrfaggregation M Name of the application
ocnaddscpaggregation.name STRING - ocnaddscpaggregation M Name of the application
ocnaddseppaggregation.name STRING - ocnaddnrfaggregation M Name of the application
ocnaddnrfaggregation.resources.limit.cpu INTEGER - 3 M Number of max CPU for NRF Aggregation
ocnaddnrfaggregation.resources.limit.memory STRING - 2Gi M Max Memory limit for NRF Aggregation
ocnaddnrfaggregation.resources.limit.ephemeralstorage STRING - 500Mi M Ephemeral Storage for NRF Aggregation
ocnaddscpaggregation.resources.limit.cpu INTEGER - 3 M Number of max CPU for SCP Aggregation
ocnaddscpaggregation.resources.limit.memory STRING - 2Gi M Max Memory limit for SCP Aggregation
ocnaddscpaggregation.resources.limit.ephemeralstorage STRING - 500Mi M Ephemeral Storage for SCP Aggregation
ocnaddseppaggregation.resources.limit.cpu INTEGER - 3 M Number of max CPU for SEPP Aggregation
ocnaddseppaggregation.resources.limit.memory STRING - 2Gi M Max Memory limit for SEPP Aggregation
ocnaddseppaggregation.resources.limit.ephemeralstorage STRING - 500Mi M Ephemeral Storage for SEPP Aggregation
OCNADD_AGGREGATION_LOG_ROOT STRING - INFO O Default Log level set for the application.
OCNADD_AGGREGATION_LOG_NETTY STRING - INFO O Default Netty Log level set for the application.
OCNADD_AGGREGATION_SERVICE_TOPIC_RETRIES_THRESHOLD INTEGER - 120000 O Retry Threshold for TOPIC reachability
OCNADD_METRICS_CPU_THRESHOLD FLOAT [ 0, 1 ] 0.45 O Parameter to compute the CPU related metrics of the application.
OCNADD_METRICS_MEM_THRESHOLD FLOAT [ 0, 1 ] 0.95 O Parameter to compute the Memory related metrics of the application.
ALARM_SERVICE_URL STRING - http://ocnaddalarm:9099 M Alarm Service API Root to raise alarm
KAFKA_PRODUCER_SECURITY_PROTOCOL STRING - PLAINTEXT M Kafka Producer Secutiry Protocol.
KAFKA_PRODUCER_SSL_PROTOCOL STRING - TLSv1.3 M SSL Protocol
KAFKA_PRODUCER_SASL_MECHANISM STRING - PLAIN M Kafka Producer SSAL Mechanism.
KAFKA_PRODUCER_SSL_CLIENT_AUTH BOOLEAN true, false false M Kafka SSL client authentication.
KAFKA_BOOTSTRAP_SERVER STRING - kafka-broker:9092 M Kafka Boot strap server address.
KAFKA_MAX_AGE_CONFIG INTEGER - 7500 M The period of time in milliseconds after which we force a refresh of metadata.
OCNADD_TRUST_KEYSTORE BOOLEAN true, false true M Enable to secure connection via OCWeb Client.
KAFKA_FETCH_MIN_BYTES STRING - 1 O The minimum amount of data per-partition the server will return
KAFKA_FETCH_MAX_BYTES INTEGER - 576720 O The maximum amount of data per-partition the server will return
KAFKA_MAX_PARTITIONS_FETCH_BYTES INTEGER - 104858 O The maximum amount of data per-partition the server will return.
FETCH_MAX_WAIT_MS INTEGER - 100 O The maximum amount of time the server will block before answering the fetch request if there isn’t sufficient data to immediately satisfy the requirement given by fetch.min.bytes
SESSION_TIME_OUT INTEGER - 15000 O The timeout used to detect client failures when using Kafka’s group management facility.
HEARTBEAT_INTERVAL_MS INTEGER - 5000 O The expected time between heartbeats to the consumer coordinator when using Kafka’s group management facilities
MAX_POLL_INTERVAL_MS INTEGER - 30000 O The maximum delay between invocations of poll() when using consumer group management
MAX_POLL_RECORDS INTEGER - 300 O The maximum number of records returned in a single call to poll()
CONSUMER_POLL_MS INTEGER - 50 O Polling time in ms for consumer
BATCH_SIZE INTEGER - 65536 O The maximum amount of data to be collected before sending the batch.
LINGER_MS INTEGER - 1 O The time to wait before sending messages out to Kafka
REQUEST_TIMEOUT_MS INTEGER - 1000 O The configuration controls the maximum amount of time the client will wait for the response of a request
KAFKA_SOCKET_BYTES_BUFFER INTEGER - 104857 O Kafka Socket Buffer setting for consumer
3.4 Configuration Service Parameters
Table 3-4 Configuration Service Parameters
ocnaddconfiguration.name STRING - ocnaddconfiguration M Name of configuration service
logging.type STRING STDOUT/LOGJSON STDOUT O Logging type Standard Output or JSON format
logging.level.reactor.netty STRING - INFO O Netty logging level
OCNADD_TRUST_KEYSTORE BOOLEAN - false O Truststore enable for Configuration Service
logging.level.com.oracle.cgbu.cne.ocnadd STRING - INFO O Logging level for OCNADD services
logging.level.com.oracle.cgbu.cne.ocdd STRING - INFO O Logging level for Common OCNADD services
3.5 Health Monitoring and Alarm Service Parameters
Table 3-5 Health Monitoring Service Parameters
Parameter Name Data Type Default Value Mandatory(M)/Optional(O)/Conditional(C) Description
ocnaddhealthmonitoring.name STRING ocnaddhealthmonitoring M Healthmonitoring monitoring service name
HEALTH_MONITORING_TIMER INTEGER 5000 O Timer to check Health of integrated services
HEALTH_METRICS_SCHEDULED BOOLEAN true O Scheduler for metrics
HEALTH_METRICS_TIMER INTEGER 120000 O Timer for health metrics
HEALTH_PURGE_TIME_HR INTEGER 24 O Health profile purging timer in hour
HEALTH_MONITORING_CPUTHRESHOLD INTEGER 75 M CPU threshold to raise alarm
HEALTH_MONITORING_MEMORYTHRESHOLD INTEGER 95 M Memory threshold to raise alarm
Logging Properties
HEALTH_LOG_HTTPCLIENT STRING INFO O Set Default Log level for Http Client
HEALTH_LOG_SPRING_WEB STRING INFO O Set Default Log level for Spring Web
logging.level.com.oracle.cgbu.cne.ocnadd STRING INFO O Logging level for Health Monitoring OCNADD Service
logging.level.com.oracle.cgbu.cne.ocdd STRING INFO O Logging level for Common OCNADD Service
HEALTH_APPLICATION_LOG_LEVEL STRING INFO O Set application logger level
Table 3-6 Alarm Service Parameters
ocnaddalarm.name STRING - ocnaddalarm M Application name for Alarm Service
logging.type STRING - STDOUT O Logging Type Standard Outpuut or JSON Format
OCNADD_TRUST_KEYSTORE BOOLEAN true/false true O Trust Keystore Enable
logging.level.com.oracle.cgbu.cne.ocnadd STRING - INFO O Logging level for Alarm OCNADD Service
logging.level.com.oracle.cgbu.cne.ocdd STRING - INFO O Logging level for Common OCNADD Service
3.6 Admin Service Parameters
Table 3-7 Admin Service Parameters
ocnadd.admin.name STRING - ocnaddadminservice M Application name admin service
Environment Variables
OCNADD_ADAPTER_LOG_LEVEL_NETTY STRING - INFO O Netty log level
OCNADD_ADAPTER_LOG_LEVEL STRING - INFO O Adapter service log level
OCNADD_ADAPTER_MIN_REPLICAS INTEGER - 2 M Minimum Replicas for Adapter
OCNADD_ADAPTER_MAX_REPLICAS INTEGER - 8 M Max Replicas for Adapter
MAX_TCP_CONNECTION_PER_DEST INTEGER - 1 M Max allowed TCP connection per destination
ADAPTER_KAFKA_FETCH_MAX_BYTES INTEGER - 576720 O The maximum amount of data the server should return for a fetch request
ADAPTER_KAFKA_MAX_PARTITION_FETCH_BYTES INTEGER - 104857 O The maximum amount of data per-partition the server will return
ADAPTER_KAFKA_FETCH_MAX_WAIT_MS INTEGER - 40 O The maximum amount of time the server will block before answering the fetch request
ADAPTER_KAFKA_SESSION_TIME_OUT INTEGER - 15000 O The timeout used to detect client failures when using Kafka’s group management facility
ADAPTER_KAFKA_HEARTBEAT_INTERVAL_MS INTEGER - 5000 O The expected time between heartbeats to the consumer coordinator when using Kafka’s group management facilities
ADAPTER_KAFKA_MAX_POLL_INTERVAL_MS INTEGER - 30000 O The maximum delay between invocations of poll() when using consumer group management
ADAPTER_KAFKA_MAX_POLL_RECORDS INTEGER - 1500 O The maximum number of records returned in a single call to poll()
ADAPTER_KAFKA_COMMIT_INT_CONFIG INTEGER - 30 O The frequency in milliseconds that the consumer offsets are committed to Kafka
ADAPTER_KAFKA_NUM_THREADS_CONFIG INTEGER - 9 O The number of threads to execute stream processing
ADAPTER_KAFKA_CONSUMER_POLL_MS INTEGER - 30 O The amount of time in milliseconds to block waiting for input
ADAPTER_KAFKA_RECEIVE_BUFFER_BYTES INTEGER - 104857 M The size of the TCP receive buffer (SO_RCVBUF) to use when reading data.
ADAPTER_WEBCLIENT_TYPE STRING - netty M Webclient Type for Adapter Service
OCNADD_ADAPTER_USE_TS BOOLEAN true/false true M Parameter to enable trustore use for Adapter
OCNADD_ADAPTER_SERVER_SSL BOOLEAN true/false false M Enable Server SSL for Adapter
EGRESS_MAX_CONNECTION_POOL_COUNT INTEGER - 100 O Max number of connections per connection pool
EGRESS_SSL_HANDSHAKE_TIMEOUT INTEGER - 40 O SSL handshake timeout
EGRESS_SSL_CLOSE_NOTIFY_FLUSH_TIMEOUT INTEGER - 20 O HttpClient Notify Flush timeout
EGRESS_SSL_CLOSE_NOTIFY_READ_TIMEOUT INTEGER - 20 O HttpClient Notify Read timeout
EGRESS_CLIENT_MAX_INMEMORY INTEGER - 12 O Webclient Max In Memory in Mb
EGRESS_JETTY_MAX_CONNECTION_PER_DESTINATION INTEGER - 12 O Jetty Max Connection per Destination
EGRESS_JETTY_MAX_REQUEST_PER_DESTINATION INTEGER - 1000 O Jetty Max Request per Destination
EGRESS_JETTY_CLIENT_IDLE_TIMEOUT INTEGER - 300000 O Jetty client IDLE timeout
EGRESS_JETTY_CLIENT_CONNECT_BLOCKING BOOLEAN true/false false O Jetty Client Connection Block Enable
EGRESS_JETTY_CLIENT_CONNECT_TIMEOUT INTEGER - 120000 O Jetty Client Connection Timeout
EGRESS_JETTY_CLIENT_STREAM_IDLE_TIMEOUT INTEGER - 300000 O Jetty Client Stream IDLE timeout
EGRESS_JETTY_CLIENT_MAX_CONCURR_PUSHED_STREAM INTEGER - 12 O Jetty HTTP2 client max concurrent pushed stream
ADAPTER_TCP_CLIENT_MSG_RETRY_MAX_ATTEMPTS INTEGER - 10 O Max TCP message retry
ADAPTER_TCP_CLIENT_MSG_RETRY_DELAY INTEGER - 50 O TCP Message retry delay
ENABLE_ADAPTER_COUNTER_METRICS BOOLEAN true/false true O Enable Adapter Counter Metric
ENABLE_ADAPTER_LATENCY_METRICS BOOLEAN true/false true O Enable Adapter Latency Metric
3.7 Kafka Configuration Parameters
Table 3-8 Kafka Configuration Parameters
Parameter Name Data Type Range Default Value Mandatory(M)/ Optional(O)/ Conditional(C) Description
kafkaBroker.kafkaProperties.logdirs String - /kafka/logdir/kafka-logs M The path to store the kafka logs
kafkaBroker.name String   kafka-broker   Name of the kafka broker
kafkaBroker.replicas Int   1   The number of replicas that you want to be available for the pod
kafkaBroker.pvcClaimSize String   10Gi M Size of Block Volume to attach to kafka
target.averageCpuUtilPercentage Int   50   The target average CPU utilization percentage
target.memoryUtilPercentage Int   80   The target average memory utilization percentage
kafkaBroker.resource.limits.cpu Int   5   The maximum limit for the number of CPUs used for the container
kafkaBroker.resource.limits.memory String   24Gi   The maximum limit for the size of the memory used for the container
kafkaBroker.kafkaProperties.logRetentionMinutes Int   5 M Log Retention Time of Topic Data in Minutes
kafkaBroker.kafkaProperties.kafkaSslProtocol String   TLSv1.2,TLSv1.3 M TLS version supported
kafkaBroker.kafkaProperties.socketSendBufferBytes Int   10485760 M TCP socket buffer sizes for the producer
kafkaBroker.kafkaProperties.socketReceiveBufferBytes Int   10485760 M TCP socket buffer sizes for the consumer
kafkaBroker.kafkaProperties.socketRequestMaxBytes Int   104857600 M The maximum number of bytes in a socket request
kafkaBroker.kafkaProperties.queuedMaxRequests Int   512 M Number of concurrent connections
kafkaBroker.kafkaProperties.numIoThreads Int   640 M Number of threads that pick up requests from the request queue to process them
kafkaBroker.kafkaProperties.numNetworkThreads Int   640 M Network threads handle requests to the Kafka cluster, such as produce and fetch requests from client applications
kafkaBroker.kafkaProperties.numReplicaFetchers Int   512 M Number of fetcher threads used to replicate records from each source broker
kafkaBroker.kafkaProperties.backgroundThreads Int   128 M The number of threads to use for various background processing tasks
kafkaBroker.kafkaProperties.replicaFetchMinBytes Int   619200 M Minimum bytes expected for each fetch response
kafkaBroker.kafkaProperties.replicaFetchMaxBytes Int   37152000 M The maximum number of bytes we will return for a fetch request
kafkaBroker.kafkaProperties.replicaFetchWaitMaxMs Int   50 M The maximum wait time for each fetcher request issued by follower replicas
kafkaBroker.kafkaProperties.replicaSocketReceiveBufferBytes Int   10485760 M The socket receive buffer for network requests
kafkaBroker.externalAccess.enabled Boolean   false M Flag to enable External access for Kafka
kafkaBroker.externalAccess.autoDiscovery Boolean   false M Flag to enable auto-discovery of LoadBalancer IPs
kafkaBroker.externalAccess.type String   LoadBalancer M Service Type of Kafka Broker
kafkaBroker.externalAccess.setstaticLoadBalancerIps Boolean   false M Setting Static LoadBalancer IPs
kafkaBroker.externalAccess.LoadBalancerIPList List   [ ] C List if LoadBalancer Static IP available for use
3.8 Backend Router Parameters
Table 3-9 Backend Router Parameters
ocnaddbackendrouter.name String - ocnaddbackendrouter M Application name for ocnaddbackendrouter
OCNADD_BKNROUTER_ROOT_LOG_LEVEL String   INFO O
Root log level configuration
(INFO,DEBUG,ERROR)
OCNADD_BKNROUTER_COM_LOG_LEVEL String   INFO O
Log level configuration
(INFO,DEBUG,ERROR)
OCNADD_BKNROUTER_LOG_LEVEL String   INFO O
(INFO,DEBUG,ERROR)
OCNADD_BKNROUTER_CLIENT_SSL_USE_TS Boolean   true O Client SSL Truststore enable
OCNADD_BKNROUTER_CLIENT_WIRETAP Boolean   false O Client Wiretap
OCNADD_BKNROUTER_SERVER_WIRETAP Boolean   false O Server Wiretap
WEBCLIENT_MAX_BUFFER_SIZE String   17777216 O Webclient Max buffer size for Backend router
